همه كامپاننت هاي Xceed رو دانلود كنيد
Mohamad_VB آفلاین
ارسال‌ها: 301
موضوع‌ها: 41
تاریخ عضویت: خرداد ۱۳۸۳
( 16 تشکر در 9 ارسال )
سلام به دوستان !
كسايي كه اينترنت پرسرعت دارن اينو از دست ندن
Xceed Ultimate Suite v2006.4
Xceed Ultimate Suite provides you with all 50 of Xceed's components and controls. Includes the highest quality grid,
chart, UI, Zip, FTP and encryption components on the market. The only suite that offers both UI tools for application
front-ends and data-handling libraries for application back-ends.
Xceed quality throughout
• All components provide royalty-free distribution rights. Deployment of server-only applications is limited as
described in the license agreement.
• All components are thoroughly and expertly documented and include a variety of sample applications.
• All components are multithreaded, written to be efficient and do not depend on external DLLs.
• All components are feature-rich yet easy to use due to the extreme emphasis on intuitive interface design.
• Source code for the included .NET components available in the Xceed Ultimate Suite Blueprint Edition.
Compression (ActiveX/COM)
• Includes Xceed Zip Compression Library, the industry's highest-performance and feature-rich Zip / Unzip
compression component. WinZip 9.0-compatible AES strong encryption now supported.
• Includes Xceed Self-Extractor Module for creating sharp, fully customizable self-extracting Zip files.
• Includes Xceed Streaming Compression Library for easy, efficient "raw" compression and decompression
functionality as well as support for .GZ or .BZ2 files.
• Includes Xceed Backup Library so you can add on-demand or scheduled backup and functionality to your
applications, quickly and easily.
Encryption (ActiveX/COM)
• Includes Xceed Encryption Library so you can encrypt and decrypt data with the latest strong algorithms, as well as
digitally sign and verify documents.
User Interface (.NET Windows Forms)
• Includes Xceed Grid for .NET, a multi-talented, advanced and feature rich grid component for .NET that offers an
extensible object model designed to set new standards for flexibility and ease of use. The only grid with a built-in
reporting engine.
• Includes Xceed SmartUI for .NET for creating user-friendly, state-of-the-art WinForms apps with ease. Supports
themed WinXP, Office XP, Office 2003 and classic Windows styles. Offers 10 controls including menubars, toolbars,
treeviews and task panes.
• Includes Xceed Chart for .NET for creating spectacular 2D/3D charts and graphs. Full features, straightforward
object model. Over 115 chart examples with source code help get you started quickly and easily.
• Includes Xceed Input Validator for .NET, providing easy-to-use, self-wiring text validation for your Windows Forms
controls. Each validation criterion can be configured visually and is then validated at runtime. Fully customizable error
messages. Also works with Xceed Grid for .NET on cells or rows.
• Xceed Editors for .NET, a modular set of 11 UI input controls such as buttons, combos, masked textboxs and
calendar controls that work together allowing you to create your own control combinations such as a resizeable and
editable dropdown listbox. Can also be used in Xceed Grid for .NET as editor controls. Now used in Xceed Grid for
.NET as the default editor controls.
• Xceed Docking Windows for .NET, a full-featured docking windows framework that allows your applications to
present windows and forms within a slick docking windows environment. Pixel-perfect and functionally faithful
recreation of the one you use in Visual Studio .NET.
User Interface (ASP.NET Web Forms)
• Includes Xceed Chart for ASP.NET. This solid, feature-rich chart server control provides extensive ASP.NET support
including streaming, image maps, server-side events, temp file cleanup and much more.
User Interface (ActiveX/VB6)
• Includes Xceed SmartUI, the best-selling tool for building Visual Basic 6 user interfaces. Includes over a dozen
state-of-the-art controls and a modular and versatile framework for creating your own.
Binary Encoding (ActiveX/COM)
• Includes Xceed Binary Encoding Library so you can convert binary data into ASCII text or vice-versa in a variety of
formats.
Internet (ActiveX/COM)
• Includes feature-rich Xceed FTP Library so you can send, receive or list documents on an FTP server.
Compression (.NET class library)
• Includes Xceed Zip for .NET, a multi-talented, 100%-managed compression component with built-in file transfer and
filesystem capabilities. Lets you tackle more programming tasks with one single component. Now supports AES
encryption at 128, 192 and 256 bits compatible with WinZip 9 and 10.
