  • 2 رأی - میانگین امتیازات: 3
کنترل وسایل برقی توسط کامپیوتر
RE: کنترل وسایل برقی توسط کامپیوتر
مهندسین یه برنامه من 4 سال پیش تو اینترنت دیدم به نام parmon که کارش همینه !!
امکانات خیلی خوبی داره و میشه همه پایه های پورت پارالل رو باهاش صفر و یک کرد !! ( البته اونهایی که خروجی میشه تعریف کرد , چون بیشتر پایه ها زمین معرفی شده و نمیشه کاریشون کرد !!! )
این محیطش :
[تصویر:  0e228b7c7f144ae58a54.PNG]
و اینم توضیجات نرم افزار :
Parallel Port Monitor
(c) 1997-2002 Fred Bulback
email: fred@geekhideout.com
url: http://www.geekhideout.com
* This program is freeware.  It may be freely
* distributed provided:
*  1)  There is no accompanying fee of any sort.
*  2)  The executable file has not been modified
*      in any way.
*  3)  This file, "parmon.txt", accompanies the
*      executable.
Parallel Port Monitor is a utility for windows 95/98/NT
that permits the three registers of the parallel port to
be spied upon.
FAQ
Q: How do I change which parallel port is being spied
   upon?
A: Click on any cell in the port column.  If there is
   more than one port, the next one will be selected.
Q:  How do I edit the values ports values?
A:  Simply click on the cell that you wish to edit and
    type the new value.  Press <ENTER> when you are done,
    or <ESC> to cancel the edit.  Some registers cannot
    be edited and therefore will not change.
Q:  What's the "Beep" column all about?
A:  You can toggle each beep cell between "Yes" and "No".
    When the cell is yes, a beep will sound when the
    corresponding register changes.  If for some reason
    you want to toggle all cells, just click on the
    column title.
Q:  Is there a way to toggle individual bits?
A:  All of the output bits may be toggled by clicking on
    the appropriate pin on the connector diagram.
    Obviously, input pins cannot be toggled.
Q:  What's the deal with the female/male connector box?
A:  Suppose you have a cable in front of you.  By
    selecting female/male, you can easily match up the
    pins to those in the connector diagram.
Q:  On the connector, some pins are green while others
    are red.  What's the difference?
A:  Green pins are low, red pins are high.  This can
    be changed to whatever you want, however.
Q:  What does "Always on top" do.
A:  Since this program *is* a monitor program, chances
    are you want to see what it's doing.  By checking
    this box, the program will always be visible.
Q:  Why would I want to disable the connector?
A:  If your system is particularly slow, you may find
    that it flickers when it is updated, which can be
    annoying.
Q:  What does sample rate do?
A:  Sample rate determines how often the state of the
    port is sampled?  It defaults to "as fast as
    possible".  You may find, however, that this will
    slow your machine down too much.
Q:  What about the blink on sample box?
A:  When this box is checked, a small indicator will
    appear to the lower left of the connector.  Every
    time a sample is taken, it will blink to a different
    color.  This is useful if your sample rate is fairly
    long.  With a short sample rate, checking this box
    can have detrimental effects.
And the most frequently asked question:
Q:  Can you change Parallel Port Monitor so it logs the
    data?
A:  Yes I could, but I'm not going to.  The reason for
    this is that the program works by taking periodic
    samples of the state of the parallel port.
    Therefore all state changes between samples are
    not even noticed.  While this is ok for viewing
    with the eye, it is rather lousy for logging because
    a lot of information will be missing from the log
    potentially causing confusion.
I welcome all comments and suggestions:
.rar   parmon.rar (اندازه: 166.54 KB / تعداد دفعات دریافت: 83)
(آخرین ویرایش در این ارسال: ۱۲-مهر-۱۳۸۹, ۰۲:۳۴:۴۱، توسط t3r!p3000.)
۱۲-مهر-۱۳۸۹, ۰۲:۳۱:۳۱
تشکر شده توسط : رسول, reza555
aleas آفلاین
ارسال‌ها: 911
موضوع‌ها: 183
تاریخ عضویت: مهر ۱۳۸۹
تشکرها : 2946
( 2592 تشکر در 1223 ارسال )
بفرما روسرور هاست خودم اپلود کردم
http://www.p30novin.com/setup.zip
2.6mb
۱۲-مهر-۱۳۸۹, ۰۲:۳۸:۲۳
علی جون یعنی الان هرکدوم از اون خونه هارو روشن کنیم اون پایه تو خروجی پارالل روشن میشه ...یا اینکه کارهای دیگه ای هم باید انجام داد؟؟؟
(آخرین ویرایش در این ارسال: ۱۲-مهر-۱۳۸۹, ۰۲:۳۹:۴۳، توسط رسول.)
۱۲-مهر-۱۳۸۹, ۰۲:۳۹:۱۷
کار دیگه ای نمی خواد !
خودش انجام می ده !
۱۲-مهر-۱۳۸۹, ۰۲:۴۱:۰۲
(۱۲-مهر-۱۳۸۹, ۰۲:۳۸:۲۳)aleas نوشته است: بفرما روسرور هاست خودم اپلود کردم
2.6mb
دانلود کردم اما باز نمیشه ... ارور میده ..
