از لینک های زیر 2 تا پروگرمر متن باز را می تونید دانلود کنید :
An open source USB programmer for PIC micros, I2C and MicroWire EEPROMs, some ATMEL micros, generic I2C/SPI devices
با پشتیبانی از چیپ های زیر :
Supported devices
I tried this programmer with a small number of devices (those I own) indicated in bold; the other devices are supported but not tested.
Please let me know if you verify operation with these devices.
Also contact me if you need other algorithms or code new ones by yourself.
devices supported for read and write:
10F200, 10F202, 10F204, 10F206, 10F220, 10F222,
12F508, 12F509, 12F510, 12F519, 12F609, 12F615, 12F629, 12F635, 12F675, 12F683,
16F505, 16F506, 16F526, 16F54, 16F610, 16F616, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F631, 16F636, 16F639, 16F648A, 16F676, 16F677, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F716, 16F73, 16F737, 16F74, 16F747, 16F76, 16F767, 16F77, 16F777, 16F785, 16F818, 16F819, 16F83, 16F83A, 16C83, 16C83A, 16F84, 16C84, 16F84A, 16C84A, 16F87, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A, 16F88, 16F882, 16F883, 16F884, 16F886, 16F887, 16F913, 16F914, 16F916, 16F917, 16F946,
18F242, 18F248, 18F252, 18F258, 18F442, 18F448, 18F452, 18F458, 18F1220, 18F1230, 18F1320, 18F1330, 18F2220, 18F2221, 18F2320, 18F2321, 18F2331, 18F2410, 18F2420, 18F2423, 18F2431, 18F2439, 18F2450, 18F2455, 18F2458, 18F2480, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2539, 18F2550, 18F2553, 18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F2682, 18F2685, 18F4220, 18F4221, 18F4320, 18F4321, 18F4331, 18F4410, 18F4420, 18F4423, 18F4431, 18F4439, 18F4450, 18F4455, 18F4458, 18F4480, 18F4510, 18F4515, 18F4520, 18F4523, 18F4525, 18F4539, 18F4550, 18F4553, 18F4580, 18F4585, 18F4610, 18F4620, 18F4680, 18F4682, 18F4685,
2400, 2401, 2402, 2404, 2408, 2416, 2432, 2464, 24128, 24256, 24512, 241025,
93C46C, 93C56C, 93C66C, 93S46, 93S56, 93S66
AT90S1200, AT90S8515, AT90S8535, ATmega8, ATmega8A, ATmega8515, ATmega8535, ATmega16, ATmega16A, ATmega32, ATmega32A
devices supported for read only:
12C508, 12C508A, 12C509, 12C509A, 12C671, 12C672, 12CE673, 12CE674
برای اطلاعات بیشتر به اینجا برید :
usbpicprog
برای اینکه ببینید از چه میکرو هایی پشتیبانی میکنه به اینجا برید :
اطلاعات بیشتر و دانلود :
نکته مهمی که باید توجه کنید این هست که این پروگرمر ها حتی اگر نخواهید بسازیدشون برای یادگیری به علت متن باز بودن بسیار مفید هستند.
