تحلیل برنامه
m-hosseini84 آفلاین
تاریخ عضویت: تير ۱۳۸۶
تحلیل برنامه
سلام ، لطفاً اگه امکان داره الگوریتم این برنامه رو توضیح بدید تا یه چیزی ازش بفهمم
'                (c) 1997-2003 MCS Electronics
'                  APPLICATION NOTE 1
$regfile = "M32def.dat"
$crystal = 8000000
Dim Mat(210) As Byte                                        '7*30
Dim Buf(210) As Byte
Dim Char1 As Byte
Dim Char2 As Byte
Dim Lsh As Byte
Dim I As Byte
Dim J As Byte
Dim J2 As Byte
Dim Linebuf As Byte
Dim R As Byte
Dim Testbit As Byte
Dim N As Byte
Dim S As Byte
Dim Tmp As Byte
Dim Tmp2 As Byte
Dim Tmp3 As Byte
Dim Sum As Byte
Dim Charcon As Byte
Dim Charcur As Byte
Dim Cur As Integer
Config Porta = Output
Config Portb = Output
Porta = 0
Portb = 255
Cur = 0
For Cur = 1 To 210                                          'clear mat
Mat(cur) = 0
Next
For Cur = 1 To 210                                          'Clear Buf
Buf(cur) = 0
Next
Charcon = 5
Charcur = 0
If Charcon >= 6 Then                                        'number of shift mat<=buf
'load new char to buf-------------------------------------
'read string ssssssssssssssssssssssssssssssssssssssssssssss
If Charcur = 25 Then Charcur = 0                           'len of string
Tmp2 = Lookup(charcur , Mystr)
If Tmp2 = 32 Then
Tmp2 = 0
Else
Tmp2 = Tmp2 - 64
Tmp2 = Tmp2 * 5
Charcon = 0
Incr Charcur
For J = 0 To 4
Testbit = 1
Tmp3 = Tmp2 + J
Char1 = Lookup(tmp3 , Data3)                                'read row(j) if char map
For S = 0 To 7
   Tmp = Char1 And Testbit
        Shift Testbit , Left , 1
Sum = S * 30
Sum = Sum + J
Incr Sum
If Tmp <> 0 Then Buf(sum) = 1
Next
Next
'load new char-------------------------------------
'For R = 1 To 3
'shift left<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
'For J = 0 To 6
'For I = 2 To 30
'J2 = J * 30
'J2 = J2 + I
'Buf(j2 -1) = Buf(j2 )
'Next
'Next
'Next
Incr Charcon
For J = 0 To 6
                                           'scroolmat
For I = 2 To 30
J2 = J * 30
J2 = J2 + I
Mat(j2 -1) = Mat(j2 )
Next
Next
For J = 0 To 6                                              'shift mat<=buf 1col
J2 = J * 30
Mat(j2 + 30) = Buf(j2 + 1)
For I = 2 To 30
J2 = J * 30
J2 = J2 + I
Next
Next
'shift right>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
'For J = 0 To 6
'For I = 1 To 29
'J2 = J * 30
'Tmp = 30 - I
'J2 = J2 + Tmp
'Mat(j2 + 1 ) = Mat(j2 )
'Next
'Mat(j2) = 0
'Next
'For J = 0 To 6
'For I = 2 To 30
'J2 = J * 30
'J2 = J2 + I
'Mat(j2 -1) = Mat(j2 )
'Next
'Next
'Next
For Cur = 1 To 100
'start of display segment
    For J = 0 To 6
                                             'for 30 cols
For R = 1 To 30
     J2 = J * 30
     J2 = J2 + R
     If Mat(j2) = 0 Then Porta.1 = 0 Else Porta.1 = 1       'serial bit for send
     Porta.2 = 1                                            'clock for pick a bit rasing
     Porta.2 = 0
Next
     Porta.0 = 1                                            'clock for byte data load   rasing
     Porta.0 = 0
     Portb.j = 0
     Waitus 100
     Portb.j = 1
    Next
'end of display segment
Next
Mystr:
Data "IN THE NAME OF GOD                     "
Data3:
Data 0 , 0 , 0 , 0 , 0                                      'space
Data &H3F , &H44 , &H44 , &H44 , &H3F                       'A
Data &H7F , &H49 , &H49 , &H49 , &H36                       'B
Data &H3E , &H41 , &H41 , &H41 , &H22                       'C
Data &H7F , &H41 , &H41 , &H22 , &H1C                       'D
Data &H7F , &H49 , &H49 , &H49 , &H41                       'E
Data &H7F , &H48 , &H48 , &H48 , &H40                       'F
