  • 1 رأی - میانگین امتیازات: 4
کلاس‌های مفید php
کلاس‌های مفید php
database-adapter برای کار با دیتاییس‌های SQL
مثال:
<?php
require_once 'DbAdapter.php';
$connection = array ('dsn' => 'mysql:dbname=databasename;host=localhost'//dsn: data source name
'username' => 'root',
'password' => '',
$dbObj = new DbAdapter($connection); //First of all creating an object
$table 'book';
/* DEMO EXAMPLES
 * //SIMPLE SELECT
 * 1. $dbObj->select() //or select('*') || select("'field1',field2") || select(array('field1','field2'))
 ->from($table) // pass second argument as alias
 * ->fetch(); will select only one row || fetchAll () for all rows
 * //SELECT WITH WHERE
 * 2. $dbObj->select()
 ->from($table)
 * ->where("field = 'value'") // or where(array('field'=>'value')) // Always put ANd between multiple condtions if array is passed
 * ->fetchAll();
 * //SELECT WITH FETCH MODE
 * 3. $dbObj->select(array('field1','field2'))
 ->from($table)
 * ->setFetchMode('FETCH_OBJ') // set fetch mode for current operation see all AVAILABLE FETCH MODES in (INTERFACE DbAdapterInterface)
 * ->where(array('field'=>'value'))
 * ->fetchAll();
 * //INSERT A RECORD MANUALLY
 * 4. $dbObj->insert($table,array('field'=>'field_value'));
 * //INSERT A RECORD AUTOMATICALLY
 * 5. $dbObj->insert($table,$_POST,TRUE); // THIRD ARGUMENT SET TO TRUE FOR AUTO INSERT
 * //UPDATE A RECORD AUTOMATICALLY
 * 6. $dbObj->update($table,$_POST); // IF COMPLETE FORM IS POSTED WITH HIDDEN PRIMARY KEY THEN IT WILL AUTO UPDATE
 * 7. //UPDATE A RECORD MANUALLY
 * $dbObj->update($table,array('field'=>'field_value'),array('condition'=>'value'));
 * 8. //DELETE RECORS
 * $dbObj->delete($table,array('key'=>'value'));
 * //Query
 * 9. $dbObj->query("SELECT * FROM $table")->fetch();
 * //GROUP BY,ORDER BY ,LIMIT
 * 10. $dbObj->select()
 ->from($table)
 * ->orderBy('field1,field1') // or orderBy(array('field1','field2'))
 ->groupBy('field1') // or groupBy(array('field1','field2'))
 * ->limit('1') or limit('0,10')
 * ->fetchAll();
 * //JOIN (join type,table,join conditions)
 * 11. $dbObj->select(array('field1','field2'))
 ->from(table1,'tbl1')
 ->join('left','table2 as tbl2','tbl1.id = tbl2.someid')
 ->join('left','table3 as tbl3','tbl2.someid = tbl3.someid')
 * ->fetchAll();
 * 12. //OR WHERE
 * $dbObj->select('*')
 * ->orWhere(array('field1'=>'value','field2'=>'value')) // Always put OR between multiple condtions if array is passed
 * ->fetchAll();
 * 13. //MIX OF ORWHERE AND WHERE
 * ->where(array('field1'=>'value','field2'=>'value'))
 * ->orWhere(array('field1'=>'value','field2'=>'value')) // ALWAYS SHOULD BE USED AFTER WHERE OR STATND ALONE
 * ->fetchAll();
 * if orWhere is used with where then it will just put OR between two statement
 * The syntex will create syntex below :
 * SELECT * FROM {table} where (table.field1 ='value' AND table.field1 ='value' ) OR (table.field1 ='value' AND table.field1 ='value' )
 * 14. OPERATOR USE
 * (A) <> OR != :- NOT EQUAL
 * (B) < :- LESS THAN
 * (C) > :- GREATOR THAN
 * (D) >= : GREATOR THAN EQUAL
 * (E) <= : LESS THAN EQUAL
$data $dbObj->select()
from($table)
fetchAll();
 echo
'<prE>';
print_r($data);
دانلود
کلاس DbAdapterInterface.php :
<?php
    * @interface    : DbAdapterInterface
    * @package      : DbAdapter
    * @author       : Satyam Kumawat
    * @version      : $id:1.0
interface DbAdapterInterface
    const
EXECEPTION 'Error Occured '
//const AUTO_INSERT = true;
    /* FETCH TYPE*/
const FETCH_LAZY   =1
    const
FETCH_ASSOC 2
    const
FETCH_NUM   3
    const
FETCH_BOTH  4
    const
FETCH_OBJ   5
//const FETCH_BOUND = 6;
    /** FETCH TYPE **/
     @function  :connect
     @params    :array config parameters as taken by PDO object
     @return    :PDO connection object
public function connect($config);
     @function  :select
     @params    :Array of fields| String of fields | if none give then (*) is set
     @return    :append select statement in query
public function select();
     @function  :delete
     @params    :String table name,Array condtions| String conditions
     @return    :no of affected row by given query
public function delete($table,$conditions=NULL);
     @function  :insert
     @params    :String table name,Array fields to be inserted,
                 autoInsert(if set to true then direct pass [FORM VALUES ($_REQUEST)] and function will insert required column according to the table structure automatically)
     @return    :last insert id
public function insert($table,$values,$autoInsert=false);
     @function  :update
     @params    :String table name,Array fields to be inserted, Array| String of condtions (if condtions in not given then it will search primary key in the given array values and updated the record automatically)
     @return    :last update record  id
public function update($table,$values,$conditions null);
     @function  :query
     @params    :Sting query (any sql statement)
public function query();
     @function  :fetch
     @params    :null
     @return    :first affected row
public function fetch();
     @function  :fetchAll
     @params    :null
     @return    :all affected row
public function fetchAll();
     @function  :where
     @params    :Array of conditions | String of prepared condtions
public function where($cond);
     @function  :orWhere
public function orWhere($cond);
     @function  :where
     @params    :Array of orderBy | String orderBy
public function orderBy($orderBy);
     @function  :groupBy
     @params    :Array of groupBy | String of groupBy
public function groupBy($groupBy);
     @function  :where
     @params    :String limit
public function limit($limit);
کلاس DbAdapter.php:
<?php
    * @class    : DbAdapter
require_once 'DbAdapterInterface.php';
class
DbAdapter  implements DbAdapterInterface{
    private
$select null;
    private
$isConnected false;
    public
$pdo null;
    private
$fields = array();
    private
$table null;
    private
$where null;
    private
$orWhere null;
    private
$orderBy null;
    private
$groupBy null;
    private
$limit null;
    private
$fetchmode self::FETCH_ASSOC;
    private
$reflectionObj null;
    private
$statementObj null;
    private
$tblStructure null;
    private
$primaryKey null;
    private
$join null;
    public function
__construct(array $config)
$this->connect($config);
    public function
connect($config){
      if(!
$this->isConnected)
              try{
$connection = new PDO($config['dsn'],$config['username'],$config['password']);
$connection->setAttribute(PDO::ATTR_DEFAULT_FETCH_MODE,self::FETCH_ASSOC);
$connection->setAttribute(PDO::ATTR_ERRMODE,PDO::ERRMODE_EXCEPTION);
$this->pdo $connection;
$this->isConnected true;
            catch (
Exception $e){
$this->exceptionHandler($e);
                 exit;
    public function
buildSql(){
$sql   $this->select;
$sql  .= $this->fields;
      if(
is_null($this->table))
            throw new
AdapterException('Table is missing');
$sql  .= $this->table;
      if(!
is_null($this->join)){
$sql .=$this->join;
      if(!
is_null($this->where)){
$sql  .= $this->where;
      if(!
is_null($this->orWhere)){
$sql  .= $this->orWhere;
      if(!
is_null($this->groupBy)){
$sql  .= $this->groupBy;
       if(!
is_null($this->orderBy)){
$sql  .= $this->orderBy;
       if(!
is_null($this->limit)){
$sql  .= $this->limit;
$this->_destruct();
      return
$sql;
    public function
select($fields ='*'){
      if(
is_null($this->select))
$this->select  'SELECT ';
      if(
is_array($fields))
$fieldString ="";
        foreach(
$fields as $key)
$fieldString .= "`$key`,";
$fieldString=substr($fieldString,0,-1);
$this->fields $fieldString;
      else
$this->fields $fields;
      return
$this;
    public function
insert($table,$values,$autoInsert false)
$this->table $table;
        if(!
is_array($values))
           throw new
AdapterException('INSERT query require Array  ('.gettype($values).') given','general');
$sql  'INSERT INTO';
$sql .= $this->_padString($this->table);
$sql .= $this->_padString('SET');
        if(
$autoInsert)
$columns $this->getTblStructure();
            foreach(
$values as $key =>$values)
                if(
in_array($key$columns))
$sql .= "`$key` ='".mysql_real_escape_string($values)."',";
        else
               foreach(
$sql .= "`$key` ='".mysql_real_escape_string($values)."' ,";
$sql=substr($sql,0,-1);
        if(
$this->execute($sql))
            return
$this->pdo->lastInsertId();
    public function
        if(!
is_array($values))
           throw new
AdapterException('Update query require Array  ('.gettype($values).') given','general');
$sql  'UPDATE';
$sql .= $this->_padString($table);
        if(
is_null($conditions))
$primaryKey $this->getPrimaryKey();
            if(!(
$primaryValue $values["$primaryKey"]))
               throw new
AdapterException("Auto Update  Syntex  Require PRIMARY KEY  ($primaryKey)");
$keyCount 0;
            foreach(
$values as $key =>$value)
$keyCount ++;
                if(
$key != $primaryKey && in_array($key$columns))
                     if(
$keyCount >)
$sql .= ",";
$sql .= "`$key`='".mysql_real_escape_string($value)."'";
$sql .= $this->_padString("WHERE `$primaryKey` =".$primaryValue);
        else
$keyCount =0;
               foreach(
$keyCount ++;
                if(
$keyCount >)
$sql .= ",";
$sql .= "`$key` ='".mysql_real_escape_string($values)."'";
$sql .= $this->_padString("WHERE");
            if(
is_array($conditions))
$count =0;
                foreach(
$conditions as $key =>$val)
$count ++;
                    if(
$count >)
$sql .= " AND ";
$sql .= "`$key` ='$val'";
            else {
$sql .= $condtions;
        return
$this->execute($sql);
    public function
getPrimaryKey()
$sql ="SHOW KEYS FROM ".$this->table." WHERE Key_name = 'PRIMARY'";
$keyData $this->query($sql)->fetch(self::FETCH_ASSOC);
$this->primaryKey $keyData['Column_name'];
       return
$this->primaryKey;
    public function
getTblStructure()
//$this->table = 'book';
$sql $this->_padString('DESCRIBE');
$this->query($sql);
$columns =   $this->query($sql)->fetchAll(PDO::FETCH_COLUMN);
$this->tblStructure $columns;
         return
$columns;
    public function
from($table,$alias=null){
$this->table " FROM $table as ".(is_null($alias) ? $table$alias);
        return
$this;
    public  function
execute($sql){
        try{
            return
$this->pdo->exec($sql);
       catch(
PDOException $e)
$exception = new AdapterException($e,'query');
$exception->throwException();
    public function
fetch(){
        return
$this->query()->fetch();
    public function
fetchAll(){
$data $this->query()->fetchAll();
        return
$data;
    public function
query($sql=null)
        if(
is_null($sql))
$sql $this->buildSql();
       try{
// $this->statementObj =  $this->pdo->query($sql);
          //return $this;
return $this->pdo->query($sql);
       catch(
PDOException $e)
            new
    public function
where($conditions =NULL)
        if(
          return
$this;
$where $this->_padString("WHERE ( ");
$count 0;
        if(
            foreach(
$conditions as $key =>$value){
$count++;
                if(
$count >1)
$where .=  $this->_padString("AND");
               if(
$char $this->_searchSpecialchar($key))
$where .= "$key '$value'";
                else{
$where .= "$key= '$value'";
        else
$where .= $conditions;
$where .=  $this->_padString(")");;
$this->where $where;
        return
$this;
    public function
orWhere($conditions)
        if(
          return
$this;
$onlyOR false;
        if(
$where $this->_padString("WHERE (");
$onlyOR true;
        else {
$where $this->_padString("OR (");
$count 0;
        if(
            foreach(
$count++;
$KeyWord = ($onlyOR) ? 'OR' :'AND';
                if(
$count >1)
$where .=  $this->_padString($KeyWord);
                if(
                else{
        else
$this->orWhere $where;
        return
$this;
    public function
_searchSpecialchar($string)
        if(
preg_match("/[<>>=<=!=]{2}|[><]{1}$/",trim($string),$match))
            return
$match[0];
        else {
            return
false;
    public function
        return
$this->_delete($table,$conditions);
    private function
$sql   $this->_padString("DELETE FROM",2,'right');
$sql  .= $table;
          if(!
is_null($conditions)){
$sql  .= $conditions;
         return
    public function
setFetchMode($mode)
$this->hasConstant($mode);
$this->pdo->setAttribute(PDO::ATTR_DEFAULT_FETCH_MODE,constant("self::$mode"));
        return
$this;
    public function
join($type='left',$table=null,$joinCond=null)
        if(
is_null($table)){
            throw new
AdapterException('Join function required second arugment to be (String) table name (Null) given.');
        if(
is_null($table)){
            throw new
AdapterException('Join function required third arugment to be (String) join conditions  (Null) given.');
$joinTitle $this->_padStringstrtoupper($type) .' '.'JOIN');
$statement =  $this->_padString($joinTitle) .$table .' ON'.$this->_padString($joinCond);
       if(
$this->join =  $statement ;
       else {
$this->join .= $statement ;
        return
$this;
    public function
orderBy($orderBy)
        if(
is_array($orderBy))
$this->orderBy $this->_padString('ORDER BY').implode(',',$orderBy);
        else {
$this->orderBy $this->_padString('ORDER BY'). $orderBy;
        return
$this;
    public function
groupBy($groupBy)
        if(
is_array($groupBy))
$this->groupBy $this->_padString('GROUP BY').implode(',',$groupBy);
        else{
$this->groupBy $this->_padString('GROUP BY').$groupBy;
        return
$this;
    public function
limit($limit)
$this->limit $this->_padString('limit') .$limit;
        return
$this;
    private function
_padString($input,$pad_length=2,$type=null)
$pad_length strlen($input) + $pad_length;
        switch (
$type
            case
'left':
$string str_pad($input,$pad_length," ",STR_PAD_LEFT);
                break;
            case
'right':
$string str_pad($input,$pad_length," ",STR_PAD_RIGHT);
                break;
            default:
$string str_pad($input,$pad_length," ",STR_PAD_BOTH);
                break;
      return
$string;
    public function
setAttribute($attribute,$value)
        if(!
defined(@constant("PDO::$attribute")))
            throw new
Exception("Error Occured : PDO  attribute ($attribute) does not exists");
$this->pdo->setAttribute(constant("PDO::$attribute"),$value);
        return
$this;
    private function
hasProperty($property)
        if(!
