delphi 7 lite حجم 75.9 مگ
( 9876 تشکر در 2650 ارسال )
این هم یک نسخه کم حجم شده دلفی 7
[تصویر:  8908544.png?800]
که تمامی فیکس ها و اپدیتها روی این نسخه نصب هست و Rtl/VCL های این نسخه با نسخه delphi11 به همون delphi 2007 ارتقا پیدا کرده فایلهای اضافه و بخشهایی که کمتر مورد نیاز بودن حذف شده تا حجمش بیشتر از پیش پایین بیاد و قابلیت جالبش هم اینه که نیاز به نصب نداره و به صورت portable هست
نقل قول: Year: 2011
Version: 7.3.4.1
Platform: Windows
Language: English
Description:
Delphi 7 Lite is the standard Delphi 7 Enterprise, with some modifications:
- Added all the official updates, patches and other Bag-fix packs
- Supports all versions of Windows: Win7, Vista, XP, 2008, 2003, 2000, Me, 98, and NT 4.0
- All optional settings vybroscheny EXCEPT source code
- Added font Consolas (recommended size 10px-enabled CT)
- Changed the color settings in Delphi 2006
- Replaced the D7 RTL / VCL to D11 (Delphi 2007) RTL (FastMM and FastCode Core) (You can change!).
- Installed Update 1.1 (version IDE - 7.0.8.1), with the patch for 1.7 ActionBar
Unnecessary files are removed
- You can import the ActiveX
- Support for MIDAS
- Support for CLX Design
- Support for IntraWeb 5.0
- Support RaveReport 5
- The installation does not copy files to system directory
- Added the VCL Fix Pack 1.3, adding a module to your VCLFixPack.pas Delphi or C + + Builder project manually
- Added Midas Speed ​​Fix 1.2, adding a module to your MidasSpeedFix.pas Delphi or C + + Builder project manually.
- Includes the following modules from the WIN32 API extensions delphi-jedi.org
* SHELL LITE - Microsoft Shell Lightweight Utility API, v.1.2
* SNMP - Microsoft headers for Simple Network Management Protocol definitions
* WINSOCK 2 - Winsock 2 API (Windows Sockets)
- The portable version! You can copy the entire directory Delphi to another computer and run D7LiteReg ***. exe
- Dynamic compilation after installing the RTL / VCL and other components, thereby reducing the size of installation files
- Install support files, command line provide additional options.
Support for Delphi7 install Recovery Menu & Registration & Miscellaneous, use the command line parameter /? and / help.
- [Optional] all ingredients (except the Standard and DB Components)
- [Optional] Project Templates (Objrepos)
- [Optional] IDE Design Packages (Known IDE Packages)
- [Optional] Delphi IDE and command line compiler (dcc32, brcc32, convert, Make, Tasm32)
- [Optional] source files
- [Optional] Help files
- [Optional] change D7 RTL to D11 (Delphi 2007) RTL (FastMM and FastCode Core).
- [Optional] install Want builder tool instead of Make
- [Optional] install FastMM 4.84 IDE Optimize-Compiled DLL
- [Optional] install expert GExperts 1.33
- [Optional] install expert CnWizards 0.9.4.549
- [Optional] install expert DelforExp 2.5
- [Optional] install expert UnitExpert
- [Optional] install IDE plug DelphiSpeedUp 2.78
- [Optional] install IDE plug DDevExtensions 1.61
- [Optional] install tweaker DelphiDistiller 1.77, to determine packages that load at startup
- [Optional] install spy Microsoft Spy + + v7.1.
- [Optional] install DLL / EXE analyzer Dependency Walker 2.2
- [Optional] install DLL list shows all the exported functions of DLL Export Viewer v1.30
- [Optional] install built-in editor Delphi Image Editor (imagedit.exe)
- [Optional] install built-in editor Delphi Windows and Message Viewer (WinSight) (WS32.EXE)
- [Optional] install built-in editor, Delphi Web App Debugger (webappdbg.exe)
- [Optional] install BDE (Borland Database Engine 5.2) and tools BDE Administrator, SQL Explorer, Database Desktop, SQL Monitor, Data Pump and so on ...
- [Optional] BDE Data Samples (Aliais is DBDEMOS)
- All such experts / tweakers / plugins are OpenSource / Freeware
لینک دانلود با حجم 75.9 مگ
http://205.196.123.91/w2juhtad7z2g/xqnckbr8smy9vas/Delphi7_Lite_Full_Edition_7.3.4.1_Build_20110101.rar
(آخرین ویرایش در این ارسال: ۰۵-بهمن-۱۳۹۰, ۱۵:۱۷:۲۸، توسط lord_viper.)
۰۵-بهمن-۱۳۹۰, ۱۵:۱۶:۱۴
  codegear rad studio 2009 To Delphi Prism lukaskain 0 836 ۰۸-اردیبهشت-۱۳۹۸, ۰۱:۴۳:۵۶
آخرین ارسال: lukaskain
  مشکل در اندازه و فونت در Delphi 10 Seattle The.Ghost 2 2,470 ۲۲-مهر-۱۳۹۴, ۱۴:۳۴:۳۷
آخرین ارسال: The.Ghost
Question how RightToLeft Text Hint in delphi The.Ghost 0 1,823 ۲۱-اردیبهشت-۱۳۹۴, ۱۵:۲۱:۵۷
  Indy 10 for Delphi 7 xxxzzz 0 1,872 ۱۲-آذر-۱۳۹۳, ۰۵:۳۴:۲۱
آخرین ارسال: xxxzzz
Question Connecting to SQL Server 2000 using Delphi and dbExpress The.Ghost 2 3,196 ۰۷-آذر-۱۳۹۳, ۲۲:۴۴:۲۳
  سریال معتبر برای نصب Delphi XE5 godvb 0 3,242 ۲۶-مهر-۱۳۹۲, ۱۴:۳۰:۴۰
آخرین ارسال: godvb
Question عوض کردن آیکون EXE در Delphi XE3 The.Ghost 0 2,091 ۲۴-مرداد-۱۳۹۲, ۱۶:۳۴:۴۵
  آموزش دلفی به صورت تصویری و با توضحیحات کامل ( Delphi XE3 ) pr0gramm3r 3 10,558 ۳۰-اردیبهشت-۱۳۹۲, ۰۹:۵۶:۵۰
آخرین ارسال: pop_0098
  نحوه استفاده از کدهای زبان c در زبان Delphi The.Ghost 1 3,269 ۰۶-اردیبهشت-۱۳۹۱, ۱۳:۳۴:۰۰
  چسباندن C object کامپایل شده با vs در delphi xe2 lord_viper 0 2,316 ۰۷-دى-۱۳۹۰, ۲۱:۵۶:۲۶