Compression (.NET Compact Framework class library)
• Includes Xceed Zip for .NET Compact Framework, a 100%-managed code compression library for .NET featuring
powerful, easy to use stream, Zip file manipulation and filesystem classes. Now features Zip64 zip file format.
• The .NET Compact Framework edition of Zip for .NET also includes capabilitites from Xceed Streaming
Compression for .NET, an efficient and lightweight compression class library for .NET that easily handles any size
byte array and offers a true .NET pass-through stream.
Internet (.NET class library)
• Includes Xceed FTP for .NET, a multi-talented, 100%-managed, robust and efficient class library that lets you easily
add FTP file transfer, Zip and filesystem capabilities to your .NET and ASP.NET apps through a straightforward and
intuitive object model. Lets you do more with one single component. Supports secure FTP. Now supports WinZip 9 &
10 compatible AES encryption at 128, 192 and 256 bits.
Released: 22.06.2006
Home:
http://www.xceedsoft.com/
Download: 58.3 MB (APP + FIX)
http://rapidshare.de/files/23877133/Xcee...0.rar.html
Password:
www.devilived.com
Amaze
O Allah the Almighty ;
Protect me and guide me ;
To your love and mercy ;
Ya Allah don’t deprive me ;
From beholding your beauty ;
O my Lord accept this plea
۰۳-تير-۱۳۸۵, ۱۰:۲۸:۵۸
mehdvirus آفلاین
ارسال‌ها: 439
موضوع‌ها: 27
تاریخ عضویت: اسفند ۱۳۸۲
( 39 تشکر در 26 ارسال )
RE: همه كامپاننت هاي Xceed رو دانلود كنيد
اوه مای گاد
۲۰-تير-۱۳۸۵, ۱۰:۴۳:۱۳
  درخواست راهنمایی برای ابزار تست نرم افزار که بشه راحت دانلود کرد و باهاش کار کرد m4rz1e 4 1,629 ۱۰-دى-۱۳۹۷, ۲۳:۰۹:۲۰
Exclamation [مقاله] دانلود نرم افزار pa reg نوشته شده به زبان ویژوال بیسیک parham2010 1 2,842 ۰۶-مرداد-۱۳۹۰, ۱۷:۳۷:۳۱
آخرین ارسال: CRazYFULL
  چند تا نرم افزار از همه جا واسه دانلود S3D4Love 4 5,760 ۲۱-آبان-۱۳۸۸, ۰۱:۴۰:۲۶
آخرین ارسال: S3D4Love
  دانلود آخرین نسخه ویندوز 7 با لینک مستقیم amgh_12 0 6,845 ۱۷-مرداد-۱۳۸۸, ۲۲:۵۲:۴۱
آخرین ارسال: amgh_12
  یاهو مسنجر ویستا ( تا داغه دانلود کن! ) Di Di 17 13,597 ۱۷-تير-۱۳۸۸, ۱۱:۳۹:۰۱
آخرین ارسال: toopdanlod
  روش جالب براي ترميم فايل هاي ناقص دانلود شده lord_viper 2 19,711 ۰۷-تير-۱۳۸۸, ۲۲:۲۲:۱۱
آخرین ارسال: igimax
  ادامه دانلود قطع شده توسط نرم افزار idm و به وسیله لینکی دیگر lord_viper 5 6,957 ۰۷-تير-۱۳۸۸, ۱۸:۴۶:۲۱
آخرین ارسال: t3r!p3000
  نرم افزار های portable را از اینجا دانلود کنید HoseinVig 8 9,951 ۲۶-اردیبهشت-۱۳۸۸, ۰۷:۱۶:۱۰
آخرین ارسال: Loyal
  دانلود غیرمستقیم ویندوز ۷ ساخت ۷۰۷۷ - نسخه ۳۲ بیتی Mr.pRoGraMmer 0 2,746 ۲۲-اردیبهشت-۱۳۸۸, ۱۷:۱۳:۱۵
آخرین ارسال: Mr.pRoGraMmer
Big Grin نرم افزار دانلود از Rapidshare Loyal 5 14,336 ۲۰-دى-۱۳۸۷, ۰۰:۱۸:۰۱
آخرین ارسال: Loyal