$this->reflectionObj)
$reflect = new ReflectionClass($this);
$this->reflectionObj $reflect;
        if(!
$this->reflectionObj->hasProperty($property))
           throw new
Exception(self::EXECEPTION .__CLASS__ ." does not have Property ($property) ");
    private function
hasConstant($constant)
        if(!
        if(!
$this->reflectionObj->hasConstant($constant))
            throw new
Exception(self::EXECEPTION .__CLASS__ ." does not have Constant ($constant)");
    private function
exceptionHandler($expectionobj)
$message $expectionobj->getMessage();
$file    $expectionobj->getFile();
$line    $expectionobj->getLine();
        echo
self::EXECEPTION.' <br>'.' Message : ' .$message .'<br>'.'File : '.$file.'<br>'.'Line No : '.$line;
    * @function : __get
    * @use      : call everytime a property is access
    * @return   : property of a class if exists
    * @input    : property_name
public function __get($property)
        if(
property_exists($this$property))
$reflect = new ReflectionProperty($this,$property);
            if(
$reflect->isPrivate())
                throw new
Exception("Propety ($property) is private and not accesible outside the class");
            else{
                return
$this->{$property};
        }else{
          throw new
Exception("Propety ($property) not available in the class");
    public function
__call($name,$args)
        if(!
method_exists($this$name))
            throw new
Exception("Error Occured : function ($name) not exists");
        else
//call_user_func_array($name, $arga);
    private function
_destruct()
$this->table  null;
$this->select null;
$this->fields null;
$this->where  null;
    * @class    : AdapterException
    * @use      : For exception handling
class AdapterException
        const
EXECP_HEADING'Error Occured';
        private
$exceptionType;
        private
$message;
        private
$expectionObj;
        public function
__construct($expectionObj,$type='general')
$this->exceptionType $type;
            if(
is_object($expectionObj))
$this->expectionObj $expectionObj;
$this->prepareExeception()->throwException();;
            else{
$this->simpleException($expectionObj)->throwException();
        public function
throwException()
$html  "<table width='800px' style='border:1px solid black;color:red;'><tr style='font-size:20px;'><td style='
            text-align:center'><b><u>"
.self::EXECP_HEADING."</u><b></td></tr>";
            foreach(
$this->message as $heading =>$data):
$html .="<tr><td><b><u>".ucwords($heading)." : </u></b>".$data."</td></tr>";
            endforeach;
$html .='</table>';
            echo
$html;
            exit;
        public function
prepareExeception()
$message = array();
            switch (
$this->exceptionType) {
                case
'general':
$message['message']  = $this->expectionObj->getMessage();
$message['file']     =  $this->expectionObj->getFile();
$message['line no']  = $this->expectionObj->getLine();
                    break;
                case
'query':
$trace     $this->expectionObj->getTrace();
$message['query']  = $trace[0]['args'][0];
                    break;
                default:
                    break;
$this->message $message;
            return
$this;
        public function
simpleException($msg)
$message['message']  = $msg;
               return
$this;
(آخرین ویرایش در این ارسال: ۰۹-فروردین-۱۳۹۲, ۱۲:۵۵:۲۷، توسط hamed_Arfaee.)
۰۵-فروردین-۱۳۹۲, ۲۰:۴۱:۳۹
تشکر شده توسط : hadikh73, Ghoghnus, lord_viper, hamed_Arfaee, omid_phoenix, aKaReZa75, javaweb, Ambassador, liliamq60
hamed_Arfaee آفلاین
ارسال‌ها: 1,334
موضوع‌ها: 231
تاریخ عضویت: تير ۱۳۸۳
تشکرها : 1250
( 2635 تشکر در 730 ارسال )
RE: کلاس‌های مفید php
من کلاس لایه دیتابیس"MYBB" رو خیلی دوست دارم
اینم خود کلاس و مثال های نحوه استفادش :
<?php
 * MyBB 1.6
 * Copyright 2010 MyBB Group, All Rights Reserved
 * Website: http://mybb.com
 * License: http://mybb.com/about/license
 * $Id$
class DB_MySQLi
     * The title of this layer.
     * @var string
public $title "MySQLi";
     * The short title of this layer.
     * @var string
public $short_title "MySQLi";
     * The type of db software being used.
     * @var string
public $type;
     * A count of the number of queries.
     * @var int
public $query_count 0;
     * A list of the performed queries.
     * @var array
public $querylist = array();
     * 1 if error reporting enabled, 0 if disabled.
     * @var boolean
public $error_reporting 1;
     * The read database connection resource.
     * @var resource
public $read_link;
     * The write database connection resource
     * @var resource
public $write_link;
     * Reference to the last database connection resource used.
     * @var resource
public $current_link;
     * Explanation of a query.
     * @var string
public $explain;
     * The current version of MySQL.
     * @var string
public $version;
     * The current table type in use (myisam/innodb)
     * @var string
public $table_type "myisam";
     * The table prefix used for simple select, update, insert and delete queries
     * @var string
public $table_prefix;
     * The extension used to run the SQL database
     * @var string
public $engine "mysqli";
     * Weather or not this engine can use the search functionality
     * @var boolean
public $can_search true;
     * The database encoding currently in use (if supported)
     * @var string
public $db_encoding "utf8";
     * The time spent performing queries
     * @var float
public $query_time 0;
     * Connect to the database server.
     * @param array Array of DBMS connection details.
     * @return resource The DB connection resource. Returns false on fail or -1 on a db connect failure.
// Simple connection to one server
if(array_key_exists('hostname'$config))
$connections['read'][] = $config;
        else
// Connecting to more than one server
// Specified multiple servers, but no specific read/write servers
if(!array_key_exists('read'$config))
                foreach(
$config as $key => $settings)
                    if(
is_int($key)) $connections['read'][] = $settings;
// Specified both read & write servers
else
$connections $config;
$this->db_encoding $config['encoding'];
// Actually connect to the specified servers
foreach(array('read''write') as $type)
            if(!
is_array($connections[$type]))
                break;
            if(
array_key_exists('hostname'$connections[$type]))
$details $connections[$type];
                unset(
$connections);
$connections[$type][] = $details;
// Shuffle the connections
shuffle($connections[$type]);
// Loop-de-loop
foreach($connections[$type] as $single_connection)
$connect_function "mysqli_connect";
$persist "";
                if(
$single_connection['pconnect'] && version_compare(PHP_VERSION'5.3.0''>='))
$persist "p:";
$link $type."_link";
$this->get_execution_time();
// Specified a custom port for this connection?
list($hostname$port) = explode(":"$single_connection['hostname'], 2);
                if(
$port)
$this->$link = @$connect_function($persist.$hostname$single_connection['username'], $single_connection['password'], ""$port);
                else
$this->$link = @$connect_function($persist.$single_connection['hostname'], $single_connection['username'], $single_connection['password']);
$time_spent $this->get_execution_time();
$this->query_time += $time_spent;
// Successful connection? break down brother!
if($this->$link)
$this->connections[] = "[".strtoupper($type)."] {$single_connection['username']}@{$single_connection['hostname']} (Connected in ".number_format($time_spent0)."s)";
                    break;
                else
$this->connections[] = "<span style=\"color: red\">[FAILED] [".strtoupper($type)."] {$single_connection['username']}@{$single_connection['hostname']}</span>";
// No write server was specified (simple connection or just multiple servers) - mirror write link
if(!array_key_exists('write'$connections))
$this->write_link = &$this->read_link;
// Have no read connection?
if(!$this->read_link)
$this->error("[READ] Unable to connect to MySQL server");
            return
false;
// No write?
else if(!$this->write_link)
$this->error("[WRITE] Unable to connect to MySQL server");
            return
false;
// Select databases
if(!$this->select_db($config['database']))
            return -
1;
$this->current_link = &$this->read_link;
        return
$this->read_link;
     * Selects the database to use.
     * @param string The database name.
     * @return boolean True when successfully connected, false if not.
function select_db($database)
        global
$mybb;
$master_success = @mysqli_select_db($this->read_link$database) or $this->error("[READ] Unable to select database"$this->read_link);
        if(
$this->write_link)
$slave_success = @mysqli_select_db($this->write_link$database) or $this->error("[WRITE] Unable to select slave database"$this->write_link);
$success = ($master_success && $slave_success true false);
        else
$success $master_success;
        if(
$success && $this->db_encoding)
$this->query("SET NAMES '{$this->db_encoding}'");
            if(
$slave_success && count($this->connections) > 1)
$this->write_query("SET NAMES '{$this->db_encoding}'");
        return
$success;
     * Query the database.
     * @param string The query SQL.
     * @param boolean 1 if hide errors, 0 if not.
     * @param integer 1 if executes on slave database, 0 if not.
     * @return resource The query data.
function query($string$hide_errors=0$write_query=0)
        global
$pagestarttime$db$mybb;
// Only execute write queries on slave server
if($write_query && $this->write_link)
$this->current_link = &$this->write_link;
$query = @mysqli_query($this->write_link$string);
        else
$query = @mysqli_query($this->read_link$string);
        if(
$this->error_number() && !$hide_errors)
$this->error($string);
            exit;
$query_time $this->get_execution_time();
$this->query_time += $query_time;
$this->query_count++;
        if(
$mybb->debug_mode)
$this->explain_query($string$query_time);
        return
$query;
     * Execute a write query on the slave database
function write_query($query$hide_errors=0)
        return
$this->query($query$hide_errors1);
     * Explain a query on the database.
     * @param string The time it took to perform the query.
function explain_query($string$qtime)
        global
$plugins;
        if(
$plugins->current_hook)
$debug_extra "<div style=\"float_right\">(Plugin Hook: {$plugins->current_hook})</div>";
        if(
preg_match("#^\s*select#i"$string))
$query mysqli_query($this->current_link"EXPLAIN $string");
$this->explain .= "<table style=\"background-color: #666;\" width=\"95%\" cellpadding=\"4\" cellspacing=\"1\" align=\"center\">\n".
"<tr>\n".
"<td colspan=\"8\" style=\"background-color: #ccc;\">{$debug_extra}<div><strong>#".$this->query_count." - Select Query</strong></div></td>\n".
"</tr>\n".
"<tr>\n".
"<td colspan=\"8\" style=\"background-color: #fefefe;\"><span style=\"font-family: Courier; font-size: 14px;\">".$string."</span></td>\n".
"</tr>\n".
"<tr style=\"background-color: #efefef;\">\n".
"<td><strong>table</strong></td>\n".
"<td><strong>type</strong></td>\n".
"<td><strong>possible_keys</strong></td>\n".
"<td><strong>key</strong></td>\n".
"<td><strong>key_len</strong></td>\n".
"<td><strong>ref</strong></td>\n".
"<td><strong>rows</strong></td>\n".
"<td><strong>Extra</strong></td>\n".
"</tr>\n";
            while(
$table mysqli_fetch_assoc($query))
$this->explain .=
"<tr bgcolor=\"#ffffff\">\n".
"<td>".$table['table']."</td>\n".
"<td>".$table['type']."</td>\n".
"<td>".$table['possible_keys']."</td>\n".
"<td>".$table['key']."</td>\n".
"<td>".$table['key_len']."</td>\n".
"<td>".$table['ref']."</td>\n".
"<td>".$table['rows']."</td>\n".
"<td>".$table['Extra']."</td>\n".
"</tr>\n";
$this->explain .=
"<tr>\n".
"<td colspan=\"8\" style=\"background-color: #fff;\">Query Time: ".$qtime."</td>\n".
"</tr>\n".
"</table>\n".
"<br />\n";
        else
"<tr>\n".
"<td style=\"background-color: #ccc;\">{$debug_extra}<div><strong>#".$this->query_count." - Write Query</strong></div></td>\n".
"</tr>\n".
"<tr style=\"background-color: #fefefe;\">\n".
"<td><span style=\"font-family: Courier; font-size: 14px;\">".htmlspecialchars_uni($string)."</span></td>\n".
"</tr>\n".
"<tr>\n".
"<td bgcolor=\"#ffffff\">Query Time: ".$qtime."</td>\n".
"</tr>\n".
"</table>\n".
"<br />\n";
$this->querylist[$this->query_count]['query'] = $string;
$this->querylist[$this->query_count]['time'] = $qtime;
     * Return a result array for a query.
     * @param resource The query data.
     * @param constant The type of array to return.
     * @return array The array of results.
function fetch_array($query)
$array mysqli_fetch_assoc($query);
        return
$array;
     * Return a specific field from a query.
     * @param resource The query ID.
     * @param string The name of the field to return.
     * @param int The number of the row to fetch it from.
function fetch_field($query$field$row=false)
        if(
$row !== false)
$this->data_seek($query$row);
$array $this->fetch_array($query);
        return
$array[$field];
     * Moves internal row pointer to the next row
     * @param int The pointer to move the row to.
function data_seek($query$row)
        return
mysqli_data_seek($query$row);
     * Return the number of rows resulting from a query.
     * @return int The number of rows in the result.
function num_rows($query)
        return
mysqli_num_rows($query);
     * Return the last id number of inserted data.
     * @return int The id number.
function insert_id()
$id mysqli_insert_id($this->current_link);
        return
$id;
     * Close the connection with the DBMS.
function close()
mysqli_close($this->read_link);
        if(
$this->write_link)
mysqli_close($this->write_link);
     * Return an error number.
     * @return int The error number of the current error.
function error_number()
        if(
            return
mysqli_errno($this->current_link);
        else
            return
mysqli_connect_errno();
     * Return an error string.
     * @return string The explanation for the current error.
function error_string()
        if(
            return
mysqli_error($this->current_link);
        else
            return
mysqli_connect_error();
     * Output a database error.
     * @param string The string to present as an error.
function error($string="")
        if(
$this->error_reporting)
            if(
class_exists("errorHandler"))
                global
$error_handler;
                if(!
is_object($error_handler))
                    require_once
MYBB_ROOT."inc/class_error.php";
$error_handler = new errorHandler();
$error = array(
"error_no" => $this->error_number(),
"error" => $this->error_string(),
"query" => $string
$error_handler->error(MYBB_SQL$error);
            else
trigger_error("<strong>[SQL] [".$this->error_number()."] ".$this->error_string()."</strong><br />{$string}"E_USER_ERROR);
        else
            return
false;
     * Returns the number of affected rows in a query.
