پروژه قفل رمز 8 رقمی به زبان بیسیک
a.mehran آفلاین
ارسال‌ها: 1,029
تشکرها : 5126
( 4490 تشکر در 1882 ارسال )
.rar   Code-Lock.rar (اندازه: 203.76 KB / تعداد دفعات دریافت: 158)
$regfile "m8def.dat"
$crystal 1000000                                          'Internal RC
$hwstack = 64
$swstack = 64
$framesize = 64
LCD
Config Lcdpin
Pin Db7 Portd.7 Db6 Portd.6 Db5 Portd.5 Db4 Portd.4 Portd.1 Rs Portd.0
Config Lcd
16 2
Cls
Home Cursor Off
'Back Space Symbol
Deflcdchar 0 , 32 , 4 , 12 , 31 , 12 , 4 , 32 , 32
Keypad
Config Kbd
Portb
'I/O
Config Pind.0 = Output                                      '
Active
Config Pind.1
Output                                      'Relay
Config Pind.2 = Input                                       '
Default
Config Pind.3 Output                                      'Speaker
Set Pullup Resistor For Default Key
Set Portd.2
'Active Pullup Res
Aliases
Active Alias Portd.0
Relay Alias Portd.1
Default Alias Pind.2
Speaker Alias Pind.3
'Var
Dim Digits As Byte , Key As Byte , Result As Byte , Num As String * 4
Dim Pass(8) As String * 1 , Pass1(8) As String * 1 , Pass2(8) As String * 1
Dim Pass_eeprom(8) As Eram String * 1 , Rcv(8) As String * 1
Dim Temp As Byte , Sel As Byte
Subroutines
Declare Sub Main
Declare Sub Default_pass
Declare Sub Load2ram
Declare Sub Getpass
Declare Sub Check
Declare Sub Change
Declare Sub Menu
Declare Sub Change_pass
Declare Sub Confirm
Declare Sub Check1
'Declare Sub Cleardisp(byval Sel As Byte)
Function
Declare Function
Is_num(byval Num As String) As Byte
'Main Prog Start Here:
Call Main
'Main Sub, Check Default Key Status & Call Other Sub's
Sub Main
   Sound Speaker
120 20                                 'Startup Sound
   Active = 1                                               '
Red LED=1
If Default = 0 Then Call Default_pass
   Call Load2ram
   Call Getpass
End Sub
'_______________________________________________________________________________
Set Default Password (11111111)
Sub Default_pass
   Sound Speaker
120 30
'Clear Pass
   For Temp = 1 To 8
      Pass_eeprom(temp) = "1"
      Waitms 20
   Next Temp
   Cursor Off
   Cls : Home : Lcd "Memoey Erased!"
   Lowerline : Lcd "Pass=11111111"
   Sound Speaker , 120 , 60
   Waitms 1500
End Sub
'Load Pass to SRAM
Sub Load2ram
   For Temp = 1 To 8
      Pass(temp) = Pass_eeprom(temp)
      Waitms 20
   Next Temp
End Sub
'Get Password
Sub Getpass
   Cls : Home : Lcd "Password?  Cls=" ; Chr(0)
   Home L : Cursor Blink
   Digits = 0
   Waitms 500
      Key = Getkbd()
      Num = Lookupstr(key , Decode)
      If Num = "Cls" Then Call Getpass
      If Is_num(num) = 1 Then
         Sound Speaker , 120 , 50
         Sound Speaker , 120 , 40
         Incr Digits
         Locate 2 , Digits : Lcd "*"
         Rcv(digits) = Num
         If Digits = 8 Then                                 '
Pass Entered
            Call Check
If Result <> 8 Then
'Error Pass
               Sound Speaker , 120 , 80
               Cls : Home : Lcd "Error!" : Set Portd.0
               Wait 2
               Cursor Noblink
               Waitms 500
               Call Getpass
            Else
Successful Pass
               Call Menu
If
End If
Waitms 300
If
End Sub
Check Pressed Key Is A Number(0-9)? If Yes Is-num 1 In No Is_num=0
Function Is_num(byval Num As String) As Byte
