مشکل ماژول گرفتن اطلاعات سیستم
hossein161 آفلاین
ارسال‌ها: 3
تاریخ عضویت: دى ۱۳۹۳
از این ماژول چند جا استفاده کردم مشکلی نداشت ولی امروز همش به کلمه ی left گیر میده و ..
این ماژول :
Type FILETIME
   lLowDateTime    As Long
   lHighDateTime   As Long
End Type
Declare Function RegOpenKeyEx Lib "advapi32.dll" Alias "RegOpenKeyExA" (ByVal hKey As Long, ByVal lpSubKey As String, ByVal ulOptions As Long, ByVal samDesired As Long, phkResult As Long) As Long
Declare Function RegCloseKey Lib "advapi32.dll" (ByVal hKey As Long) As Long
Declare Function RegCreateKey Lib "advapi32.dll" Alias "RegCreateKeyA" (ByVal hKey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Declare Function RegDeleteKey Lib "advapi32.dll" Alias "RegDeleteKeyA" (ByVal hKey As Long, ByVal lpSubKey As String) As Long
Declare Function RegQueryValueEx Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, ByVal lpData As String, lpcbData As Long) As Long
Declare Function RegQueryValueExA Lib "advapi32.dll" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, ByRef lpData As Long, lpcbData As Long) As Long
Declare Function RegSetValueEx Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, ByVal lpData As String, ByVal cbData As Long) As Long
Declare Function RegSetValueExA Lib "advapi32.dll" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, ByRef lpData As Long, ByVal cbData As Long) As Long
Declare Function RegSetValueExB Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, ByRef lpData As Byte, ByVal cbData As Long) As Long
Const ERROR_SUCCESS = 0&
Const ERROR_BADDB = 1009&
Const ERROR_BADKEY = 1010&
Const ERROR_CANTOPEN = 1011&
Const ERROR_CANTREAD = 1012&
Const ERROR_CANTWRITE = 1013&
Const ERROR_OUTOFMEMORY = 14&
Const ERROR_INVALID_PARAMETER = 87&
Const ERROR_ACCESS_DENIED = 5&
Const ERROR_NO_MORE_ITEMS = 259&
Const ERROR_MORE_DATA = 234&
Const REG_NONE = 0&
Const REG_SZ = 1&
Const REG_EXPAND_SZ = 2&
Const REG_BINARY = 3&
Const REG_DWORD = 4&
Const REG_DWORD_LITTLE_ENDIAN = 4&
Const REG_DWORD_BIG_ENDIAN = 5&
Const REG_LINK = 6&
Const REG_MULTI_SZ = 7&
Const REG_RESOURCE_LIST = 8&
Const REG_FULL_RESOURCE_DESCRIPTOR = 9&
Const REG_RESOURCE_REQUIREMENTS_LIST = 10&
Const KEY_QUERY_VALUE = &H1&
Const KEY_SET_VALUE = &H2&
Const KEY_CREATE_SUB_KEY = &H4&
Const KEY_ENUMERATE_SUB_KEYS = &H8&
Const KEY_NOTIFY = &H10&
Const KEY_CREATE_LINK = &H20&
Const READ_CONTROL = &H20000
Const WRITE_DAC = &H40000
Const WRITE_OWNER = &H80000
Const SYNCHRONIZE = &H100000
Const STANDARD_RIGHTS_REQUIRED = &HF0000
Const STANDARD_RIGHTS_READ = READ_CONTROL
Const STANDARD_RIGHTS_WRITE = READ_CONTROL
Const STANDARD_RIGHTS_EXECUTE = READ_CONTROL
Const KEY_READ = STANDARD_RIGHTS_READ Or KEY_QUERY_VALUE Or KEY_ENUMERATE_SUB_KEYS Or KEY_NOTIFY
Const KEY_WRITE = STANDARD_RIGHTS_WRITE Or KEY_SET_VALUE Or KEY_CREATE_SUB_KEY
Const KEY_EXECUTE = KEY_READ
Dim hKey As Long, MainKeyHandle As Long
Dim rtn As Long, lBuffer As Long, sBuffer As String
Dim lBufferSize As Long
Dim lDataSize As Long
Dim ByteArray() As Byte
'This constant determins wether or not to display error messages to the
'user. I have set the default value to False as an error message can and
'does become irritating after a while. Turn this value to true if you want
'to debug your programming code when reading and writing to your system
'registry, as any errors will be displayed in a message box.
