من یه تابع به زبان VB دارم که میخوام اونو به زبان C / C++ تبدیل کنم البته اونو با Turbo C++ باید کامپایل کنم ، اگه در این ضمینه کمک کنید ممنون میشم
کار تابع به اینصورت که میاد یک عدد رو میگیره و معادل حروفی اونرو به زبان فارسی بر میگردونه مثل :
12 = دوازده
تابع به زبان VB :
Function Adad(ByVal Number As Double) As String
If Number = 0 Then
Adad = "صفر"
Dim Flag As Boolean
Dim S As String
Dim I, L As Byte
Dim K(1 To 5) As Double
S = Trim(Str(Number))
L = Len(S)
If L > 15 Then
Adad = "بسيار بزرگ"
Exit Function
For I = 1 To 15 - L
S = "0" & S
Next I
For I = 1 To Int((L / 3) + 0.99)
K(5 - I + 1) = Val(Mid(S, 3 * (5 - I) + 1, 3))
Next I
Flag = False
S = ""
For I = 1 To 5
If K(I) <> 0 Then
Select Case I
Case 1
S = S & Three(K(I)) & " تريليون"
Flag = True
Case 2
S = S & IIf(Flag = True, " و ", "") & Three(K(I)) & " ميليارد"
Flag = True
Case 3
S = S & IIf(Flag = True, " و ", "") & Three(K(I)) & " ميليون"
Flag = True
Case 4
S = S & IIf(Flag = True, " و ", "") & Three(K(I)) & " هزار"
Flag = True
Case 5
End Select
Next I
Adad = S
End Function
Function Three(ByVal Number As Integer) As String
Dim S As String
Dim I, L As Long
Dim h(1 To 3) As Byte
Dim Flag As Boolean
L = Len(Trim(Str(Number)))
If Number = 0 Then
Three = ""
Exit Function
If Number = 100 Then
Three = "يكصد"
Exit Function
If L = 2 Then h(1) = 0
If L = 1 Then
h(1) = 0
h(2) = 0
For I = 1 To L
h(3 - I + 1) = Mid(Trim(Str(Number)), L - I + 1, 1)
Next I
Select Case h(1)
Case 1
S = "يكصد"
Case 2
S = "دويست"
Case 3
S = "سيصد"
Case 4
S = "چهارصد"
Case 5
S = "پانصد"
Case 6
S = "ششصد"
Case 7
S = "هفتصد"
Case 8
S = "هشتصد"
Case 9
S = "نهصد"
End Select
Select Case h(2)
Case 1
Select Case h(3)
Case 0
S = S & " و " & "ده"
Case 1
S = S & " و " & "يازده"
Case 2
S = S & " و " & "دوازده"
Case 3
S = S & " و " & "سيزده"
Case 4
S = S & " و " & "چهارده"
Case 5
S = S & " و " & "پانزده"
Case 6
S = S & " و " & "شانزده"
Case 7
S = S & " و " & "هفده"
Case 8
S = S & " و " & "هجده"
Case 9
S = S & " و " & "نوزده"
End Select
Case 2
S = S & " و " & "بيست"
Case 3
S = S & " و " & "سي"
Case 4
S = S & " و " & "چهل"
Case 5
S = S & " و " & "پنجاه"
Case 6
S = S & " و " & "شصت"
Case 7
S = S & " و " & "هفتاد"
Case 8
S = S & " و " & "هشتاد"
Case 9
S = S & " و " & "نود"
End Select
If h(2) <> 1 Then
Select Case h(3)
Case 1
S = S & " و " & "يك"
Case 2
S = S & " و " & "دو"
Case 3
S = S & " و " & "سه"
Case 4
S = S & " و " & "چهار"
Case 5
S = S & " و " & "پنج"
Case 6
S = S & " و " & "شش"
Case 7
S = S & " و " & "هفت"
Case 8
S = S & " و " & "هشت"
Case 9
S = S & " و " & "نه"
End Select
S = IIf(L < 3, Right(S, Len(S) - 3), S)
Three = S
End Function
البته این تابع برای اساتید فکر نکنم پیچیده باشه بنابراین اگه تبدیل کردین و یا خودتون یک سورس بدید که همین کارو انجام بده که یک دنیا ممنون میشم
چون فوری هستش !!!
منتظر پاسخهاتون هستم ...