     * @return int The number of affected rows.
function affected_rows()
        return
mysqli_affected_rows($this->current_link);
     * Return the number of fields.
     * @return int The number of fields.
function num_fields($query)
        return
mysqli_num_fields($query);
     * Lists all functions in the database.
     * @param string Prefix of the table (optional)
     * @return array The table list.
function list_tables($database$prefix='')
        if(
$prefix)
$query $this->query("SHOW TABLES FROM `$database` LIKE '".$this->escape_string($prefix)."%'");
        else
$query $this->query("SHOW TABLES FROM `$database`");
        while(list(
$table) = mysqli_fetch_array($query))
$tables[] = $table;
        return
$tables;
     * Check if a table exists in a database.
     * @param string The table name.
     * @return boolean True when exists, false if not.
function table_exists($table)
// Execute on master server to ensure if we've just created a table that we get the correct result
$query $this->write_query("
            SHOW TABLES
            LIKE '
{$this->table_prefix}$table'
$exists $this->num_rows($query);
        if(
$exists 0)
            return
true;
        else
            return
false;
     * Check if a field exists in a database.
     * @param string The field name.
function field_exists($field$table)
            SHOW COLUMNS
            FROM
            LIKE '
$field'
        if(
$exists 0)
            return
true;
        else
            return
false;
     * Add a shutdown query.
     * @param string An optional name for the query.
function shutdown_query($query$name=0)
        global
$shutdown_queries;
        if(
$name)
$shutdown_queries[$name] = $query;
        else
$shutdown_queries[] = $query;
     * Performs a simple select query.
     * @param string The table name to be queried.
     * @param string Comma delimetered list of fields to be selected.
     * @param string SQL formatted list of conditions to be matched.
     * @param array List of options, order by, order direction, limit, limit start.
function simple_select($table$fields="*"$conditions=""$options=array())
$query "SELECT ".$fields." FROM ".$this->table_prefix.$table;
        if(
$conditions != "")
$query .= " WHERE ".$conditions;
        if(isset(
$options['order_by']))
$query .= " ORDER BY ".$options['order_by'];
            if(isset(
$options['order_dir']))
$query .= " ".my_strtoupper($options['order_dir']);
        if(isset(
$options['limit_start']) && isset($options['limit']))
$query .= " LIMIT ".$options['limit_start'].", ".$options['limit'];
        else if(isset(
$options['limit']))
$query .= " LIMIT ".$options['limit'];
        return
$this->query($query);
     * Build an insert query from an array.
     * @param string The table name to perform the query on.
     * @param array An array of fields and their values.
     * @return int The insert ID if available
function insert_query($table$array)
        if(!
is_array($array))
            return
false;
$fields "`".implode("`,`"array_keys($array))."`";
$values implode("','"$array);
            INSERT
            INTO
{$this->table_prefix}{$table} (".$fields.")
            VALUES ('"
.$values."')
        return
$this->insert_id();
     * Build one query for multiple inserts from a multidimensional array.
     * @param array An array of inserts.
function insert_query_multiple($table$array)
        if(!
is_array($array))
            return
false;
// Field names
$fields array_keys($array[0]);
$fields "`".implode("`,`"$fields)."`";
$insert_rows = array();
        foreach(
$array as $values)
$insert_rows[] = "('".implode("','"$values)."')";
$insert_rows implode(", "$insert_rows);
            INSERT
            INTO
{$this->table_prefix}{$table} ({$fields}
            VALUES
{$insert_rows}
     * Build an update query from an array.
     * @param string An optional where clause for the query.
     * @param string An optional limit clause for the query.
     * @param boolean An option to quote incoming values of the array.
function update_query($table$array$where=""$limit=""$no_quote=false)
        if(!
is_array($array))
            return
false;
$comma "";
$query "";
$quote "'";
        if(
$no_quote == true)
$quote "";
        foreach(
$array as $field => $value)
$query .= $comma."`".$field."`={$quote}{$value}{$quote}";
$comma ', ';
        if(!empty(
$where))
$query .= " WHERE $where";
        if(!empty(
$limit))
$query .= " LIMIT $limit";
        return
            UPDATE
            SET
$query
     * Build a delete query.
function delete_query($table$where=""$limit="")
$query "";
        if(!empty(
$where))
        if(!empty(
$limit))
        return
$this->write_query("DELETE FROM {$this->table_prefix}$table $query");
     * Escape a string according to the MySQL escape format.
     * @param string The string to be escaped.
     * @return string The escaped string.
function escape_string($string)
        if(
function_exists("mysqli_real_escape_string") && $this->read_link)
$string mysqli_real_escape_string($this->read_link$string);
        else
$string addslashes($string);
        return
$string;
     * Frees the resources of a MySQLi query.
     * @param object The query to destroy.
     * @return boolean Returns true on success, false on faliure
function free_result($query)
        return
mysqli_free_result($query);
     * Escape a string used within a like command.
function escape_string_like($string)
        return
$this->escape_string(str_replace(array('%''_') , array('\\%' '\\_') , $string));
     * Gets the current version of MySQL.
     * @return string Version of MySQL.
function get_version()
        if(
$this->version)
            return
$this->version;
$query $this->query("SELECT VERSION() as version");
$ver $this->fetch_array($query);
        if(
$ver['version'])
$version explode("."$ver['version'], 3);
$this->version intval($version[0]).".".intval($version[1]).".".intval($version[2]);
        return
$this->version;
     * Optimizes a specific table.
     * @param string The name of the table to be optimized.
function optimize_table($table)
$this->write_query("OPTIMIZE TABLE ".$this->table_prefix.$table."");
     * Analyzes a specific table.
     * @param string The name of the table to be analyzed.
function analyze_table($table)
$this->write_query("ANALYZE TABLE ".$this->table_prefix.$table."");
     * Show the "create table" command for a specific table.
     * @param string The name of the table.
     * @return string The MySQL command to create the specified table.
function show_create_table($table)
$query $this->write_query("SHOW CREATE TABLE ".$this->table_prefix.$table."");
$structure $this->fetch_array($query);
        return
$structure['Create Table'];
     * Show the "show fields from" command for a specific table.
     * @return string Field info for that table
function show_fields_from($table)
$query $this->write_query("SHOW FIELDS FROM ".$this->table_prefix.$table."");
        while(
$field $this->fetch_array($query))
$field_info[] = $field;
        return
$field_info;
     * Returns whether or not the table contains a fulltext index.
     * @param string Optionally specify the name of the index.
     * @return boolean True or false if the table has a fulltext index or not.
function is_fulltext($table$index="")
$structure $this->show_create_table($table);
        if(
$index != "")
            if(
preg_match("#FULLTEXT KEY (`?)$index(`?)#i"$structure))
                return
true;
            else
                return
false;
        if(
preg_match('#FULLTEXT KEY#i'$structure))
            return
true;
        return
false;
     * Returns whether or not this database engine supports fulltext indexing.
     * @param string The table to be checked.
     * @return boolean True or false if supported or not.
function supports_fulltext($table)
$version $this->get_version();
$query $this->write_query("SHOW TABLE STATUS LIKE '{$this->table_prefix}$table'");
$status $this->fetch_array($query);
$table_type my_strtoupper($status['Engine']);
        if(
$version >= '3.23.23' && $table_type == 'MYISAM')
            return
true;
        return
false;
     * Returns whether or not this database engine supports boolean fulltext matching.
function supports_fulltext_boolean($table)
$supports_fulltext $this->supports_fulltext($table);
        if(
$version >= '4.0.1' && $supports_fulltext == true)
            return
true;
        return
false;
     * Checks to see if an index exists on a specified table
     * @param string The name of the index.
function index_exists($table$index)
$index_exists false;
$query $this->write_query("SHOW INDEX FROM {$this->table_prefix}{$table}");
        while(
$ukey $this->fetch_array($query))
            if(
$ukey['Key_name'] == $index)
$index_exists true;
                break;
        if(
$index_exists)
            return
true;
        return
false;
     * Creates a fulltext index on the specified column in the specified table with optional index name.
     * @param string Name of the column to be indexed.
     * @param string The index name, optional.
function create_fulltext_index($table$column$name="")
$this->write_query("ALTER TABLE {$this->table_prefix}$table ADD FULLTEXT $name ($column)");
     * Drop an index with the specified name from the specified table
function drop_index($table$name)
$this->write_query("ALTER TABLE {$this->table_prefix}$table DROP INDEX $name");
     * Drop an table with the specified table
     * @param boolean hard drop - no checking
     * @param boolean use table prefix
function drop_table($table$hard=false$table_prefix=true)
        if(
$table_prefix == false)
$table_prefix "";
        else
$table_prefix $this->table_prefix;
        if(
$hard == false)
$this->write_query('DROP TABLE IF EXISTS '.$table_prefix.$table);
        else
$this->write_query('DROP TABLE '.$table_prefix.$table);
     * Replace contents of table with values
     * @param array The replacements
function replace_query($table$replacements=array())
$values '';
$comma '';
        foreach(
$replacements as $column => $value)
$values .= $comma."`".$column."`='".$value."'";
$comma ',';
        if(empty(
$replacements))
             return
false;
        return
$this->write_query("REPLACE INTO {$this->table_prefix}{$table} SET {$values}");
     * Drops a column
     * @param string The column name
function drop_column($table$column)
        return
$this->write_query("ALTER TABLE {$this->table_prefix}{$table} DROP {$column}");
     * Adds a column
     * @param string the new column definition
function add_column($table$column$definition)
        return
$this->write_query("ALTER TABLE {$this->table_prefix}{$table} ADD {$column} {$definition}");
     * Modifies a column
function modify_column($table$column$new_definition)
        return
$this->write_query("ALTER TABLE {$this->table_prefix}{$table} MODIFY {$column} {$new_definition}");
     * Renames a column
     * @param string The old column name
     * @param string the new column name
function rename_column($table$old_column$new_column$new_definition)
        return
$this->write_query("ALTER TABLE {$this->table_prefix}{$table} CHANGE {$old_column} {$new_column} {$new_definition}");
     * Sets the table prefix used by the simple select, insert, update and delete functions
     * @param string The new table prefix
function set_table_prefix($prefix)
$this->table_prefix $prefix;
     * Fetched the total size of all mysql tables or a specific table
     * @param string The table (optional)
     * @return integer the total size of all mysql tables or a specific table
function fetch_size($table='')
        if(
$table != '')
$query $this->query("SHOW TABLE STATUS LIKE '".$this->table_prefix.$table."'");
        else
$query $this->query("SHOW TABLE STATUS");
$total 0;
        while(
$table $this->fetch_array($query))
$total += $table['Data_length']+$table['Index_length'];
        return
$total;
     * Fetch a list of database character sets this DBMS supports
     * @return array Array of supported character sets with array key being the name, array value being display name. False if unsupported
function fetch_db_charsets()
        if(
$this->link && version_compare($this->get_version(), "4.1""<"))
            return
false;
        return array(
'big5' => 'Big5 Traditional Chinese',
'dec8' => 'DEC West European',
'cp850' => 'DOS West European',
'hp8' => 'HP West European',
'koi8r' => 'KOI8-R Relcom Russian',
'latin1' => 'cp1252 West European',
'latin2' => 'ISO 8859-2 Central European',
'swe7' => '7bit Swedish',
'ascii' => 'US ASCII',
'ujis' => 'EUC-JP Japanese',
'sjis' => 'Shift-JIS Japanese',
'hebrew' => 'ISO 8859-8 Hebrew',
'tis620' => 'TIS620 Thai',
'euckr' => 'EUC-KR Korean',
'koi8u' => 'KOI8-U Ukrainian',
'gb2312' => 'GB2312 Simplified Chinese',
'greek' => 'ISO 8859-7 Greek',
'cp1250' => 'Windows Central European',
'gbk' => 'GBK Simplified Chinese',
'latin5' => 'ISO 8859-9 Turkish',
'armscii8' => 'ARMSCII-8 Armenian',
'utf8' => 'UTF-8 Unicode',
'ucs2' => 'UCS-2 Unicode',
'cp866' => 'DOS Russian',
'keybcs2' => 'DOS Kamenicky Czech-Slovak',
'macce' => 'Mac Central European',
'macroman' => 'Mac West European',
'cp852' => 'DOS Central European',
'latin7' => 'ISO 8859-13 Baltic',
'cp1251' => 'Windows Cyrillic',
'cp1256' => 'Windows Arabic',
'cp1257' => 'Windows Baltic',
'binary' => 'Binary pseudo charset',
'geostd8' => 'GEOSTD8 Georgian',
'cp932' => 'SJIS for Windows Japanese',
'eucjpms' => 'UJIS for Windows Japanese',
     * Fetch a database collation for a particular database character set
     * @param string The database character set
     * @return string The matching database collation, false if unsupported
function fetch_charset_collation($charset)
$collations = array(
'big5' => 'big5_chinese_ci',
'dec8' => 'dec8_swedish_ci',
'cp850' => 'cp850_general_ci',
'hp8' => 'hp8_english_ci',
'koi8r' => 'koi8r_general_ci',
'latin1' => 'latin1_swedish_ci',
'latin2' => 'latin2_general_ci',
'swe7' => 'swe7_swedish_ci',
'ascii' => 'ascii_general_ci',
'ujis' => 'ujis_japanese_ci',
'sjis' => 'sjis_japanese_ci',
'hebrew' => 'hebrew_general_ci',
'tis620' => 'tis620_thai_ci',
'euckr' => 'euckr_korean_ci',
'koi8u' => 'koi8u_general_ci',
'gb2312' => 'gb2312_chinese_ci',
'greek' => 'greek_general_ci',
'cp1250' => 'cp1250_general_ci',
'gbk' => 'gbk_chinese_ci',
'latin5' => 'latin5_turkish_ci',
'armscii8' => 'armscii8_general_ci',
'utf8' => 'utf8_general_ci',
'ucs2' => 'ucs2_general_ci',
'cp866' => 'cp866_general_ci',
'keybcs2' => 'keybcs2_general_ci',
'macce' => 'macce_general_ci',
'macroman' => 'macroman_general_ci',
'cp852' => 'cp852_general_ci',
'latin7' => 'latin7_general_ci',
'cp1251' => 'cp1251_general_ci',
'cp1256' => 'cp1256_general_ci',
'cp1257' => 'cp1257_general_ci',
'binary' => 'binary',
'geostd8' => 'geostd8_general_ci',
'cp932' => 'cp932_japanese_ci',
'eucjpms' => 'eucjpms_japanese_ci',
        if(
$collations[$charset])
            return
$collations[$charset];
        return
false;
     * Fetch a character set/collation string for use with CREATE TABLE statements. Uses current DB encoding
     * @return string The built string, empty if unsupported
function build_create_table_collation()
        if(!
