اشنایی کامل با ساختار فایلهای pe اشنایی با شیوه اجرای برنامه ها توسط ویندوز اشنایی با الگورتمهای coding و encryptiong وکمی کرک
(چند نمونه سورس پکر ساده رو بگیرین و روش کار کنین)
type
TSections = array [0..0] of TImageSectionHeader;
function GetAlignedSize(Size: dword; Alignment: dword): dword;
begin
if ((Size mod Alignment) = 0) then
Result := Size;
else
Result := ((Size div Alignment) + 1) * Alignment;
end;
function ImageSize(Image: pointer): dword;
var
Alignment: dword;
ImageNtHeaders: PImageNtHeaders;
PSections: ^TSections;
SectionLoop: dword;
begin
ImageNtHeaders := pointer(dword(dword(Image)) + dword(PImageDosHeader(Image)._lfanew));
Alignment := ImageNtHeaders.OptionalHeader.SectionAlignment;
if ((ImageNtHeaders.OptionalHeader.SizeOfHeaders mod Alignment) = 0) then
begin
Result := ImageNtHeaders.OptionalHeader.SizeOfHeaders;
end
else
begin
Result := ((ImageNtHeaders.OptionalHeader.SizeOfHeaders div Alignment) + 1) * Alignment;
end;
PSections := pointer(pchar(@(ImageNtHeaders.OptionalHeader)) + ImageNtHeaders.FileHeader.SizeOfOptionalHeader);
for SectionLoop := 0 to ImageNtHeaders.FileHeader.NumberOfSections - 1 do
begin
if PSections[SectionLoop].Misc.VirtualSize <> 0 then
begin
if ((PSections[SectionLoop].Misc.VirtualSize mod Alignment) = 0) then
begin
Result := Result + PSections[SectionLoop].Misc.VirtualSize;
end
else
begin
Result := Result + (((PSections[SectionLoop].Misc.VirtualSize div Alignment) + 1) * Alignment);
end;
end;
end;
end;
procedure CreateProcessEx(FileMemory: pointer);
var
BaseAddress, Bytes, HeaderSize, InjectSize, SectionLoop, SectionSize: dword;
Context: TContext;
FileData: pointer;
InjectMemory: pointer;
ProcInfo: TProcessInformation;
StartInfo: TStartupInfo;
begin
ImageNtHeaders := pointer(dword(dword(FileMemory)) + dword(PImageDosHeader(FileMemory)._lfanew));
InjectSize := ImageSize(FileMemory);
GetMem(InjectMemory, InjectSize);
try
FileData := InjectMemory;
HeaderSize := ImageNtHeaders.OptionalHeader.SizeOfHeaders;
begin
if PSections[SectionLoop].PointerToRawData < HeaderSize then HeaderSize := PSections[SectionLoop].PointerToRawData;
end;
CopyMemory(FileData, FileMemory, HeaderSize);
FileData := pointer(dword(FileData) + GetAlignedSize(ImageNtHeaders.OptionalHeader.SizeOfHeaders, ImageNtHeaders.OptionalHeader.SectionAlignment));
begin
if PSections[SectionLoop].SizeOfRawData > 0 then
begin
SectionSize := PSections[SectionLoop].SizeOfRawData;
if SectionSize > PSections[SectionLoop].Misc.VirtualSize then SectionSize := PSections[SectionLoop].Misc.VirtualSize;
CopyMemory(FileData, pointer(dword(FileMemory) + PSections[SectionLoop].PointerToRawData), SectionSize);
FileData := pointer(dword(FileData) + GetAlignedSize(PSections[SectionLoop].Misc.VirtualSize, ImageNtHeaders.OptionalHeader.SectionAlignment));
end
else
begin
if PSections[SectionLoop].Misc.VirtualSize <> 0 then FileData := pointer(dword(FileData) + GetAlignedSize(PSections[SectionLoop].Misc.VirtualSize, ImageNtHeaders.OptionalHeader.SectionAlignment));
end;
end;
ZeroMemory(@StartInfo, SizeOf(StartupInfo));
ZeroMemory(@Context, SizeOf(TContext));
CreateProcess(nil, pchar(ParamStr(0)), nil, nil, False, CREATE_SUSPENDED, nil, nil, StartInfo, ProcInfo);
Context.ContextFlags := CONTEXT_FULL;
GetThreadContext(ProcInfo.hThread, Context);
ReadProcessMemory(ProcInfo.hProcess, pointer(Context.Ebx + 8), @BaseAddress, 4, Bytes);
VirtualAllocEx(ProcInfo.hProcess, pointer(ImageNtHeaders.OptionalHeader.ImageBase), InjectSize, MEM_RESERVE or MEM_COMMIT, PAGE_EXECUTE_READWRITE);
WriteProcessMemory(ProcInfo.hProcess, pointer(ImageNtHeaders.OptionalHeader.ImageBase), InjectMemory, InjectSize, Bytes);
WriteProcessMemory(ProcInfo.hProcess, pointer(Context.Ebx + 8), @ImageNtHeaders.OptionalHeader.ImageBase, 4, Bytes);
Context.Eax := ImageNtHeaders.OptionalHeader.ImageBase + ImageNtHeaders.OptionalHeader.AddressOfEntryPoint;
SetThreadContext(ProcInfo.hThread, Context);
ResumeThread(ProcInfo.hThread);
finally
FreeMemory(InjectMemory);
end;
end;
برای استفاده ازش هم به صورت زیر خواهد بود
var
MyStream: TMemoryStream;
begin
MyStream := TMemoryStream.Create;
try
MyStream.LoadFromFile('Pro.exe');
//MyStream.LoadFromStream(yourstream);
CreateProcessEx(MyStream.Memory);
finally
MyStream.Free;
end;
end;
این یه نمونه ساده هست که ادرس یک فایل exe رو میدین و این برنامه اونو تو حافظه load میکنه حالا شما میتونین این فایل رو به هر صورت که دوست دارین با یکی از الگوریتم های کد یا encrypt کد کرده در یک stub ذخیره کنین و موقع اجرا با چک کردن مسایل امنیتی برنامه رو از حالت کد خارج و در حافظه اجرا کنید