Data &H3E , &H41 , &H49 , &H49 , &H2F                       'G
Data &H7F , &H08 , &H08 , &H08 , &H7F                       'H
Data &H00 , &H41 , &H7F , &H41 , &H00                       'I
Data &H02 , &H01 , &H41 , &H7E , &H40                       'J
Data &H7F , &H08 , &H14 , &H22 , &H41                       'K
Data &H7F , &H01 , &H01 , &H01 , &H01                       'L
Data &H7F , &H20 , &H18 , &H20 , &H7F                       'M
Data &H7F , &H10 , &H08 , &H04 , &H7F                       'N
Data &H3E , &H41 , &H41 , &H41 , &H3E                       'O
Data &H7F , &H48 , &H48 , &H48 , &H30                       'P
Data &H3E , &H41 , &H45 , &H42 , &H3D                       'Q
Data &H7F , &H48 , &H4C , &H4A , &H31                       'R
Data &H31 , &H49 , &H49 , &H49 , &H46                       'S
Data &H40 , &H40 , &H7F , &H40 , &H40                       'T
Data &H7E , &H01 , &H01 , &H01 , &H7E                       'U
Data &H7C , &H02 , &H01 , &H02 , &H7C                       'V
Data &H7E , &H01 , &H06 , &H01 , &H7E                       'W
Data &H63 , &H14 , &H08 , &H14 , &H63                       'X
Data &H70 , &H08 , &H07 , &H08 , &H70                       'Y
Data &H43 , &H45 , &H49 , &H51 , &H61                       'Z
۰۸-تير-۱۳۸۶, ۰۹:۳۲:۱۵
این یه string رو می گیره بعد معادلش یه سری کارکتر رو توی بافر قرار می ده (معمولا برای نمایش روی ماتریس استفاده می شه ) بعد یکم چپ راستش کرده (یا ماتریس دیگه کافیه سطر و ستونش رو یکی بالا یا پایین ببری) مقدار زیادیش هم توضیحاتش کرده پاکش کن راحت تر می شه
این آخرش هم فکر کنم ارسالش کرده
تو رفتگی ها شم اگه رعایت کنی راحت تر می شه فهمیدش
۰۸-تير-۱۳۸۶, ۱۰:۱۴:۰۵
تشکر شده توسط : 1نفر
m-hosseini84 آفلاین
توضیح برنامه
اگه امکان داره بیشتر توضیح بدید .
چند سوال دیگه :
1- حداکثر فرکانس داخلی این مگا8 چنده ؟ کریستال خارجی که بهش میشه وصل کرد حداکثر چنده ؟
2- چرا زمانها دقیق نیست ؟ 1 ثانیه حدود 4 ثانیه تاخیر داره !!! برای دقیق شدن زمان چکار باید کرد ؟
3- یه مدار عملی اتصال ds1307 به مگا 8 میشه بدید به همراه کد بیسکام ؟
3- توی پروتیوس7.1 ds1307 نداره ؟
۰۸-تير-۱۳۸۶, ۱۰:۴۴:۲۰
newdesign آفلاین
ارسال‌ها: 218
موضوع‌ها: 14
تاریخ عضویت: فروردین ۱۳۸۶
( 30 تشکر در 22 ارسال )
جالبه کد رو هم می دی توضیح می خوان؟
این برنامه قرار بود استپشن (همون چراق قرمز که با ترمز روشن میشه بشه)
مثل اتوبوس های ولو اما خیلی ظریف و برای خود رو های سواری
اما توضیح برنامه
برای برنامه نویسی راههای مختلفی است
برای اونا که مبتدی هستد بهتر از روش پایین به بالا استفاده کنند
یعنی برنامه رو به قسمتهای کوچکتر تقسیم کنند من هم از این روش استفاده کردم
در این برنامه از این روش استفاده شده
1)قسمت اول یک حرف از جمله ای که باید نوشته بشه رو می خونه
2)قسمت دوم کارکتر رو تبدیل به بیت مپ می کنه و در بافر میریزه
3)قسمت سوم یک ستون از بافر رو در ماتریس display میریزه
4)قسمت چهار display نمایش داده میشه
واما سوالات
حداکثر فرکانس داخلی 8 و خارجی 16 مگا هرتز است
اگر از پروتیوس استفاده میکنید روی زمانبندی ان حساب نکنید
از کریستال خارجی استفاده کنید حواستان در تنظیم فیوز بیت باشه تا 3000 تومان لازم نباشه یک میکرو دیگه بخرید
برای اندازه گیری زمان بهتره از ایسی ساعت 1307 که 900 تومان استفاده کنید
پروتیوس 6.9 که تو سایت هستش داره من بسکام رو هم از همین سایت دانلود کردم که کتابخونه این ای سی رو داره
مثال اون هم تو help بسکام هستش همون مثال رو امتحان کردم درست بود
۰۹-تير-۱۳۸۶, ۰۰:۲۱:۴۴
تشکر شده توسط : m-hosseini84
  تحلیل یه برنامه به زبان بیسیک رسول21 1 2,840 ۱۴-فروردین-۱۳۹۲, ۱۲:۰۲:۳۳
آخرین ارسال: EBKA
  تحلیل مدار E.EINITABAR 4 4,942 ۰۹-آذر-۱۳۸۹, ۱۸:۲۱:۵۵
آخرین ارسال: E.EINITABAR
  درخواست تحلیل برنامه sumy 0 1,554 ۲۶-دى-۱۳۸۸, ۰۳:۰۹:۴۸
آخرین ارسال: sumy