$this->db_encoding)
            return
$collation $this->fetch_charset_collation($this->db_encoding);
        if(!
$collation)
            return
        return
" CHARACTER SET {$this->db_encoding} COLLATE {$collation}";
     * Time how long it takes for a particular piece of code to run. Place calls above & below the block of code.
     * @return float The time taken
function get_execution_time()
        static
$time_start;
$time microtime(true);
// Just starting timer, init and return
if(!$time_start)
$time_start $time;
            return;
// Timer has run, return execution time
else
$total $time-$time_start;
            if(
$total 0$total 0;
$time_start 0;
            return
$total;
آماده سازی (ساخت شی و تنظیمات کانکشن :
<?php
error_reporting
(E_ALL E_NOTICE);
require_once
"db_mysqli.php";
$config['database']['type'] = 'mysqli';
$config['database']['database'] = 'db1';
$config['database']['table_prefix'] = '';
$config['database']['hostname'] = 'localhost';
$config['database']['username'] = 'root';
$config['database']['password'] = '';
$config['database']['encoding'] = 'utf8';
$db = new DB_MySQLi;
$db->connect($config['database']);
$db->set_table_prefix($config['database']['table_prefix']);
$db->type $config['database']['type'];
مثال :
انتخاب
<?php
$query
$db->query("select * from tbl1");
while(
$user $db->fetch_array($query))
    echo (
$user['col2']);
    echo(
'<br>');
<?php
$options
= array(
"limit" => 1
$pid=1;
$query $db->simple_select("tbl1""*""col1='".$pid."'",  $options);
ثبت
<?php
$fields
= array(
"col1" => 1,
"col2" => $db->escape_string($_POST["newname"])
$db->insert_query("tbl1"$fields);
آپدیت
<?php
$update_sql
= array("col2" => "hamed");
$db->update_query("tbl1"$update_sql"col1='1'");
حذف
<?php
$db
->delete_query("tbl1""col1='' OR col1='1'");
حامد ارفعی
تریگرها در SQL server
آیا میدانید SQL ای
۰۶-فروردین-۱۳۹۲, ۱۴:۱۰:۰۸
تشکر شده توسط : hadikh73, babyy, aleas, Ghoghnus, aKaReZa75, javaweb
JSON
کتابخانه‌ی json :
(البته خود php چنین کتابخانه برای دیکد و انکود داره اما بعضو اوغات در بعضی از سرور ها یا فعال نیست یا ورژنشون قدیکه این به درد میخوره)
<?php
/* vim: set expandtab tabstop=4 shiftwidth=4 softtabstop=4: */
 * Converts to and from JSON format.
 * JSON (javascirpt Object Notation) is a lightweight data-interchange
 * format. It is easy for humans to read and write. It is easy for machines
 * to parse and generate. It is based on a subset of the javascirpt
 * Programming Language, Standard ECMA-262 3rd Edition - December 1999.
 * This feature can also be found in  Python. JSON is a text format that is
 * completely language independent but uses conventions that are familiar
 * to programmers of the C-family of languages, including C, C++, C#, Java,
 * javascirpt, Perl, TCL, and many others. These properties make JSON an
 * ideal data-interchange language.
 * This package provides a simple encoder and decoder for JSON notation. It
 * is intended for use with client-side javascirpt applications that make
 * use of HTTPRequest to perform server communication functions - data can
 * be encoded into JSON notation for use in a client-side javascirpt, or
 * decoded from incoming javascirpt requests. JSON format is native to
 * javascirpt, and can be directly eval()'ed with no further parsing
 * overhead
 * All strings should be in ASCII or UTF-8 format!
 * LICENSE: Redistribution and use in source and binary forms, with or
 * without modification, are permitted provided that the following
 * conditions are met: Redistributions of source code must retain the
 * above copyright notice, this list of conditions and the following
 * disclaimer. Redistributions in binary form must reproduce the above
 * copyright notice, this list of conditions and the following disclaimer
 * in the documentation and/or other materials provided with the
 * distribution.
 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
 * NO EVENT SHALL CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
 * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
 * TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
 * USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
 * DAMAGE.
 * @category
 * @package     Services_JSON
 * @author      Michal Migurski <mike-json@teczno.com>
 * @author      Matt Knapp <mdknapp[at]gmail[dot]com>
 * @author      Brett Stimmerman <brettstimmerman[at]gmail[dot]com>
 * @copyright   2005 Michal Migurski
 * @version     CVS: $Id: JSON.php,v 1.31 2006/06/28 05:54:17 migurski Exp $
 * @license     http://www.opensource.org/licenses/bsd-license.php
 * @link        http://pear.php.net/pepr/pepr-proposal-show.php?id=198
 * Marker constant for Services_JSON::decode(), used to flag stack state
define('SERVICES_JSON_SLICE',   1);
define('SERVICES_JSON_IN_STR',  2);
define('SERVICES_JSON_IN_ARR',  3);
define('SERVICES_JSON_IN_OBJ',  4);
define('SERVICES_JSON_IN_CMT'5);
 * Behavior switch for Services_JSON::decode()
define('SERVICES_JSON_LOOSE_TYPE'16);
define('SERVICES_JSON_SUPPRESS_ERRORS'32);
 * Brief example of use:
 * <code>
 * // create a new instance of Services_JSON
 * $json = new Services_JSON();
 * // convert a complexe value to JSON notation, and send it to the browser
 * $value = array('foo', 'bar', array(1, 2, 'baz'), array(3, array(4)));
 * $output = $json->encode($value);
 * print($output);
 * // prints: ["foo","bar",[1,2,"baz"],[3,[4]]]
 * // accept incoming POST data, assumed to be in JSON notation
 * $input = file_get_contents('php://input', 1000000);
 * $value = $json->decode($input);
 * </code>
class Services_JSON
    * constructs a new JSON instance
    * @param    int     $use    object behavior flags; combine with boolean-OR
    *                           possible values:
    *                           - SERVICES_JSON_LOOSE_TYPE:  loose typing.
    *                                   "{...}" syntax creates associative arrays
    *                                   instead of objects in decode().
    *                           - SERVICES_JSON_SUPPRESS_ERRORS:  error suppression.
    *                                   Values which can't be encoded (e.g. resources)
    *                                   appear as NULL instead of throwing errors.
    *                                   By default, a deeply-nested resource will
    *                                   bubble up with an error, so all return values
    *                                   from encode() should be checked with isError()
function Services_JSON($use 0)
$this->use $use;
    * convert a string from one UTF-16 char to one UTF-8 char
    * Normally should be handled by mb_convert_encoding, but
    * provides a slower PHP-only method for installations
    * that lack the multibye string extension.
    * @param    string  $utf16  UTF-16 character
    * @return   string  UTF-8 character
    * @access   private
function utf162utf8($utf16)
// oh please oh please oh please oh please oh please
if(function_exists('mb_convert_encoding')) {
            return
mb_convert_encoding($utf16'UTF-8''UTF-16');
$bytes = (ord($utf16{0}) << 8) | ord($utf16{1});
        switch(
true) {
            case ((
0x7F $bytes) == $bytes):
// this case should never be reached, because we are in ASCII range
                // see: http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
return chr(0x7F $bytes);
            case (
0x07FF $bytes) == $bytes:
// return a 2-byte UTF-8 character
return chr(0xC0 | (($bytes >> 6) & 0x1F))
chr(0x80 | ($bytes 0x3F));
            case (
0xFFFF $bytes) == $bytes:
// return a 3-byte UTF-8 character
return chr(0xE0 | (($bytes >> 12) & 0x0F))
chr(0x80 | (($bytes >> 6) & 0x3F))
// ignoring UTF-32 for now, sorry
return '';
    * convert a string from one UTF-8 char to one UTF-16 char
    * @param    string  $utf8   UTF-8 character
    * @return   string  UTF-16 character
    * @access   private
function utf82utf16($utf8)
            return
mb_convert_encoding($utf8'UTF-16''UTF-8');
        switch(
strlen($utf8)) {
            case
1:
return $utf8;
            case
2:
// return a UTF-16 character from a 2-byte UTF-8 char
return chr(0x07 & (ord($utf8{0}) >> 2))
chr((0xC0 & (ord($utf8{0}) << 6))
0x3F ord($utf8{1})));
            case
3:
// return a UTF-16 character from a 3-byte UTF-8 char
return chr((0xF0 & (ord($utf8{0}) << 4))
0x0F & (ord($utf8{1}) >> 2)))
chr((0xC0 & (ord($utf8{1}) << 6))
0x7F ord($utf8{2})));
return '';
    * encodes an arbitrary variable into JSON format
    * @param    mixed   $var    any number, boolean, string, array, or object to be encoded.
    *                           see argument 1 to Services_JSON() above for array-parsing behavior.
    *                           if var is a strng, note that encode() always expects it
    *                           to be in ASCII or UTF-8 format!
    * @return   mixed   JSON string representation of input var or an error if a problem occurs
    * @access   public
function encode($var)
        switch (
gettype($var)) {
            case
'boolean':
                return
$var 'true' 'false';
            case
'NULL':
                return
'null';
            case
'integer':
                return (int)
$var;
            case
'double':
            case
'float':
                return (float)
$var;
            case
'string':
// STRINGS ARE EXPECTED TO BE IN ASCII OR UTF-8 FORMAT
$ascii '';
$strlen_var strlen($var);
                * Iterate over every character in the string,
                * escaping with a slash or encoding to UTF-8 where necessary
for ($c 0$c $strlen_var; ++$c) {
$ord_var_c ord($var{$c});
                    switch (
true) {
                        case
$ord_var_c == 0x08:
$ascii .= '\b';
                            break;
                        case
$ord_var_c == 0x09:
$ascii .= '\t';
                            break;
                        case
$ord_var_c == 0x0A:
$ascii .= '\n';
                            break;
                        case
$ord_var_c == 0x0C:
$ascii .= '\f';
                            break;
                        case
$ord_var_c == 0x0D:
$ascii .= '\r';
                            break;
                        case
$ord_var_c == 0x22:
                        case
$ord_var_c == 0x2F:
                        case
$ord_var_c == 0x5C:
// double quote, slash, slosh
$ascii .= '\\'.$var{$c};
                            break;
                        case ((
$ord_var_c >= 0x20) && ($ord_var_c <= 0x7F)):
// characters U-00000000 - U-0000007F (same as ASCII)
$ascii .= $var{$c};
                            break;
                        case ((
$ord_var_c 0xE0) == 0xC0):
// characters U-00000080 - U-000007FF, mask 110XXXXX
                            // see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
$char pack('C*'$ord_var_cord($var{$c 1}));
$c += 1;
$utf16 $this->utf82utf16($char);
$ascii .= sprintf('\u%04s'bin2hex($utf16));
                            break;
                        case ((
$ord_var_c 0xF0) == 0xE0):
// characters U-00000800 - U-0000FFFF, mask 1110XXXX
$char pack('C*'$ord_var_c,
ord($var{$c 1}),
ord($var{$c 2}));
$c += 2;
                            break;
                        case ((
$ord_var_c 0xF8) == 0xF0):
// characters U-00010000 - U-001FFFFF, mask 11110XXX
ord($var{$c 1}),
ord($var{$c 2}),
ord($var{$c 3}));
$c += 3;
                            break;
                        case ((
$ord_var_c 0xFC) == 0xF8):
// characters U-00200000 - U-03FFFFFF, mask 111110XX
ord($var{$c 1}),
ord($var{$c 2}),
ord($var{$c 3}),
ord($var{$c 4}));
$c += 4;
                            break;
                        case ((
$ord_var_c 0xFE) == 0xFC):
// characters U-04000000 - U-7FFFFFFF, mask 1111110X
ord($var{$c 1}),
ord($var{$c 2}),
ord($var{$c 3}),
ord($var{$c 4}),
ord($var{$c 5}));
$c += 5;
                            break;
                return
'"'.$ascii.'"';
            case
'array':
                * As per JSON spec if any array key is not an integer
                * we must treat the the whole array as an object. We
                * also try to catch a sparsely populated associative
                * array with numeric keys here because some JS engines
                * will create an array with empty indexes up to
                * max_index which can cause memory issues and because
                * the keys, which may be relevant, will be remapped
                * otherwise.
                * As per the ECMA and JSON specification an object may
                * have any string as a property. Unfortunately due to
                * a hole in the ECMA specification if the key is a
                * ECMA reserved word or starts with a digit the
                * parameter is only accessible using ECMAScript's
                * bracket notation.
                // treat as a JSON object
if (is_array($var) && count($var) && (array_keys($var) !== range(0sizeof($var) - 1))) {
$properties array_map(array($this'name_value'),
array_keys($var),
array_values($var));
                    foreach(
$properties as $property) {
                        if(
Services_JSON::isError($property)) {
                            return
$property;
                    return
'{' join(','$properties) . '}';
// treat it like a regular array
$elements array_map(array($this'encode'), $var);
                foreach(
$elements as $element) {
                    if(
Services_JSON::isError($element)) {
                        return
$element;
                return
'[' join(','$elements) . ']';
            case
'object':
$vars get_object_vars($var);
array_keys($vars),
array_values($vars));
                foreach(
                    if(
                        return
$property;
                return
            default:
                return (
$this->use SERVICES_JSON_SUPPRESS_ERRORS)
'null'
: new Services_JSON_Error(gettype($var)." can not be encoded as JSON string");
    * array-walking function for use in generating JSON-formatted name-value pairs
    * @param    string  $name   name of key to use
    * @param    mixed   $value  reference to an array element to be encoded
    * @return   string  JSON-formatted name-value pair, like '"name":value'
    * @access   private
function name_value($name$value)
$encoded_value $this->encode($value);
        if(
Services_JSON::isError($encoded_value)) {
            return
$encoded_value;
        return
$this->encode(strval($name)) . ':' $encoded_value;
    * reduce a string by removing leading and trailing comments and whitespace
    * @param    $str    string      string value to strip of comments and whitespace
    * @return   string  string value stripped of comments and whitespace
    * @access   private
function reduce_string($str)
$str preg_replace(array(
// eliminate single line comments in '// ...' form
'#^\s*//(.+)$#m',
// eliminate multi-line comments in '/* ... */' form, at start of string
'#^\s*/\*(.+)\*/#Us',
// eliminate multi-line comments in '/* ... */' form, at end of string
'#/\*(.+)\*/\s*$#Us'
), ''$str);
// eliminate extraneous space
return trim($str);
    * decodes a JSON string into appropriate variable
    * @param    string  $str    JSON-formatted string
    * @return   mixed   number, boolean, string, array, or object
    *                   corresponding to given JSON input string.