Const DisplayErrorMsg = False
Function SetDWORDValue(SubKey As String, Entry As String, Value As Long)
Call ParseKey(SubKey, MainKeyHandle)
If MainKeyHandle Then
  rtn = RegOpenKeyEx(MainKeyHandle, SubKey, 0, KEY_WRITE, hKey) 'open the key
  If rtn = ERROR_SUCCESS Then 'if the key was open successfully then
     rtn = RegSetValueExA(hKey, Entry, 0, REG_DWORD, Value, 4) 'write the value
     If Not rtn = ERROR_SUCCESS Then   'if there was an error writting the value
        If DisplayErrorMsg = True Then 'if the user want errors displayed
           MsgBox ErrorMsg(rtn)        'display the error
     rtn = RegCloseKey(hKey) 'close the key
  Else 'if there was an error opening the key
End Function
Function GetDWORDValue(SubKey As String, Entry As String)
  rtn = RegOpenKeyEx(MainKeyHandle, SubKey, 0, KEY_READ, hKey) 'open the key
  If rtn = ERROR_SUCCESS Then 'if the key could be opened then
     rtn = RegQueryValueExA(hKey, Entry, 0, REG_DWORD, lBuffer, 4) 'get the value from the registry
     If rtn = ERROR_SUCCESS Then 'if the value could be retreived then
        GetDWORDValue = lBuffer  'return the value
     Else                        'otherwise, if the value couldnt be retreived
        GetDWORDValue = "Error"  'return Error to the user
        If DisplayErrorMsg = True Then 'if the user wants errors displayed
           MsgBox ErrorMsg(rtn)        'tell the user what was wrong
  Else 'otherwise, if the key couldnt be opened
End Function
Function SetBinaryValue(SubKey As String, Entry As String, Value As String)
     lDataSize = Len(Value)
     ReDim ByteArray(lDataSize)
     For i = 1 To lDataSize
     ByteArray(i) = Asc(Mid$(Value, i, 1))
     Next
     rtn = RegSetValueExB(hKey, Entry, 0, REG_BINARY, ByteArray(1), lDataSize) 'write the value
     If Not rtn = ERROR_SUCCESS Then   'if the was an error writting the value
End Function
Function GetBinaryValue(SubKey As String, Entry As String)
     lBufferSize = 1
     rtn = RegQueryValueEx(hKey, Entry, 0, REG_BINARY, 0, lBufferSize) 'get the value from the registry
     sBuffer = Space(lBufferSize)
     rtn = RegQueryValueEx(hKey, Entry, 0, REG_BINARY, sBuffer, lBufferSize) 'get the value from the registry
        GetBinaryValue = sBuffer 'return the value to the user
        GetBinaryValue = "Error" 'return Error to the user
        If DisplayErrorMsg = True Then 'if the user wants to errors displayed
           MsgBox ErrorMsg(rtn)  'display the error to the user
End Function
Function DeleteKey(Keyname As String)
Call ParseKey(Keyname, MainKeyHandle)
  rtn = RegOpenKeyEx(MainKeyHandle, Keyname, 0, KEY_WRITE, hKey) 'open the key
     rtn = RegDeleteKey(hKey, Keyname) 'delete the key
End Function
Function GetMainKeyHandle(MainKeyName As String) As Long
Const HKEY_CLASSES_ROOT = &H80000000
Const HKEY_CURRENT_USER = &H80000001
Const HKEY_LOCAL_MACHINE = &H80000002
Const HKEY_USERS = &H80000003
Const HKEY_PERFORMANCE_DATA = &H80000004
Const HKEY_CURRENT_CONFIG = &H80000005
Const HKEY_DYN_DATA = &H80000006
Select Case MainKeyName
      Case "HKEY_CLASSES_ROOT"
           GetMainKeyHandle = HKEY_CLASSES_ROOT
      Case "HKEY_CURRENT_USER"
           GetMainKeyHandle = HKEY_CURRENT_USER
      Case "HKEY_LOCAL_MACHINE"
           GetMainKeyHandle = HKEY_LOCAL_MACHINE
      Case "HKEY_USERS"
           GetMainKeyHandle = HKEY_USERS
      Case "HKEY_PERFORMANCE_DATA"
           GetMainKeyHandle = HKEY_PERFORMANCE_DATA
      Case "HKEY_CURRENT_CONFIG"
           GetMainKeyHandle = HKEY_CURRENT_CONFIG
      Case "HKEY_DYN_DATA"
           GetMainKeyHandle = HKEY_DYN_DATA
End Select
End Function
Function ErrorMsg(lErrorCode As Long) As String
'If an error does accurr, and the user wants error messages displayed, then
'display one of the following error messages
Select Case lErrorCode
      Case 1009, 1015
           getErrorMsg = "The Registry Database is corrupt!"
