#include <string>
#include <fstream>
#pragma once
namespace wincpp2 {
using namespace System;
using namespace System::ComponentModel;
using namespace System::Collections;
using namespace System::Windows::Forms;
using namespace System::Data;
using namespace System::Drawing;
using namespace std;
/// <summary>
/// Summary for Form1
/// WARNING: If you change the name of this class, you will need to change the
/// 'Resource File Name' property for the managed resource compiler tool
/// associated with all .resx files this class depends on. Otherwise,
/// the designers will not be able to interact properly with localized
/// resources associated with this form.
/// </summary>
public ref class Form1 : public System::Windows::Forms::Form
public:
Form1(void)
InitializeComponent();
//TODO: Add the constructor code here
protected:
/// <summary>
/// Clean up any resources being used.
/// </summary>
~Form1()
if (components)
delete components;
private: System::Windows::Forms::Button^ button1;
protected:
private: System::Windows::Forms::TextBox^ textBox1;
private: System::Windows::Forms::TextBox^ textBox2;
private:
/// <summary>
/// Required designer variable.
/// </summary>
System::ComponentModel::Container ^components;
#pragma region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
void InitializeComponent(void)
this->button1 = (gcnew System::Windows::Forms::Button());
this->textBox1 = (gcnew System::Windows::Forms::TextBox());
this->textBox2 = (gcnew System::Windows::Forms::TextBox());
this->SuspendLayout();
// button1
this->button1->Location = System::Drawing::Point(43, 143);
this->button1->Name = L"button1";
this->button1->Size = System::Drawing::Size(109, 44);
this->button1->TabIndex = 0;
this->button1->Text = L"button1";
this->button1->UseVisualStyleBackColor = true;
this->button1->Click += gcnew System::EventHandler(this, &Form1::button1_Click);
// textBox1
this->textBox1->Location = System::Drawing::Point(53, 22);
this->textBox1->Name = L"textBox1";
this->textBox1->Size = System::Drawing::Size(109, 20);
this->textBox1->TabIndex = 1;
// textBox2
this->textBox2->Location = System::Drawing::Point(47, 66);
this->textBox2->Name = L"textBox2";
this->textBox2->Size = System::Drawing::Size(114, 20);
this->textBox2->TabIndex = 2;
// Form1
this->AutoScaleDimensions = System::Drawing::SizeF(6, 13);
this->AutoScaleMode = System::Windows::Forms::AutoScaleMode::Font;
this->ClientSize = System::Drawing::Size(284, 264);
this->Controls->Add(this->textBox2);
this->Controls->Add(this->textBox1);
this->Controls->Add(this->button1);
this->Name = L"Form1";
this->Text = L"Form1";
this->Load += gcnew System::EventHandler(this, &Form1::Form1_Load);
this->ResumeLayout(false);
this->PerformLayout();
#pragma endregion
fstream f("g:\\a.txt", ios::out);
private: System::Void button1_Click(System::Object^ sender, System::EventArgs^ e) {
private: System::Void Form1_Load(System::Object^ sender, System::EventArgs^ e) {
این کد فرم بود.
نمی خواد کامل بخونیدش. قسمت هایی که من اضاقه کردم :
اون خطی که fstream رو تعریف کردم ارور میده !