    *                   See argument 1 to Services_JSON() above for object-output behavior.
    *                   Note that decode() always returns strings
    *                   in ASCII or UTF-8 format!
    * @access   public
function decode($str)
$str $this->reduce_string($str);
        switch (
strtolower($str)) {
            case
'true':
                return
true;
            case
'false':
                return
false;
            case
'null':
                return
null;
            default:
$m = array();
                if (
is_numeric($str)) {
// Lookie-loo, it's a number
                    // This would work on its own, but I'm trying to be
                    // good about returning integers where appropriate:
                    // return (float)$str;
                    // Return float or int, as appropriate
return ((float)$str == (integer)$str)
                        ? (integer)
$str
: (float)$str;
                } elseif (
preg_match('/^("|\').*(\1)$/s'$str$m) && $m[1] == $m[2]) {
// STRINGS RETURNED IN UTF-8 FORMAT
$delim substr($str01);
$chrs substr($str1, -1);
$utf8 '';
$strlen_chrs strlen($chrs);
                    for (
$c 0$c $strlen_chrs; ++$c) {
$substr_chrs_c_2 substr($chrs$c2);
$ord_chrs_c ord($chrs{$c});
                        switch (
true) {
                            case
$substr_chrs_c_2 == '\b':
$utf8 .= chr(0x08);
$c;
                                break;
                            case
$substr_chrs_c_2 == '\t':
$utf8 .= chr(0x09);
$c;
                                break;
                            case
$substr_chrs_c_2 == '\n':
$utf8 .= chr(0x0A);
$c;
                                break;
                            case
$substr_chrs_c_2 == '\f':
$utf8 .= chr(0x0C);
$c;
                                break;
                            case
$substr_chrs_c_2 == '\r':
$utf8 .= chr(0x0D);
$c;
                                break;
                            case
$substr_chrs_c_2 == '\\"':
                            case
$substr_chrs_c_2 == '\\\'':
                            case
$substr_chrs_c_2 == '\\\\':
                            case
$substr_chrs_c_2 == '\\/':
                                if ((
$delim == '"' && $substr_chrs_c_2 != '\\\'') ||
$delim == "'" && $substr_chrs_c_2 != '\\"')) {
$utf8 .= $chrs{++$c};
                                break;
                            case
preg_match('/\\\u[0-9A-F]{4}/i'substr($chrs$c6)):
// single, escaped unicode character
$utf16 chr(hexdec(substr($chrs, ($c 2), 2)))
chr(hexdec(substr($chrs, ($c 4), 2)));
$utf8 .= $this->utf162utf8($utf16);
$c += 5;
                                break;
                            case (
$ord_chrs_c >= 0x20) && ($ord_chrs_c <= 0x7F):
$utf8 .= $chrs{$c};
                                break;
                            case (
$ord_chrs_c 0xE0) == 0xC0:
                                //see http://www.cl.cam.ac.uk/~mgk25/unicode.html#utf-8
$utf8 .= substr($chrs$c2);
$c;
                                break;
                            case (
$ord_chrs_c 0xF0) == 0xE0:
$utf8 .= substr($chrs$c3);
$c += 2;
                                break;
                            case (
$ord_chrs_c 0xF8) == 0xF0:
$utf8 .= substr($chrs$c4);
$c += 3;
                                break;
                            case (
$ord_chrs_c 0xFC) == 0xF8:
$utf8 .= substr($chrs$c5);
$c += 4;
                                break;
                            case (
$ord_chrs_c 0xFE) == 0xFC:
$utf8 .= substr($chrs$c6);
$c += 5;
                                break;
                    return
$utf8;
                } elseif (
preg_match('/^\[.*\]$/s'$str) || preg_match('/^\{.*\}$/s'$str)) {
// array, or object notation
if ($str{0} == '[') {
$stk = array(SERVICES_JSON_IN_ARR);
$arr = array();
                    } else {
                        if (
$this->use SERVICES_JSON_LOOSE_TYPE) {
$stk = array(SERVICES_JSON_IN_OBJ);
$obj = array();
                        } else {
$obj = new stdClass();
array_push($stk, array('what'  => SERVICES_JSON_SLICE,
'where' => 0,
'delim' => false));
$chrs $this->reduce_string($chrs);
                    if (
$chrs == '') {
                        if (
reset($stk) == SERVICES_JSON_IN_ARR) {
                            return
$arr;
                        } else {
                            return
$obj;
//print("\nparsing {$chrs}\n");
                    for (
$c 0$c <= $strlen_chrs; ++$c) {
$top end($stk);
                        if ((
$c == $strlen_chrs) || (($chrs{$c} == ',') && ($top['what'] == SERVICES_JSON_SLICE))) {
// found a comma that is not inside a string, array, etc.,
                            // OR we've reached the end of the character list
$slice substr($chrs$top['where'], ($c $top['where']));
array_push($stk, array('what' => SERVICES_JSON_SLICE'where' => ($c 1), 'delim' => false));
//print("Found split at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
if (reset($stk) == SERVICES_JSON_IN_ARR) {
// we are in an array, so just push an element onto the stack
array_push($arr$this->decode($slice));
                            } elseif (
reset($stk) == SERVICES_JSON_IN_OBJ) {
// we are in an object, so figure
                                // out the property name and set an
                                // element in an associative array,
                                // for now
$parts = array();
                                if (
preg_match('/^\s*(["\'].*[^\\\]["\'])\s*:\s*(\S.*),?$/Uis'$slice$parts)) {
// "name":value pair
$key $this->decode($parts[1]);
$val $this->decode($parts[2]);
                                    if (
$obj[$key] = $val;
                                    } else {
$obj->$key $val;
                                } elseif (
preg_match('/^\s*(\w+)\s*:\s*(\S.*),?$/Uis'$slice$parts)) {
// name:value pair, where name is unquoted
$key $parts[1];
                                    if (
$obj[$key] = $val;
                                    } else {
$obj->$key $val;
                        } elseif (((
$chrs{$c} == '"') || ($chrs{$c} == "'")) && ($top['what'] != SERVICES_JSON_IN_STR)) {
// found a quote, and we are not inside a string
array_push($stk, array('what' => SERVICES_JSON_IN_STR'where' => $c'delim' => $chrs{$c}));
//print("Found start of string at {$c}\n");
} elseif (($chrs{$c} == $top['delim']) &&
$top['what'] == SERVICES_JSON_IN_STR) &&
strlen(substr($chrs0$c)) - strlen(rtrim(substr($chrs0$c), '\\'))) % != 1)) {
// found a quote, we're in a string, and it's not escaped
                            // we know that it's not escaped becase there is _not_ an
                            // odd number of backslashes at the end of the string so far
array_pop($stk);
//print("Found end of string at {$c}: ".substr($chrs, $top['where'], (1 + 1 + $c - $top['where']))."\n");
} elseif (($chrs{$c} == '[') &&
in_array($top['what'], array(SERVICES_JSON_SLICESERVICES_JSON_IN_ARRSERVICES_JSON_IN_OBJ))) {
// found a left-bracket, and we are in an array, object, or slice
array_push($stk, array('what' => SERVICES_JSON_IN_ARR'where' => $c'delim' => false));
//print("Found start of array at {$c}\n");
} elseif (($chrs{$c} == ']') && ($top['what'] == SERVICES_JSON_IN_ARR)) {
// found a right-bracket, and we're in an array
array_pop($stk);
//print("Found end of array at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
} elseif (($chrs{$c} == '{') &&
// found a left-brace, and we are in an array, object, or slice
array_push($stk, array('what' => SERVICES_JSON_IN_OBJ'where' => $c'delim' => false));
//print("Found start of object at {$c}\n");
} elseif (($chrs{$c} == '}') && ($top['what'] == SERVICES_JSON_IN_OBJ)) {
// found a right-brace, and we're in an object
array_pop($stk);
//print("Found end of object at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
} elseif (($substr_chrs_c_2 == '/*') &&
// found a comment start, and we are in an array, object, or slice
array_push($stk, array('what' => SERVICES_JSON_IN_CMT'where' => $c'delim' => false));
$c++;
//print("Found start of comment at {$c}\n");
} elseif (($substr_chrs_c_2 == '*/') && ($top['what'] == SERVICES_JSON_IN_CMT)) {
// found a comment end, and we're in one now
array_pop($stk);
$c++;
                            for (
$i $top['where']; $i <= $c; ++$i)
$chrs substr_replace($chrs' '$i1);
//print("Found end of comment at {$c}: ".substr($chrs, $top['where'], (1 + $c - $top['where']))."\n");
                    if (
                        return
$arr;
                    } elseif (
                        return
$obj;
     * @todo Ultimately, this should just call PEAR::isError()
function isError($data$code null)
        if (
class_exists('pear')) {
            return
PEAR::isError($data$code);
        } elseif (
is_object($data) && (get_class($data) == 'services_json_error' ||
is_subclass_of($data'services_json_error'))) {
            return
true;
        return
false;
if (
class_exists('PEAR_Error')) {
    class
Services_JSON_Error extends PEAR_Error
        function
Services_JSON_Error($message 'unknown error'$code null,
$mode null$options null$userinfo null)
parent::PEAR_Error($message$code$mode$options$userinfo);
} else {
     * @todo Ultimately, this class shall be descended from PEAR_Error
class Services_JSON_Error
        function
مثال:
$json_obj  = new Services_JSON();
$json_echo $json_obj->encode($json);
$json_echo $json_obj->decode($json);
۰۶-فروردین-۱۳۹۲, ۲۰:۱۸:۳۲
تشکر شده توسط : hadikh73, Ghoghnus, aKaReZa75, javaweb
babyy جان کلاس اون اداپتر رو هم لطف کنی عالی میشه
۰۸-فروردین-۱۳۹۲, ۱۷:۲۶:۲۶
تشکر شده توسط : babyy, aKaReZa75
(۰۸-فروردین-۱۳۹۲, ۱۷:۲۶:۲۶)lord_viper نوشته است: babyy جان کلاس اون اداپتر رو هم لطف کنی عالی میشه
چشم لرد گرامی جان Biggrin
فقط اینکه من دسترسی ندارم پست اولی رو ویرایش کنم اینو بزارم توش؛
هرکی میتونه اینکارو کنه متشکر میشم
.zip   database-adapter-2013-03-17.zip (اندازه: 7.35 KB / تعداد دفعات دریافت: 77)
۰۸-فروردین-۱۳۹۲, ۲۲:۳۱:۱۷
تشکر شده توسط : omid_phoenix, lord_viper, aKaReZa75, javaweb
hamed_Arfaee آفلاین
ارسال‌ها: 1,334
موضوع‌ها: 231
تشکرها : 1250
(۰۸-فروردین-۱۳۹۲, ۲۲:۳۱:۱۷)babyy نوشته است: فقط اینکه من دسترسی ندارم پست اولی رو ویرایش کنم اینو بزارم توش؛
منم نتونستم پیوستتو اونجا لینک بدم بجاش هر دو کلاس رو اونجا کپی کردم :)
کلاس تقویم شمسی :
[تصویر:  calendar-1.png]
لینک
محض احتیاط اینجاهم آپلود میکنم
.zip   jalali-date-2011-04-02.zip (اندازه: 103.58 KB / تعداد دفعات دریافت: 91)
حامد ارفعی
آیا میدانید SQL ای
۰۹-فروردین-۱۳۹۲, ۱۳:۰۴:۵۸
تشکر شده توسط : omid_phoenix, babyy, lord_viper, hadikh73, aKaReZa75, javaweb
کلاسی برای session
مثال:
// Require the class file
require('SmartSession.php');
// All methods should be called before send anything to browser (any echo).
// You do not need to call session_start for any operation.
// You could configure session before any operation (call session_set_cookie_params or session_name).
// Example how to set a value to session
SmartSession::getInstance()->set('example'123);
// Example how to get a value from session by key
$value SmartSession::getInstance()->get('example');
// Example how to check whether a key exists
$exists SmartSession::getInstance()->has('example');
// Example how to unset a value from session by key
SmartSession::getInstance()->del('example');
// Example how to persist session data
// Note: You can get/set/del session data after calling saveSession,
// but it is better if you call saveSession after all manipulations.
SmartSession::getInstance()->saveSession();
// Example how to clear session data
SmartSession::getInstance()->clearSession();
۲۴-اردیبهشت-۱۳۹۲, ۲۰:۰۴:۳۷
تشکر شده توسط : lord_viper, omid_phoenix, aKaReZa75, javaweb, rochelleup1
مشخص کردن اطلاعات آیپی (کشور شهر و ...)
در واقع همون GEOIP رو میتونید توسط این سایت ببینید!
در مورد GEOIP اینحا توضیحات دادم
این کلاس با استفاده از این سایت اطلاعات رو میگیره و نشون میده!
http://www.freegeoip.net/xml/
در این حالت اطلاعات آیپی که دارین رو نشون میده؛ و اگه اطلاعات واسه هر آیپی دیگه‌ای میخوایین رو؛ به این صورت عمل میکنیم:
http://www.freegeoip.net/xml/67.205.76.146
<?php
/*          This class handles netGeo location actions            */
/*            All that you need to do is use the function            */
/*            called    getNetGeo(), the function can take an Ip    */
/*            as a parameter or if left out, the service will        */
/*            use your Ip.                                        */
/*            Examples are in the bottom of this file                */
/*          Copyright: Frederik Yssing - Pinch                    */
/*          frederik.yssing@pinchlabs.dk                        */
class netGeo{
    public
$Ip '0.0.0.0';
    public
$CountryCode '';
    public
$CountryName '';
    public
$RegionCode '';
    public
$RegionName '';
    public
$City '';
    public
$ZipCode '';
    public
$Latitude '';
    public
$Longitude '';
    public
$MetroCode '';
    public
$AreaCode '';
    public function
getNetGeo($ip 0){
        if(
$ip){
$url 'http://freegeoip.net/xml/'.$ip;
        } else {
$url 'http://freegeoip.net/xml/';
$postdata http_build_query(
// just incase we later need to post parameters
$opts = array('http' =>
            array(
'method' => 'POST',
'header' => 'Content-type: application/x-www-form-urlencoded',
'content' => $postdata
        try{
$context stream_context_create($opts);
$result file_get_contents($urlfalse$context);
            if(!
