مشكل در SQLDataSours
hamidsina آفلاین
ارسال‌ها: 210
موضوع‌ها: 67
تاریخ عضویت: بهمن ۱۳۸۶
تشکرها : 94
( 23 تشکر در 11 ارسال )
[/code]با عرض سلام
من در ارسال جديد به ديتا بيس SQL توسط فرم ويو مشكل دارم
نوع فيلدهام رو هم عوض كردم ولي نشده
Error ي هم كه ميده اينه
Server Error in '/Boloor' Application.
Incorrect syntax near 'nvarchar'.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Incorrect syntax near 'nvarchar'.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SqlException (0x80131904): Incorrect syntax near 'nvarchar'.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +177
   System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +68
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +199
   System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2300
   System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +147
   System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +1021
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +314
   System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) +413
   System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +115
   System.Web.UI.WebControls.SqlDataSourceView.ExecuteDbCommand(DbCommand command, DataSourceOperation operation) +392
   System.Web.UI.WebControls.SqlDataSourceView.ExecuteInsert(IDictionary values) +405
   System.Web.UI.DataSourceView.Insert(IDictionary values, DataSourceViewOperationCallback callback) +68
   System.Web.UI.WebControls.FormView.HandleInsert(String commandArg, Boolean causesValidation) +388
   System.Web.UI.WebControls.FormView.HandleEvent(EventArgs e, Boolean causesValidation, String validationGroup) +609
   System.Web.UI.WebControls.FormView.OnBubbleEvent(Object source, EventArgs e) +88
   System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +35
   System.Web.UI.WebControls.FormViewRow.OnBubbleEvent(Object source, EventArgs e) +109
   System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +85
   System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument) +155
   System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +7
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +170
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4919
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
۲۵-مهر-۱۳۸۷, ۰۲:۴۵:۱۶
sizmamani آفلاین
تاریخ عضویت: اردیبهشت ۱۳۹۰
RE: مشكل در SQLDataSours
در هنگام بایند کردن از گذاشتن [] ونام فیلد داخل آن خودداری کن
bind("نام فیلد") درست
bind("[نام فیلد]") غلط
۲۵-اردیبهشت-۱۳۹۱, ۱۱:۵۸:۰۸
Ghoghnus آفلاین
ارسال‌ها: 1,506
موضوع‌ها: 277
( 3939 تشکر در 1454 ارسال )
میشه بیشتر توضیح بدید؟ دستور insert نوع فیلد هارا هم بگید تا بشه راهنمایی کرد!
باور کنیم
نیستیم؟
۲۵-اردیبهشت-۱۳۹۱, ۱۴:۵۵:۰۷
  مشكل اتصال سوكت در شبكه mahdi321 5 4,041 ۲۹-آذر-۱۳۹۴, ۱۷:۵۲:۵۲
آخرین ارسال: mahdi321
  مشكل با گزارش گيري ΛΛ Θ l-l $ Σ Ω 0 1,631 ۱۲-اسفند-۱۳۹۲, ۲۰:۲۴:۳۶
آخرین ارسال: ΛΛ Θ l-l $ Σ Ω
  [سوال] مشكل در اتصال به بانك ΛΛ Θ l-l $ Σ Ω 9 9,064 ۱۲-اسفند-۱۳۹۲, ۲۰:۲۰:۱۱
  مشكل پينهاي پورت com lemo 3 4,285 ۱۰-دى-۱۳۸۸, ۲۲:۵۱:۰۸
آخرین ارسال: hamidsina