If Num "0" Or Num "1" Or Num "2" Or Num "3" Or Num "4" _
Or Num "5" Or Num "6" Or Num "7" Or Num "8" Or Num "9" then
      Is_num
1
Else
Is_num 0
If
End Function
Password Checker
Sub Check
   Result
0
For Temp 1 To 8
If Rcv(temp) = Pass(tempThen Incr Result
   Next Temp
End Sub
Sub Menu (Open Door Or Cahnge pass)
Sub Menu
   Cls
Home Cursor Noblink Lcd "1=Relay     Exit"
Lowerline Lcd "2=Change"
Sound Speaker 120 100
   Sound Speaker
120 80
   Sound Speaker
120 60
   Waitms 500
Key Getkbd()
Num Lookupstr(key Decode)
      If
Num "1" Then
         Toggle Relay
If Relay 0 Then
            Sound Speaker
120 20
Else
Sound Speaker 120 40
If
Waitms 500
If
      If
Num "Exit" Then Call Getpass
If Num "2" Then Call Change_pass
End Sub
Change Password
Sub Change_pass
   Cls
Home Lcd "New Pass?  Cls=" Chr(0)
Lowerline Lcd "            Exit"
Sound Speaker 120 60
   Home L
Cursor Blink
   Digits
0
   Waitms 500
Key Getkbd()
      If
Num "Cls" Then Call Change_pass
If Num "Exit" Then Call Getpass
         Sound Speaker
120 50
         Sound Speaker
120 40
         Incr Digits
         Pass1
(digits) = Num
         Locate 2
Digits Lcd "*"
Waitms 300
If Digits 8 Then Call Confirm
If
End Sub
Confirm Password
Sub Confirm
   Digits
0
   Cls
Home Lcd "Confirm:   Cls=" Chr(0)
   Home L
   Waitms 500
Key Getkbd()
      If
Num "Cls" Then Call Confirm
         Sound Speaker
120 50
         Sound Speaker
120 40
         Incr Digits
         Pass2
(digits) = Num
         Locate 2
Digits Lcd "*"
Waitms 300
If Digits 8 Then
            Call Check1
            Cursor Noblink
If Result 8 Then
               Cls
Home Lcd "Pass Changed!"
               Sound Speaker
120 80
               Sound Speaker
120 60
For Temp 1 To 8
                  Pass_eeprom
(temp) = Pass1(temp)
Waitms 20
               Next Temp
               Call Load2ram
               Call Getpass
Else
Sound Speaker 120 80
               Cls
Home Lcd "Error!"
Waitms 500
               Call Change_pass
If
End If
End If
End Sub
Confirm Pass Checker
Sub Check1
   Result
0
For Temp 1 To 8
If Pass1(temp) = Pass2(tempThen Incr Result
   Next Temp
End Sub
'Keypad Decode Data Table
Decode:
Data "1" , "2" , "3" , ""
Data "4" , "5" , "6" , ""
Data "7" , "8" , "9" , ""
Data "Exit" , "0" , "Cls" , "" , ""
'_____________________________________فایل کامل پیوست شد
سایت من Abrdade.com
(آخرین ویرایش در این ارسال: ۱۰-شهریور-۱۳۹۲, ۲۳:۲۲:۴۱، توسط babyy.)
۱۰-شهریور-۱۳۹۲, ۲۱:۲۰:۵۶
تشکر شده توسط : hadikh73, babyy, omid_phoenix, Ambassador
آخرین ارسال: sky_man847
  کمک در برنامه فرستنده avr به زبان سی sniper-70 3 3,823 ۱۹-شهریور-۱۳۹۵, ۱۲:۳۳:۲۰
  glcd با بیسیک mohebbat 9 3,466 ۲۷-بهمن-۱۳۹۴, ۱۶:۲۹:۲۴
آخرین ارسال: mohebbat
  [فوری] ساخت نمایشگر شمارنده سه رقمی نزولی hamtoosi 1 2,490 ۲۵-دى-۱۳۹۴, ۰۱:۱۵:۵۹
آخرین ارسال: lord mohsen
  گرفتن عدد دو رقمی و بیشتر از کیبرد goldenmasoud 14 23,650 ۲۵-دى-۱۳۹۴, ۰۱:۰۸:۲۷
  کمک برای شمارنده 3 رقمی مریم 89 9 6,027 ۲۲-آبان-۱۳۹۴, ۰۲:۵۶:۳۷
آخرین ارسال: amiri630
  [سوال] شمارش معکوس سه رقمی سون سگمنت مالتی پلکس amiri630 0 2,853 ۱۷-آبان-۱۳۹۴, ۱۵:۳۶:۰۶
  شمارنده سه رقمی با امکان کنترل morvarid 1 2,557 ۲۴-مرداد-۱۳۹۴, ۱۵:۳۷:۱۴
  راهنمایی در یک پروژه cortex-m3 0 2,020 ۱۴-تير-۱۳۹۴, ۲۰:۲۰:۵۶
آخرین ارسال: cortex-m3
  داشتن یک عدد سه رقمی از adc در تمام حالات؟ cortex-m3 1 2,233 ۱۹-خرداد-۱۳۹۴, ۱۱:۳۶:۲۰
آخرین ارسال: milad15m