$result){
                throw new
Exception('Could not get a response from freegeoip.net');
                return
false;
            } else {
self::pickDataFromXML($result);
        catch (
Exception $e){
            echo
'Caught exception: '$e->getMessage();
        return
true;
    public function
pickDataFromXML($file){
$HisVurderingNum 0;
$SalgsPriserNum 0;
$XMLFile '';
$success 0;
        try{
$XMLFile simplexml_load_string($file);
            if(!
$XMLFile){
                throw new
Exception('Could not load XML file!');
            } else {
$this->Ip $XMLFile->Ip;
$this->CountryCode $XMLFile->CountryCode;
$this->CountryName $XMLFile->CountryName;
$this->RegionCode $XMLFile->RegionCode;
$this->RegionName $XMLFile->RegionName;
$this->City $XMLFile->City;
$this->ZipCode $XMLFile->ZipCode;
$this->Latitude $XMLFile->Latitude;
$this->Longitude $XMLFile->Longitude;
$this->MetroCode $XMLFile->MetroCode;
$this->AreaCode $XMLFile->AreaCode;
$success 1;
unlink($XMLFile);
        catch (
Exception $e){
            echo
        return
$success;
$netGeo = new netGeo();
// Using you local IP
$netGeo->getNetGeo($_SERVER['REMOTE_ADDR']);
echo
$netGeo->Ip.'<br />';
echo
$netGeo->CountryCode.'<br />';
echo
$netGeo->CountryName.'<br />';
echo
$netGeo->RegionCode.'<br />';
echo
$netGeo->RegionName.'<br />';
echo
$netGeo->City.'<br />';
echo
$netGeo->ZipCode.'<br />';
echo
$netGeo->Latitude.'<br />';
echo
$netGeo->Longitude.'<br />';
echo
$netGeo->MetroCode.'<br />';
echo
$netGeo->AreaCode.'<br />';
//Letting the service find the proper Ip
$netGeo->getNetGeo();
echo
echo
echo
echo
echo
echo
echo
echo
echo
echo
echo
منبع
(آخرین ویرایش در این ارسال: ۲۷-اردیبهشت-۱۳۹۲, ۱۱:۴۶:۰۷، توسط babyy.)
۲۷-اردیبهشت-۱۳۹۲, ۱۱:۴۵:۰۹
تشکر شده توسط : omid_phoenix, aKaReZa75, javaweb, lord_viper, hamed_Arfaee, rochelleup1
چک کردن وجود دامین با استفاده از whois
کلاس:
<?PHP
 * @category ServerTools
 * @package Whois
 * @author Peter Reza Moghaddam <r324.moghaddam@gmail.com>
 * @author Peter Schmalfeldt <peter@manifestinteractive.com>
 * @link http://www.moghaddam24.ir
 * @link http://www.manifestinteractive.com
 * Begin Document
class Whois
     * fsockopen port
     * @var    string
     * @access private
private $port 43;
     * fsockopen Error Number
     * @var    string
     * @access private
private $errno;
     * fsockopen Error String
     * @var    string
     * @access private
private $errstr;
     * fsockopen Time Out
     * @var    string
     * @access private
private $timeout 10;
     * Selected Server from $whoisservers based on TLD from $domain
     * @var    string
     * @access private
private $whoisserver;
     * Available Whois Servers
     * @var    array
     * @access private
private $whoisservers = array(
"ac" => "whois.nic.ac",
"ae" => "whois.nic.ae",
"aero" => "whois.aero",
"af" => "whois.nic.af",
"ag" => "whois.nic.ag",
"al" => "whois.ripe.net",
"am" => "whois.amnic.net",
"arpa" => "whois.iana.org",
"as" => "whois.nic.as",
"asia" => "whois.nic.asia",
"at" => "whois.nic.at",
"au" => "whois.aunic.net",
"az" => "whois.ripe.net",
"ba" => "whois.ripe.net",
"be" => "whois.dns.be",
"bg" => "whois.register.bg",
"bi" => "whois.nic.bi",
"biz" => "whois.biz",
"bj" => "whois.nic.bj",
"br" => "whois.registro.br",
"bt" => "whois.netnames.net",
"by" => "whois.ripe.net",
"bz" => "whois.belizenic.bz",
"ca" => "whois.cira.ca",
"cat" => "whois.cat",
"cc" => "whois.nic.cc",
"cd" => "whois.nic.cd",
"ch" => "whois.nic.ch",
"ci" => "whois.nic.ci",
"ck" => "whois.nic.ck",
"cl" => "whois.nic.cl",
"cn" => "whois.cnnic.net.cn",
"com" => "whois.verisign-grs.com",
"coop" => "whois.nic.coop",
"cx" => "whois.nic.cx",
"cy" => "whois.ripe.net",
"cz" => "whois.nic.cz",
"de" => "whois.denic.de",
"dk" => "whois.dk-hostmaster.dk",
"dm" => "whois.nic.cx",
"dz" => "whois.ripe.net",
"edu" => "whois.educause.edu",
"ee" => "whois.eenet.ee",
"eg" => "whois.ripe.net",
"es" => "whois.ripe.net",
"eu" => "whois.eu",
"fi" => "whois.ficora.fi",
"fo" => "whois.ripe.net",
"fr" => "whois.nic.fr",
"gb" => "whois.ripe.net",
"gd" => "whois.adamsnames.com",
"ge" => "whois.ripe.net",
"gg" => "whois.channelisles.net",
"gi" => "whois2.afilias-grs.net",
"gl" => "whois.ripe.net",
"gm" => "whois.ripe.net",
"gov" => "whois.nic.gov",
"gr" => "whois.ripe.net",
"gs" => "whois.nic.gs",
"gw" => "whois.nic.gw",
"gy" => "whois.registry.gy",
"hk" => "whois.hkirc.hk",
"hm" => "whois.registry.hm",
"hn" => "whois2.afilias-grs.net",
"hr" => "whois.ripe.net",
"hu" => "whois.nic.hu",
"ie" => "whois.domainregistry.ie",
"il" => "whois.isoc.org.il",
"in" => "whois.inregistry.net",
"info" => "whois.afilias.info",
"int" => "whois.iana.org",
"io" => "whois.nic.io",
"iq" => "vrx.net",
"ir" => "whois.nic.ir",
"is" => "whois.isnic.is",
"it" => "whois.nic.it",
"je" => "whois.channelisles.net",
"jobs" => "jobswhois.verisign-grs.com",
"jp" => "whois.jprs.jp",
"ke" => "whois.kenic.or.ke",
"kg" => "www.domain.kg",
"ki" => "whois.nic.ki",
"kr" => "whois.nic.or.kr",
"kz" => "whois.nic.kz",
"la" => "whois.nic.la",
"li" => "whois.nic.li",
"lt" => "whois.domreg.lt",
"lu" => "whois.dns.lu",
"lv" => "whois.nic.lv",
"ly" => "whois.nic.ly",
"ma" => "whois.iam.net.ma",
"mc" => "whois.ripe.net",
"md" => "whois.ripe.net",
"me" => "whois.meregistry.net",
"mg" => "whois.nic.mg",
"mil" => "whois.nic.mil",
"mn" => "whois.nic.mn",
"mobi" => "whois.dotmobiregistry.net",
"ms" => "whois.adamsnames.tc",
"mt" => "whois.ripe.net",
"mu" => "whois.nic.mu",
"museum" => "whois.museum",
"mx" => "whois.nic.mx",
"my" => "whois.mynic.net.my",
"na" => "whois.na-nic.com.na",
"name" => "whois.nic.name",
"net" => "whois.verisign-grs.net",
"nf" => "whois.nic.nf",
"nl" => "whois.domain-registry.nl",
"no" => "whois.norid.no",
"nu" => "whois.nic.nu",
"nz" => "whois.srs.net.nz",
"org" => "whois.pir.org",
"pl" => "whois.dns.pl",
"pm" => "whois.nic.pm",
"pr" => "whois.uprr.pr",
"pro" => "whois.registrypro.pro",
"pt" => "whois.dns.pt",
"re" => "whois.nic.re",
"ro" => "whois.rotld.ro",
"ru" => "whois.ripn.net",
"sa" => "whois.nic.net.sa",
"sb" => "whois.nic.net.sb",
"sc" => "whois2.afilias-grs.net",
"se" => "whois.iis.se",
"sg" => "whois.nic.net.sg",
"sh" => "whois.nic.sh",
"si" => "whois.arnes.si",
"sk" => "whois.ripe.net",
"sm" => "whois.ripe.net",
"st" => "whois.nic.st",
"su" => "whois.ripn.net",
"tc" => "whois.adamsnames.tc",
"tel" => "whois.nic.tel",
"tf" => "whois.nic.tf",
"th" => "whois.thnic.net",
"tj" => "whois.nic.tj",
"tk" => "whois.dot.tk",
"tl" => "whois.nic.tl",
"tm" => "whois.nic.tm",
"tn" => "whois.ripe.net",
"to" => "whois.tonic.to",
"tp" => "whois.nic.tl",
"tr" => "whois.nic.tr",
"travel" => "whois.nic.travel",
"tv" => "tvwhois.verisign-grs.com",
"tw" => "whois.twnic.net.tw",
"ua" => "whois.net.ua",
"ug" => "whois.co.ug",
"uk" => "whois.nic.uk",
"us" => "whois.nic.us",
"uy" => "nic.uy",
"uz" => "whois.cctld.uz",
"va" => "whois.ripe.net",
"vc" => "whois2.afilias-grs.net",
"ve" => "whois.nic.ve",
"vg" => "whois.adamsnames.tc",
"wf" => "whois.nic.wf",
"ws" => "whois.website.ws",
"yt" => "whois.nic.yt",
"yu" => "whois.ripe.net");
     * Domain Name (URL or IP Address)
     * @var    string
     * @access public
public $domain;
     * Full URL
     * @var    string
     * @access public
public $url;
     * Domain Array containing Domain and TLD
     * @var    array
     * @access public
public $domainarray;
     * Returned Whois Text
     * @var    string
     * @access public
public $data;
     * Constructor
     * Create Google Translate Object and Convert $string
     * <code>
     * <?php
     * $whois = new Whois("example.com");
     * echo $whois->domain;                    // 'example.com'
     * echo $whois->url;                     // 'http://example.com'
     * echo $whois->domainarray[0];            // 'com'
     * echo $whois->domainarray[1];            // 'example'
     * echo $whois->data;                     // [ ... whois data ... ]
     * $whoisFull = new Whois("http://www.example.com");
     * echo $whoisFull->domain;                // 'example.com'
     * echo $whoisFull->url;                 // 'http://www.example.com'
     * echo $whoisFull->domainarray[0];        // 'com'
     * echo $whoisFull->domainarray[1];        // 'example'
     * echo $whoisFull->data;                 // [ ... whois data ... ]
     * $whoisIP = new Whois("123.45.678.90");
     * echo $whoisIP->domain;                // '123.45.678.90'
     * echo $whoisIP->url;                     // 'http://123.45.678.90'
     * echo $whoisIP->domainarray[0];        // NULL
     * echo $whoisIP->domainarray[1];        // NULL
     * echo $whoisIP->data;                 // [ ... whois data ... ]
     * </code>
     * @param     string $domain URL or IP Address
     * @access     public
function checkDomain($domain)
$this->domain $domain;
$this->domain rtrim($this->domain"/");
$this->domain preg_replace('/http:\/\//'''$this->domain);
$this->url = (substr($this->domain07) != 'http://') ? 'http://' $this->
domain $this->domain;
        if (!
preg_match('/(\d+).(\d+).(\d+).(\d+)/'$this->domain)) {
$this->domainarray split("\."$this->domain);
$this->domainarray array_reverse($this->domainarray);
$this->domain $this->domainarray[1] . '.' $this->domainarray[0];
        if (
strlen($this->domain) > 0) {
            foreach (
$this->whoisservers as $tld => $server) {
                if (
substr($this->domain, -strlen($tld)) == $tld) {
$this->whoisserver $server;
                    break;
            if (!
$this->whoisserver) {
                if (
$this->whoisserver "whois.arin.net";
                else
$this->data "Error: No appropriate Whois server found for {$this->domain} domain!";
            if (
$result $this->queryServer()) {
preg_match("/Whois Server: (.*)/"$result$matches);
$secondary $matches[1];
                if (
$secondary) {
$this->whoisserver $secondary;
$result $this->queryServer();
$this->data $result;
            } else {
$this->data "Error: No results retrieved from $whoisserver server for {$this->domain} domain!";
     * Query Selected Whois Server
     * @access private
private function queryServer()
$out "";
$fp = @fsockopen($this->whoisserver$this->port$this->errno$this->errstr$this->
timeout);
fputs($fp$this->domain "\r\n");
        while (!