۱۲-مهر-۱۳۸۹, ۰۲:۴۳:۵۰
aleas آفلاین
ارسال‌ها: 911
موضوع‌ها: 183
تشکرها : 2946
دوست عزیز اینی که شما گذاشتین با اینی من گذاشتم فرقی نداره فقط شکل ضاهریشون ولی اگر تعداد عداد نباید بیشتر از 8 تا باشه
ای بابا خودم تست کردم چه اروری؟
دوست عزیز من دارم میرم ولی این برنامه مشکلی نداره شاید بد دانلود کردی دوباره دانلودش کن دانلود کردی لازم نیست از فشرده خارجش کنی بازش کن رو setup کلیک کن نصبش کن همین بعد برو از محل نصب اجراش کن
(آخرین ویرایش در این ارسال: ۱۲-مهر-۱۳۸۹, ۰۳:۰۱:۲۹، توسط aleas.)
۱۲-مهر-۱۳۸۹, ۰۲:۴۸:۱۳
WhiteNoise آفلاین
ارسال‌ها: 941
تشکرها : 8104
( 7796 تشکر در 3061 ارسال )
رسول جان اینو بنگر
برا کنترل پارالل هست
با cشارپ نوشتدیده
البته من دانلود نکردم
ولی شاید به کارت باید
این
۱۷-مهر-۱۳۸۹, ۲۱:۱۱:۵۷
تشکر شده توسط : رسول, t3r!p3000, mahdi20, aleas
aleas آفلاین
ارسال‌ها: 911
موضوع‌ها: 183
تشکرها : 2946
دوستان نمیدونم سوالم تکراری یا نه اگر تکراری خواهشن ببخشید
میخوام تو این مدار بجای استفاده از رله از یک عدد رگولاتور قابلمه ای +15 ولت /78H15 و هشت عدد پتانسیومتر 5 کیلو اهم و سه عدد LM32 استفاده کنم ؟آیا شدنی هسته و به چه ترتیب باید به مدار وصلشون کنم توضیح کامل امیدوارم تکراری نباشه
(آخرین ویرایش در این ارسال: ۲۶-مهر-۱۳۸۹, ۲۲:۵۴:۳۲، توسط aleas.)
۲۶-مهر-۱۳۸۹, ۱۷:۲۶:۵۶
مهندس کاربرد رله یه چیزه !
کاربرد رگولاتور یه چیز دیگه !
به جای هم نمی تون قرار بگیرن !!!
حالا اگه فرضا بگه ترانزیستور قدرت یا تریاک می خوام بذارم به جای رله یه چیزی !!!!
دقیقا می خوای چی کار کنی ؟
توضیحات بیشتر بده !!!
۲۷-مهر-۱۳۸۹, ۰۲:۳۴:۲۴
aleas آفلاین
ارسال‌ها: 911
موضوع‌ها: 183
تشکرها : 2946
(۲۷-مهر-۱۳۸۹, ۰۲:۳۴:۲۴)Gawky نوشته است: مهندس کاربرد رله یه چیزه !
اینارو مهرداد بهم گفت به جا رله نمیدونم برای قطع وصل کردن وسایل برقی دگه مثل یخچال تلویزیون لامپ...
به ایمیلت یه سربزن
(آخرین ویرایش در این ارسال: ۲۷-مهر-۱۳۸۹, ۱۰:۴۳:۵۰، توسط aleas.)
۲۷-مهر-۱۳۸۹, ۱۰:۴۱:۳۳
WhiteNoise آفلاین
ارسال‌ها: 941
تشکرها : 8104
آخه گوش نمیکنی چی می گم بهت دیگه
بهت میگم رله هم بخر نمیخری
تو میخوای با 3 ولت یه 12 ولتو کنترل کنی میخواستی 16 تا رله بزاری من اومدم گفتم بجای اینکه با 8 تا رله ولتاژو ببری بالا با آپ امپ ببر
بهت میگم برو lm324بخر رفتی lm32خریدی که اصلا نمیدونم چی هست
قرار نیست تو با اینا بیای ولتاژو جریان بالا راه بندازی با اینا قراره ولتاژ 3 ولتتو تبدیل به 12 ولت کنی که تا اونجا که من میدونم بسیار راحته فقط باید آپ امپو راه بندازی اون تاپیک آموزش روباتیک از اول اول اولش من تو اون کاملا آپامپو توضیح دادم برو اول اونا رو بخون بعد بیا سوال بده
بیشتر از 500 باره بهت میگم اونو بخون نمیخونی برادر من شمال برو بخون اگه چیزی نفهمیدی بیا بپرس نه اینکه از همون اولش بیای سوال رو پست بزنی
در کل اینا رو برا خودت میگم دو روز دیگه علی بره اونموقع دیگه کسی نیست بهت جواب بده لنگ میمونی
(آخرین ویرایش در این ارسال: ۲۷-مهر-۱۳۸۹, ۱۵:۳۹:۰۲، توسط WhiteNoise.)
۲۷-مهر-۱۳۸۹, ۱۵:۳۸:۵۲
