تغيير در رجيستري ويندوز
hashem_te آفلاین
تاریخ عضویت: آبان ۱۳۸۶
ميخواهم يك مقدار رشته اي را در يك ورودي موجود در رجيستري بنويسم ولي آنچه در اثر كد زير نوشته ميشود با چيزي كه من تايپ ميكنم فرق دارد؟ راهنمايي كنيد
با تشكر
هاشمي
09132356511
hashemi-te@esfahansteel.com
Option Explicit
Dim KeyName As String
Dim EntryName As String
Dim Subtree As Long
Private Sub Form_Load()
Subtree = HKEY_LOCAL_MACHINE
"KeyName = "SYSTEM\Setup
"EntryName = "CmdLine
Private Sub ReadBtn_Click()
Dim hKey As Long
Dim lRetVal As Long
Dim vValue As Variant
Dim lValue As Long
(lRetVal = RegOpenKeyEx(Subtree, KeyName, 0, KEY_QUERY_VALUE, hKey
(lRetVal = QueryValueEx(hKey, EntryName, vValue
Me.ValueBox.Text = vValue
()Private Sub WriteBtn2_Click
Dim lRetVal As Long
Dim hKey As Long
Dim EntryType As Long
Dim sValue As String
sValue = Me.ValueBox.Text
EntryType = REG_SZ
(lRetVal = RegOpenKeyEx(Subtree, KeyName, 0, KEY_ALL_ACCESS, hKey
(lRetVal = SetValueEx(hKey, EntryName, EntryType, sValue
( RegCloseKey (hKey
الگوي توابع و ثابتها نيز در يك ماژول مشابه زير تعريف شده
Option Explicit
Public Const STANDARD_RIGHTS_ALL = &H1F0000
Public Const KEY_QUERY_VALUE = &H1
Public Const KEY_SET_VALUE = &H2
Public Const KEY_CREATE_SUB_KEY = &H4
Public Const KEY_ENUMERATE_SUB_KEYS = &H8
Public Const KEY_NOTIFY = &H10
Public Const KEY_CREATE_LINK = &H20
Public Const SYNCHRONIZE = &H100000
Public Const KEY_ALL_ACCESS = ((STANDARD_RIGHTS_ALL Or KEY_QUERY_VALUE Or KEY_SET_VALUE Or KEY_CREATE_SUB_KEY Or KEY_ENUMERATE_SUB_KEYS Or KEY_NOTIFY Or KEY_CREATE_LINK) And (Not SYNCHRONIZE))
Public Const HKEY_CURRENT_USER = &H80000001
Public Const REG_SZ = 1 ' Unicode nul terminated string
Public Const REG_DWORD = 4 ' 32-bit number
Public Const REG_EXPAND_SZ = 2 ' Unicode nul terminated string
Public Const ERROR_NONE = 0
Public Const LongSize_onByte = 4
Public Const HKEY_LOCAL_MACHINE = &H80000002
Declare Function RegOpenKeyEx Lib "advapi32.dll" Alias "RegOpenKeyExA" (ByVal hKey As Long, ByVal lpSubKey As String, ByVal ulOptions As Long, ByVal samDesired As Long, phkResult As Long) As Long
Declare Function RegCloseKey Lib "advapi32.dll" (ByVal hKey As Long) As Long
Declare Function RegSetValueEx Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, lpData As Any, ByVal cbData As Long) As Long ' Note that if you declare the lpData parameter as String, you must pass it By Value.
Declare Function RegQueryValueEx Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, lpData As Any, lpcbData As Long) As Long ' Note that if you declare the lpData parameter as String, you must pass it By Value.