feof($fp))
$out .= fgets($fp);
fclose($fp);
        if (
strlen($out) > 0)
            return
$out;
        else
            return
false;
     * Simple Whois With Details
function checkExist()
//compare what has been returned by the server
if (eregi("Can't get information"$this->data) || eregi("No entries found"$this->data) ||
eregi("NOT FOUND"$this->data) || eregi("No match"$this->data)) {
            return
0;
        } else {
            return
nl2br($this->data);
     * Simple Whois WithOut Details
function existOrNo()
            return
0;
        } else {
            return
1;
مثال:
<?php
 * @Author      Reza Moghaddam
 * @URL         moghaddam24.ir
 * @Email       r324.moghaddam@gmail.com
include_once 'whois.class.php';
$whois = new Whois();
$whois->checkDomain("your-domain.com");
if ( $whois->checkExist() ){
    echo $whois->checkExist();
}else{
    echo "Available For Register";
if ( $whois->existOrNo() ){
    echo
"Dont Available";
}else{
    echo
منبع
۲۷-اردیبهشت-۱۳۹۲, ۱۲:۵۳:۱۹
تشکر شده توسط : omid_phoenix, aKaReZa75, lord_viper, javaweb, hamed_Arfaee
برای کار با ftp :
کلاس :
<?php
** class FTP
** rev 2013-08-07 Mark Kintigh
** Common class to interface with an FTP server
** ______________________________________________________________________________
** $this->server == FTP server's name
** $this->logon_user == User name for the FTP logon
** $this->logon_pswd == User name's password for the FTP logon
** $this->transfer_mode == Current/default transfer mode for FTP file transfers
** $this->lconnected() == Returns the current status of the FTP connection
** $this->connect(["server", 'user", "password]) == Returns if a connection to
**      the FTP server was successful.  Optionally, a new server, user name, and
**      password can be given
** $this->pasivemode(<true/false>) == Set the passive mode for the FTP connection;
**      true = passive, false = active.
** $this->close() == Attempts to close the connection to the FTP server
** $this->makedir("directory") == Attempts to create a directory on the remote
**      FTP host.  This will create an entire path of folders if necessary.
**      Returns the success or failure of the attempt.
** $this->lpwd() == Returns the local, present working directory
** $this->pwd() == Returns the remote (FTP), present working directory
** $this->lcd("directory") == Attempts to change the local directory; returns the
**      success or failure
** $this->cd("directory") == Attempts to change the remote directory; returns the
** $this->isdir("directory") == Returns if the given name is a directory or not;
**      this can be the full path or relative to the present working directory
** $this->dir(["new directory"]) == Returns an array of file and folder names
**      from the FTP server (empty array if error/not connected/etc).  Optionally
**      a new folder path can be given
** $this->dirfind($filespecs) == Returns an array of files and folder names from
**      the FTP server that match the given file specifications (empty array if
**      error/not connected/etc)
** $this->dirdetails(["directory"]) == Returns an array of arrays with details
**      about each of the directory entries.  The subarray contains the following:
**           [x]['name'] == File/directory name for this entry
**           [x]['dir'] == T/F; true = subdirectory, false = file
**           [x]['size'] == Human readable version of the file size (blank if
**                 directory)
**           [x]['chmod'] == Unix permissions (blank if Windows server)
**           [x]['date'] == Date of the file
**           [x]['raw'] == the raw array of information that the above was built
**                 from
**      Optionally a new folder path can be given
** $this->get($filename[,$mode=NULL]) == Attempt to download a file.  The file
**      name can contain a path as well.  Optionally the transfer mode is give.
** $this->mget($filespecs[, $mode=NULL]) == Attempt to download a group of files
**      from server.  The file  name can contain a path as well.  Optionally the
**      transfer mode is give.
** $this->getdir($path[, $recursive=true[, $mode=NULL]]) == Attempts to download
**      an entire directory from an FTP server.  Optionally you can download just
**      the files in the first folder or (default) the entire tree.  You can also
**      change/set the download mode as well.
** $this->getdirfilter($path[[[, $fliter="*"[, $recursive=true[, $mode=NULL]]])
**      Attempts to download a list of files matching a given pattern from a
**      directory from an FTP server.  Optionally you can download just the files
**      in the first folder or (default) the entire tree.  You can also change/set
**      the download mode as well.
** $this->put($filename[, $dest=""[,$mode=NULL]]) == Attempts to upload a single
**      file to the FTP server.  Optionally it will upload it in a destination
**      directory.  You can also change/set the upload mode as well.
** $this->mput($filespecs="*"[, $dest=""[, $mode=NULL]]) == Attempts to upload a
**      file(s) to the FTP server.  Optionally it will upload it in a destination
** $this->putdir($srcdir[, $destdir=""[, $mode=NULL]]) == Attempts to upload a
**      folder to the FTP server.  Optionally it will upload it in a destination
** $this->del($file) == Attempts to delete a file on the FTP host.  Returns
**      success or failure.
** $this->deldir($dir) == Attempts to delete a folder on the FTP host.  Returns
** $this->exists($path) == Checks to see if a file exists.  Returns T/F.
** $this->existsdir($path)  == Checks to see if a file or folder exists.  Returns
**      T/F.
** $this->movetoserver($file[, $dest=""[, $mode=NULL]]) == Combines the tasks of
**      uploading a file, verifying it was uploading, then removing it from the
**      local server.  Returns success or failure.
** $this->movefromserver($file[, $mode=NULL]) == Combines the tasks of downloading
**      a file, verifying it was downloaded, then removing it from the FTP server.
**      Returns success or failure.
** $this->rename($oldname, $newname) == Will attempt to rename the given file on
**      the remote host to a new name.  Returns success / failure.
** $this->chmod($mode, $filename) == Will attempt to set permissions on a file on
**      the host.  Returns success or failure.  This ONLY works on a Linux/UNIX
**      host because it call the external "chmod" command to set these values.
**      Limitations on how the mode is passed depends on the FTP host; best bet is
**      to use the 3 octal numbers instead of something like "u+rw,g+w,o+r".
** $this->translatecommand($commandline) == Will attempt to translate the string
**      into the operation for this class and execute it -- used for translating
**      scripts.  Returns success or failure.
class FTP {
    // Public variables
public $server "";
    public
$logon_user "";
    public
$logon_pswd "";
    public
$transfer_mode FTP_BINARY;
    // Private, global variables
private $lconnected false;
    private
$conn;
    private
$port 21;
public function __construct($newserver=""$newuser=""$newpswd="") {
$this->server trim($newserver);
$this->logon_user trim($newuser);
$this->logon_pswd trim($newpswd);
$this->checkforport();
private function checkforport() {
        // Check the set server's name for a port number (standard
        // "ftp.some.com:2121" configuration)
if(strpos($this->server":")>-1) {
$a split(":"$this->server2);
$this->server trim($a[0]);
$this->port intval($a[1])>intval($a[1]) : 21;
            unset(
$a);
private function connected() {
        // Return the current status of the FTP connection
return $this->lconnected;
public function connect($newserver=""$newuser=""$newpswd="") {
        // Attempt to connect to an FTP server
        // __________
        // If the 3 optional parameters are all set, change to the new server
if(strlen(trim($newserver))>&& strlen(trim($newuser))>&&
strlen(trim($newpswd))>0) {
        // If there is already an open connection close it
if($this->lconnected$this->close();
        // Try to connect to the FTP server and then try to login
$this->conn ftp_connect($this->server$this->port);
$result ftp_login($this->conn$this->logon_user$this->logon_pswd);
        if(!
$this->conn || !$result) {
$this->lconnected false;
            return
false;
        } else {
$this->lconnected true;
            return
true;
public function pasivemode($isPassive=true) {
        // Set the passive mode for the connection
if(!$this->lconnected) return false;
        return
ftp_pasv($this->conn$isPassive);
public function close() {
        // If there is a connection open close it
if($this->conn) {
ftp_close($this->conn);
public function makedir($dirname) {
        if(!
$pwd $this->pwd();
$cur $pwd;
        // Determine if this is just creating one folder or a series of folders
$temp str_replace("\\","/",$dirname);
        // If the path start with the root, then change out the path to root
if(substr($temp,0,1)=="/") {
$temp substr($temp,1);
$this->cd("/");
$cur "/";
        if(
strpos($temp,"/")>-1) {
            // Has a full path, so verify that the folders exist or create the
            // desired folder
$ret true;
            // For each of the parts
foreach(split("/",$temp) as $part) {
                // Add this part to the current path
$cur .= "/$part";
                // Try to change to the folder
if(!$this->cd($cur)) {
                    // It did not change, so try to create the folder
if(ftp_mkdir($this->conn$cur)) {
                        // Successfully created the folder, so change to it
$this->cd($cur);
                    } else {
                        // Fail the creation of the path
$ret false;
            // Return to the original folder and return the results
$this->cd($pwd);
            return
$ret;
        } else {
            // Just try to create the folder
return ftp_mkdir($this->conn$dirname);
public function lpwd() {
        // Return local present working directory
return getcwd();
public function pwd() {
        // Return the remote present working directory
if(!$this->lconnected) return "";
        return
ftp_pwd($this->conn);
public function lcd($ldir) {
        // Local change directory; return success/faliure
if(is_dir($ldir)) {
            return @
chdir($ldir);
        } else {
            return
false;
public function cd($rdir) {
        // Change the remote directory, if possible, and return
        // success/failure
        return @
ftp_chdir($this->conn$rdir);
public function isdir($foldername) {
        // Check to see if the given folder name is a directory.  If
        // it fails the first time, try again after adding the present
        // working directory
$pwd $this->pwd();
$ret $this->cd($foldername);
        if(!
$ret) {
$tmp "$pwd/$foldername";
$this->cd($pwd);
        return
$ret;
public function dir($newdir="") {
        if(!
$this->lconnected) return array();
$pwd $this->pwd();
        // If the user wants a different directory, try to change to
        // that directory
if(strlen(trim($newdir))>0) {
            if(
$this->cd($newdir)) {
$pwd $this->pwd();
$list ftp_nlist($this->conn$pwd);
        // Strip the path off of the file names
for($x=0$x<count($list); $x++) {
$list[$x] = substr($list[$x], strlen($pwd));
            // Remove any leading "\" and "/" characters
if(strcmp(substr($list[$x],0,1),"\\")==0)
$list[$x] = substr($list[$x],1);
            if(
strcmp(substr($list[$x],0,1),"/")==0)
        return
$list;
public function dirfilter($filespecs="*.*") {
        if(!
$pwd $this->pwd();
$list = @ftp_nlist($this->conn"$pwd/" trim($filespecs));
            if(
        return
$list;
public function dirdetails($newdir="") {
        if(!
$pwd $this->pwd();
        // that directory
            if(
$pwd $this->pwd();
$list ftp_rawlist($this->conn$this->pwd(), false);
$ret = array();
        if(empty(
$list)) return $ret;
        foreach(
$list as $fil) {
$info = array(
'name'=>'',
'dir'=>false,
'size'=>'',
'chmod'=>'',
'date'=>'',
'raw'=>NULL
            if(
strpos("0123456789",substr($fil,0,1))>-1) {
                // Windows FTP host
$split preg_split("/[\s]+/"$fil);
                if(
count($split)>3) {
$split preg_split("/[\s]+/"$fil4);
$info['name'] = str_replace(":"""trim($split[3]));
                    if(
strcmp("<DIR>",trim($split[2]))==0) {
$info['dir'] = true;
                    } else {
$info['dir'] = false;
$info['size'] = $this->byteconvert($split[2]);
$info['date'] = strtotime(str_replace("-","/""{$split[0]} "
str_replace("P"," P",
str_replace("A"," A",strtoupper($split[1])))));
$info['raw'] = $split;
            } elseif(
strlen(trim($fil))>0) {
                // UNIX FTP host
                if(
count($split)>8) {
$split preg_split("/[\s]+/"$fil9);
$info['name'] = trim($split[8]);
$info['dir'] = ($split[0]{0}=='d');
$info['size'] = $this->byteconvert($split[4]);
$info['chmod'] = $this->chmodnum($split[0]);
$info['date'] = strtotime("{$split[6]} {$split[5]} {$split[7]}");
            if(
strlen(trim($info['name']))>0) {
array_push($ret,$info);
            unset(
$info);
return $ret;
private function stringMatchWithWildcard($source,$pattern) {
$pattern preg_quote($pattern,'/');
$pattern str_replace'\*' '.*'$pattern);
        return
preg_match'/^' $pattern '$/i' $source );
public function dirdetailsfilter($filespecs="*"$newdir="") {
        if(!
$pwd $this->pwd();
        // that directory
            if(
$pwd $this->pwd();
$ret = array();
        if(empty(
        foreach(
$list as $fil) {
$info = array(
'name'=>'',
'dir'=>false,
'size'=>'',
'chmod'=>'',
'date'=>'',
'raw'=>NULL
            if(
                // Windows FTP host
                if(
count($split)>3) {
                    if(
                    } else {
            } elseif(
                // UNIX FTP host
                if(
count($split)>8) {
            if(
$this->stringMatchWithWildcard(trim($info['name']), $filespecs)) {
return $ret;
private function byteconvert($bytes) {
$symbol = array('B''KB''MB''GB''TB''PB''EB''ZB''YB');
$exp floorlog($bytes) / log(1024) );
        return @
sprintf'%.2f ' $symbol$exp ],
$bytes pow(1024floor($exp))) );
private function chmodnum($chmod) {
$trans = array('-' => '0''r' => '4''w' => '2''x' => '1');
$chmod substr(strtr($chmod$trans), 1);
$array str_split($chmod3);
        return
array_sum(str_split($array[0])) . array_sum(str_split($array[1]))
array_sum(str_split($array[2]));
public function get($filename,$mode=NULL) {
        if(!
        // Check to see if the user wants to use a specific transfer method,
        // otherwise assume that they want to use the class' default mode
$usemode $this->transfer_mode;
        if(
$mode==FTP_BINARY || $mode==FTP_ASCII$usemode $mode;
        // Check to see if there is a path as part of the file name and, if so,
        // split off the file name to use it as the local file name too
if(strpos($filename,"\\")>-1) {
$parts explode("\\",$filename);
$localname array_pop($parts);
            unset(
$parts);
        } elseif(
strpos($filename,"/")>-1) {
$parts explode("/",$filename);
            unset(
$parts);
        } else {
$localname $filename;
        // Try to get the file
if(ftp_get($this->conn$localname$filename$usemode)) {
            return
true;
        } else {
            return
false;
public function mget($filespecs$mode=NULL) {
        if(!
$pwd $this->pwd();
$remotepath $pwd;
        if(
        // Check to see if there is a path as part of the file specs and, if so,
        // split off the filespecs and the folder path
if(strpos($filespecs,"\\")>-1) {
$localspecs array_pop($parts);
$remotepath implode("\\",$parts);
            unset(
$parts);
        } elseif(
strpos($filespecs,"/")>-1) {
$remotepath implode("/",$parts);
            unset(
$parts);
        } else {
$localspecs $filespecs;
        // The the present working directory on the FTP server is not the same as
        // the desired location, try to change to that folder.  If that does not
        // work then exit with failure here (not accessable/does not exist).
if(strcmp($pwd,$remotepath)!=0) if(!$this->cd($remotepath)) return false;
        // Process each of the files
$success 0;
$found 0;
        foreach(
$this->dirdetailsfilter($localspecs$remotepath) as $info) {
            // If this is NOT a folder
if(!$info['dir']) {
$found++;
                if(
$this->get($info['name'], $usemode)) {
$success++;
        // the desired location, try to return to the old directory.
if(strcmp($pwd,$remotepath)!=0$this->cd($pwd);
        // Determine what to return
        // * If nothing found, return -1
        // * If found = success, return 1
        // * Otherwise, return 0
if($found==0) {
            return -
1;
        } elseif(
$found==$success) {
            return
1;
        } else {
            return
0;
function getdir($path$recursive=true$mode=NULL) {
        if(!