      Case 2, 1010
           getErrorMsg = "Bad Key Name"
      Case 1011
           getErrorMsg = "Can't Open Key"
      Case 4, 1012
           getErrorMsg = "Can't Read Key"
      Case 5
           getErrorMsg = "Access to this key is denied"
      Case 1013
           getErrorMsg = "Can't Write Key"
      Case 8, 14
           getErrorMsg = "Out of memory"
      Case 87
           getErrorMsg = "Invalid Parameter"
      Case 234
           getErrorMsg = "There is more data than the buffer has been allocated to hold."
      Case Else
           getErrorMsg = "Undefined Error Code:  " & Str$(lErrorCode)
End Select
End Function
Function GetStringValue(SubKey As String, Entry As String)
On Error Resume Next
     sBuffer = Space(255)     'make a buffer
     lBufferSize = Len(sBuffer)
     rtn = RegQueryValueEx(hKey, Entry, 0, REG_SZ, sBuffer, lBufferSize) 'get the value from the registry
        sBuffer = Trim(sBuffer)
        GetStringValue = Left(sBuffer, Len(sBuffer) - 1) 'return the value to the user
        GetStringValue = "Error" 'return Error to the user
        If DisplayErrorMsg = True Then 'if the user wants errors displayed then
End Function
Private Sub ParseKey(Keyname As String, Keyhandle As Long)
rtn = InStr(Keyname, "\") 'return if "\" is contained in the Keyname
If Left(Keyname, 5) <> "HKEY_" Or Right(Keyname, 1) = "\" Then 'if the is a "\" at the end of the Keyname then
  MsgBox "Incorrect Format:" + Chr(10) + Chr(10) + Keyname 'display error to the user
  Exit Sub 'exit the procedure
ElseIf rtn = 0 Then 'if the Keyname contains no "\"
  Keyhandle = GetMainKeyHandle(Keyname)
  Keyname = "" 'leave Keyname blank
Else 'otherwise, Keyname contains "\"
  Keyhandle = GetMainKeyHandle(Left(Keyname, rtn - 1)) 'seperate the Keyname
  Keyname = Right(Keyname, Len(Keyname) - rtn)
Function CreateKey(SubKey As String)
  rtn = RegCreateKey(MainKeyHandle, SubKey, hKey) 'create the key
  If rtn = ERROR_SUCCESS Then 'if the key was created then
End Function
Function SetStringValue(SubKey As String, Entry As String, Value As String)
     rtn = RegSetValueEx(hKey, Entry, 0, REG_SZ, ByVal Value, Len(Value)) 'write the value
End Function
عجیبه برام که بعضی اوقات کار میکنه ولی بعضی اوقات ارور       GetStringValue = Left(sBuffer, Len(sBuffer) - 1)
کد موقع خروجی گرفتن این شکلیه :
a = GetStringValue("HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion", "ProductId")
b = GetStringValue("HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\ComputerName\ActiveComputerName", "ComputerName")
۰۳-مرداد-۱۳۹۴, ۱۷:۴۴:۳۰
RE: مشکل ماژول گرفتن اطلاعات سیستم
احتمالا طول بافرت صفره.
۲۰-شهریور-۱۳۹۴, ۱۵:۲۲:۲۲
  چگونگی دریافت اطلاعات لحظه ای بورس javad917 10 14,847 ۱۷-فروردین-۱۳۹۹, ۱۹:۰۳:۴۵
آخرین ارسال: mostafa2020
آخرین ارسال: reza1354
  [سوال] گرفتن شماره ستون و ردیف از رنج مشخص به شکل داینامیک eppagh 0 2,162 ۰۶-اسفند-۱۳۹۳, ۲۰:۱۸:۱۳
آخرین ارسال: eppagh
  کمک برای گرفتن خروجی در EXCEL javad917 4 5,369 ۱۵-آبان-۱۳۹۳, ۱۴:۵۸:۵۴
آخرین ارسال: javad917
  مشکل در تماس گرفتن MSComm mahdi321 3 4,039 ۰۶-فروردین-۱۳۹۳, ۱۹:۴۶:۲۸
  سوال در مورد ماژول وینساک gachboy 5 4,476 ۲۲-بهمن-۱۳۹۲, ۱۷:۴۳:۵۲
آخرین ارسال: gachboy
  گرفتن سورس سایت aleas 6 5,415 ۲۷-شهریور-۱۳۹۲, ۱۴:۰۴:۴۰
آخرین ارسال: rap0661
  گروه بندی اطلاعات automa 9 6,342 ۲۵-تير-۱۳۹۲, ۲۰:۳۲:۵۱
آخرین ارسال: automa
