Open a port in Windows firewall
Top Previous Next
In order to make your computer more secure, Microsoft enables the Windows firewall by default in Windows Vista. This poses a problem if you need to run the BiblioWeb or BiblioRemote servers. The following instructions show how to open the ports needed by BiblioWeb and BiblioRemote in Windows Vista firewall. If you run other security software that blocks Windows ports, please refer to its user manual for how to open a port.
1.
In Windows Vista, click the Start button and type "firewall". Select the suggested program "Windows Firewall".
2.
On the left pane, click the hyperlink "Allow a program through Windows Firewall".
3.
BiblioWeb uses port 80 by default. Click the "Add port..." button. Enter a name like "biblioweb" and port number "80". Chose TCP as the protocol and click the OK button. If you already have a web server using port 80, BiblioWeb will default to port 8001. In that case, enter port 8001 instead. Or, instead, you can click the "Add program..." button and enter the full path to BiblioWeb.exe and click the OK button.
4.
BiblioRemote uses ports 12005 and 12006 by default. Click the "Add port..." button. Enter a name such as "biblioremote data" and port number "12005". Chose TCP as the protocol and click the OK button. Click the "Add port..." button again, and enter a name like "biblioremote admin" and port number "12006". Chose TCP as the protocol and click the OK button. Or, you can click the "Add program..." button and enter the full path to "...\BiblioRemote\dbsrvr.exe" and click the OK button.