$pwd $this->pwd();
$ret true;
        if(
$parts explode("/"str_replace("\\","/",$path));
        // Stip the desired folder name off of the given path
$foldername array_pop($parts);
        unset(
$parts);
        if(!
is_dir($foldername)) mkdir($foldername);
        if(
$this->lcd($foldername)) {
            // What kind of get is this -- single folder or recursive
if($recursive) {
                if(
$this->cd($path)) {
                    // In the subfolder, so read the directory
$files $this->dirdetails();
                    foreach(
$files as $fil) {
                        if(
$fil['dir']==true) {
                            // This is a folder, so recursively call the function
                            // __________
                            // 1 -- get the current local path
                            // 2 -- recursively call this function
                            // 3 -- return to the current remote path
                            // 4 -- return to the local path before the recursion
$olddir $this->lpwd();
$this->getdir($path "/" trim($fil['name']),
$recursive$usemode);
$this->cd($path);
$this->lcd($olddir);
                        } else {
                            // Download the file
if(!$this->get($path "/" $fil['name'], $usemode)) {
$ret false;
                } else {
                    // Could not change to the desired path on the FTP server, so
                    // this operation has failed
$ret=false;
            } else {
                // Just download the files in the given folder; this will recreate
                // the folder name in the current path.  If it already exists it will
                // just add files to the existing folder.
if($this->cd($path)) {
                    foreach(
$files as $fil) {
                        // If this entry is not a directory...
if($fil['dir']==false) {
                            // ...download the file
if(!$this->get($fil['name'], $usemode)) {
$ret false;
                } else {
$ret=false;
        } else {
            // Could not change to the desired path on the local machine, so
$ret=false;
        // Return to the original path
$this->cd($pwd);
        return
$ret;
function getdirfilter($path$fliter="*"$recursive=true$mode=NULL) {
        if(!
$pwd $this->pwd();
$ret true;
        if(
        unset(
$parts);
        if(!
        if(
if($recursive) {
                if(
$this->cd($path)) {
$files $this->dirdetailsfilter($fliter);
                    if(!empty(
$files)) {
                        foreach(
$files as $fil) {
                            if(
                                // __________
$this->getdirfilter($path "/" trim($fil['name']),
$fliter$recursive$usemode);
$this->cd($path);
                            } else {
$ret false;
                    } else {
                        // Nothing matched
$ret=false;
                } else {
$ret=false;
            } else {
                    foreach(
$files as $fil) {
$ret false;
                } else {
$ret=false;
        } else {
$ret=false;
$this->cd($pwd);
        return
$ret;
public function put($filename$dest="",$mode=NULL) {
        if(!
$pwd $this->pwd();
        if(
        // Check to see if there was a destination location given.  If so, change
        // to that location.  If that fails, return to the present working
        // directory and return false.
if(strlen($dest)>0) {
            if(!
$this->cd($dest)) {
$this->cd($pwd);
                return -
1;
            unset(
$parts);
        } elseif(
            unset(
$parts);
        } else {
        // Try to put the file
$ret false;
        if(
ftp_put($this->conn$localname$filename$usemode)) {
            return
false;
$this->cd($pwd);
        return
$ret;
public function mput($filespecs="*"$dest=""$mode=NULL) {
        if(!
$lpwd $this->lpwd();
$localpath $lpwd;
$pwd $this->pwd();
        if(
            if(!
$this->cd($dest)) {
$this->cd($pwd);
                return -
1;
        // split off the file name to use it as the local file name too.
$parts explode("\\",$filespecs);
$localpath implode("\\"$parts);
            unset(
$parts);
        } elseif(
$parts explode("/",$filespecs);
$localpath implode("/"$parts);
            unset(
$parts);
        } else {
        // The the present working directory on the local server is not the same as
if(strcmp($lpwd,$localpath)!=0) if(!$this->lcd($localpath)) return -1;
$success 0;
$found 0;
$list glob($filespecs);
        if(empty(
$list)) return 0;
        foreach(
$list as $srcfile) {
            if(!
is_dir($srcfile)) {
$found++;
                if(
$this->put($srcfile$usemode)) $success++;
if(strcmp($lpwd,$localpath)!=0$this->lcd($lpwd);
$this->cd($pwd);
        // * If nothing found or an error, return -1
if($found==0) {
            return -
1;
        } elseif(
$found==$success) {
            return
1;
        } else {
            return
0;
public function putdir($srcdir$destdir="",$mode=NULL) {
        if(!
$ret true;
$pwd $this->pwd();
        if(
        // Check to see if there was a destdirination location given.  If so, change
if(strlen($destdir)>0) {
            if(!
$this->cd($destdir)) {
$this->cd($pwd);
                return -
1;
        // Try to put the folder
        // __________
        // Load the source directory
$local dir($srcdir);
$target strlen(trim($destdir))>trim($destdir) : $pwd;
        while(
$file =  $local->read()) {
            // Ignore . and .. (prevents a loop)
if($file != "." && $file!="..") {
                if(
is_dir("$srcdir/$file")) {
                    // This is a directory
if(!$this->cd("$target/$file")) {
                        // Try to create the new folder
if(!$this->makedir("$target/$file")) {
                            // If the folder was not made, fail here and do
                            // not try to upload this folder
$ret false;
                        } else {
                            // Recursively call this function to add the files
$this->putdir("$srcdir/$file""$target/$file",
$usemode);
                    } else {
$usemode);
                } else {
                    // Try to upload the file to the server
if(!$this->put("$srcdir/$file""$target"$usemode)) {
$ret false;
$local->close();
$this->cd($pwd);
        return
$ret;
public function del($file) {
        if(!
        if(
strpos($file,"*")>-|| strpos($file,"?")>-1) {
            // Name has wildcards, so delete multiple files
$pwd $this->pwd();
$remotepath $pwd;
if(strpos($file,"\\")>-1) {
$parts explode("\\",$file);
                unset(
$parts);
            } elseif(
strpos($file,"/")>-1) {
$parts explode("/",$file);
                unset(
$parts);
            } else {
$localspecs $file;
            // Get a list of matching files
$this->cd($remotepath);
$list $this->dirdetailsfilter($localspecs);
$ret true;
            foreach(
$list as $fil) {
                if(!
$fil['dir']) {
                    if(!
$this->del($fil['name'])) {
$ret false;
$this->cd($pwd);
            return
$ret;
        } else {
            // Just removing one file
return ftp_delete($this->conn$file);
public function deldir($dir) {
        if(!
        if(
strlen(trim($dir))<1) return false;
$pwd $this->pwd();
        // Make sure the folder exists
$ret true;
$dir str_replace("\\","/",$dir);
        if(
substr($dir,0,1)!="/"$dir "$pwd/$dir";
        if(!
$this->existsdir($dir)) return false;
        if(!(@
ftp_rmdir($this->conn$dir) || @ftp_delete($this->conn$dir))) {
            // If this fails, then the folder has files in it still
$list = @ftp_nlist($this->conn$dir);
            // Call this function again for each of the entries within this folder
foreach($list as $name) {
                if(
$name !="." && $name!="..") {
                    if(!
$this->deldir($name)) $ret false;
            // Try removing this folder again
if(!$this->deldir($dir)) $ret false;
        if(!
$this->cd($pwd)) $this->cd("/");
        return
$ret;
public function exists($path) {
        // File existance check
$list $this->dirdetails($path);
$ret count($list)>true false;
        unset(
$list);
        return
$ret;
public function existsdir($path) {
        // File or folder existance check
$path str_replace("\\","/",$path);
        if(
$path == "/") return true;
$parts split("/",$path);
$last array_pop($parts);
$base implode("/"$parts);
        unset(
$parts);
$list $this->dirdetailsfilter($last$base);
        unset(
$list);
        return
$ret;
public function movetoserver($file$dest=""$mode=NULL) {
        if(!
        // Try to put the file on the host
$ret $this->put($file,$dest,$mode);
        // If the put operation was successful, delete the file
if($retunlink($file);
        return
$ret;
public function movefromserver($file$mode=NULL) {
        if(!
        // Try to get the file from the server
$ret $this->get($file,$mode);
        // If the get operation was successful, delete the file from the FTP host
if($ret$this->del($file);
        return
$ret;
public function rename($oldname$newname) {
        if(!
        // Call the native rename command and return its results
return ftp_rename($this->conn$oldname$newname);
public function chmod($mode$filename) {
        if(!
$mod trim($mode);
$fil str_replace("\\","/",trim($filename));
        return
ftp_site($this->conn"chmod $mod $fil");
public function translatecommand($commandline) {
$commandline trim(str_replace("\\""/"$commandline));
        if(
strlen($commandline)<1) return false;
        // Ignore comment lines
if(substr($commandline,0,1)=="#") return true;
$commandline $this->replacetokens($commandline);
        // Process the actual FTP command
$ret false;
$parts split(" "$commandline2);
        echo
var_dump($parts) . "\n";
        if(isset(
$parts[0])) {
            switch(
trim($parts[0])) {
                case
'chmod':
$list split(" "$parts[1], 2);
$mod = isset($list[0]) ? trim($list[0]) : "";
$fil = isset($list[1]) ? trim($list[1]) : "";
                    if(
strlen($mod)>&& strlen($fil)>0) {
$ret $this->chmod($mod$fil);
                    } else {
$ret false;
                    break;
                case
'ren':
                case
'rename':
$old = isset($list[0]) ? trim($list[0]) : "";
$new = isset($list[1]) ? trim($list[1]) : "";
                    if(
strlen($old)>&& strlen($new)>0) {
$ret $this->rename($old$new);
                    } else {
$ret false;
                    break;
                case
'put':
$ret $this->put($parts[1]);
                    break;
                case
'mput':
$list split(" "$parts[1]);
                    foreach(
$list as $s) {
                        if(
$this->mput($s)) $ret true;
                    break;
                case
'mget':
                    foreach(
$list as $s) {
                        if(
$this->mget($s)) $ret true;
                    break;
                case
'mkdir':
                    if(
$this->conn) {
$ret $this->makedir($parts[1]);
                    } else {
$ret false;
                    break;
                case
'mget':
$ret $this->mget($parts[1]);
                    break;
                case
'get':
$ret $this->get($parts[1]);
                    break;
                case
'rmdir':
$ret $this->deldir($parts[1]);
                    break;
                case
'mdel':
                case
'mdelete':
                    foreach(
$list as $s) {
                        if(
$this->del($s)) $ret true;
                    break;
                case
'del':
                case
'delete':
$ret $this->del($parts[1]);
                    break;
                case
'lcd':
$ret $this->lcd($parts[1]);
                    break;
                case
'cd':
$ret $this->cd($parts[1]);
                    break;
                case
'binary':
$this->transfer_mode FTP_BINARY;
$ret true;
                    break;
                case
'ascii':
$this->transfer_mode FTP_ASCII;
$ret true;
                    break;
                case
'close':
                case
'quit':
                case
'bye':
$this->close();
$ret true;
                    break;
        return
$ret;
private function replacetokens($cmd) {
$ret $cmd;
$ret str_replace("%d%"date("d",strtotime("now")), $ret);
$ret str_replace("%D%"date("D",strtotime("now")), $ret);
$ret str_replace("%j%"date("j",strtotime("now")), $ret);
$ret str_replace("%l%"date("l",strtotime("now")), $ret);
$ret str_replace("%N%"date("N",strtotime("now")), $ret);
$ret str_replace("%S%"date("S",strtotime("now")), $ret);
$ret str_replace("%w%"date("w",strtotime("now")), $ret);
$ret str_replace("%z%"date("z",strtotime("now")), $ret);
$ret str_replace("%W%"date("W",strtotime("now")), $ret);
$ret str_replace("%F%"date("F",strtotime("now")), $ret);
$ret str_replace("%m%"date("m",strtotime("now")), $ret);
$ret str_replace("%M%"date("M",strtotime("now")), $ret);
$ret str_replace("%n%"date("n",strtotime("now")), $ret);
$ret str_replace("%t%"date("t",strtotime("now")), $ret);
$ret str_replace("%L%"date("L",strtotime("now")), $ret);
$ret str_replace("%o%"date("o",strtotime("now")), $ret);
$ret str_replace("%Y%"date("Y",strtotime("now")), $ret);
$ret str_replace("%y%"date("y",strtotime("now")), $ret);
$ret str_replace("%a%"date("a",strtotime("now")), $ret);
$ret str_replace("%A%"date("A",strtotime("now")), $ret);
$ret str_replace("%B%"date("B",strtotime("now")), $ret);
$ret str_replace("%g%"date("g",strtotime("now")), $ret);
$ret str_replace("%G%"date("G",strtotime("now")), $ret);
$ret str_replace("%h%"date("h",strtotime("now")), $ret);
$ret str_replace("%H%"date("H",strtotime("now")), $ret);
$ret str_replace("%i%"date("i",strtotime("now")), $ret);
$ret str_replace("%s%"date("s",strtotime("now")), $ret);
$ret str_replace("%u%"date("u",strtotime("now")), $ret);
$ret str_replace("%e%"date("e",strtotime("now")), $ret);
$ret str_replace("%I%"date("I",strtotime("now")), $ret);
$ret str_replace("%O%"date("O",strtotime("now")), $ret);
$ret str_replace("%P%"date("P",strtotime("now")), $ret);
$ret str_replace("%T%"date("T",strtotime("now")), $ret);
$ret str_replace("%Z%"date("Z",strtotime("now")), $ret);
$ret str_replace("%c%"date("c",strtotime("now")), $ret);
$ret str_replace("%r%"date("r",strtotime("now")), $ret);
$ret str_replace("%U%"date("U",strtotime("now")), $ret);
$ret str_replace("%LONGDATE%"date("l, F j, Y"strtotime("now")),
$ret);
$ret str_replace("%SHORTDATE%"date("n/j/Y",strtotime("now")), $ret);
$ret str_replace("%LONGTIME%"date("g:i:s A"strtotime("now")), $ret);
$ret str_replace("%SHORTTIME%"date("H:i:s",strtotime("now")), $ret);
$ret str_replace("%DATESTAMP%"strtotime("now"), $ret);
        return
$ret;
http://www.phpclasses.org/package/8186-PHP-Access-files-in-FTP-servers.html
۲۱-مرداد-۱۳۹۲, ۰۰:۲۳:۳۸
تشکر شده توسط : lord_viper, Ambassador, omid_phoenix
RE: کلاس‌های مفید php
کلاسی برای ایجاد فایل ورد (word docX)
.zip   vs-template-docx-2013-07-31.zip (اندازه: 33.71 KB / تعداد دفعات دریافت: 63)
۲۵-مرداد-۱۳۹۲, ۲۲:۵۵:۱۹
تشکر شده توسط : Ambassador, lord_viper, omid_phoenix
Question [سوال] اعتبار سنجی فرم آپلود عکس با استفاده از یک کلاس crafcrab 2 2,619 ۱۳-آبان-۱۳۹۴, ۰۹:۴۸:۵۹