Declare Function RegQueryValueExString Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, ByVal lpData As String, lpcbData As Long) As Long
Declare Function RegQueryValueExLong Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, lpData As Long, lpcbData As Long) As Long
Declare Function RegQueryValueExNULL Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, lpType As Long, ByVal lpData As Long, lpcbData As Long) As Long
Public Function SetValueEx(ByVal hKey As Long, ByVal EntryName As String, ByVal EntryType As Long, ByVal vValue As Variant) As Long
Dim lValue As Long
Select Case EntryType
Case REG_SZ 'type of value is string
sValue = vValue
SetValueEx = RegSetValueEx(hKey, EntryName, 0, EntryType, sValue, Len(sValue))
'lValue = Asc(vValue)
'SetValueEx = RegSetValueEx(hKey, EntryName, 0, EntryType, lValue, 4)
Case REG_DWORD 'type of value is Double word
lValue = vValue
Case Else
SetValueEx = RegSetValueEx(hKey, EntryName, 0, EntryType, vValue, 4)
End Select
End Function
Function QueryValueEx(ByVal lhKey As Long, ByVal szValueName As String, vValue As Variant) As Variant
Dim cch As Long
Dim lrc As Long
Dim lValue As Long
lrc = RegQueryValueExNULL(lhKey, szValueName, 0, EntryType, 0, cch)
Case REG_SZ: 'For strings
sValue = String(cch, 2)
lrc = RegQueryValueExString(lhKey, szValueName, 0, EntryType, sValue, cch)
If lrc = ERROR_NONE Then
vValue = Left$(sValue, cch - 1)
Else
vValue = Empty
Case REG_DWORD: 'For DWORDS
lrc = RegQueryValueExLong(lhKey, szValueName, 0, EntryType, lValue, cch)
If lrc = ERROR_NONE Then vValue = lValue
Case Else 'all other data types not supported
lrc = -1
End Select
QueryValueExExit:
QueryValueEx = lrc
Exit Function
QueryValueExError:
Resume QueryValueExExit
End Function
.zip   rar.zip (اندازه: 18.01 KB / تعداد دفعات دریافت: 61)
۱۴-آبان-۱۳۸۶, ۱۷:۴۰:۳۱
hashem_te آفلاین
RE: تغيير در رجيستري ويندوز
پاسخ در فايل ضميمه است
.zip   rar.zip (اندازه: 8.07 KB / تعداد دفعات دریافت: 65)
۱۶-آبان-۱۳۸۶, ۱۱:۱۷:۲۹
  تغيير همزمان در چند ابزار student-p 3 2,385 ۱۰-تير-۱۳۹۷, ۱۲:۴۱:۲۲
آخرین ارسال: student-p
  تبديل فونت داس به ويندوز majid_da57 6 8,492 ۰۱-آبان-۱۳۹۱, ۱۹:۲۸:۵۷
آخرین ارسال: bashiribashiri
  سورس برنامه براي گذاشتن رمز روي ويندوز بعد از ريستارت يا خاموش شدن rap0661 19 16,987 ۰۱-آبان-۱۳۹۰, ۰۰:۰۶:۳۱
  دستكاري رجيستري با توابع API shedayat 2 3,409 ۲۳-آبان-۱۳۸۸, ۱۹:۲۱:۰۲
آخرین ارسال: Redico2
  چسبيدن فرم به لبه هاي پنجره هاي ويندوز hamed_Arfaee 3 3,360 ۲۰-آبان-۱۳۸۸, ۱۶:۳۹:۴۳
آخرین ارسال: hamed_Arfaee
  تغيير سايز عكس reza87 2 3,196 ۰۲-آذر-۱۳۸۷, ۱۳:۲۲:۳۵
آخرین ارسال: asoft
  تغيير اسم فايلها reza87 7 7,328 ۲۵-آبان-۱۳۸۷, ۱۶:۵۹:۳۷
  تغيير Screen Refresh Rate vz67 6 5,835 ۲۲-مهر-۱۳۸۷, ۱۱:۱۹:۱۹
آخرین ارسال: vz67
  تغيير آيكون فايل exe reza87 1 4,079 ۲۱-شهریور-۱۳۸۷, ۱۲:۱۴:۱۵
آخرین ارسال: yeketaz
