سلام من این کدها رو از یه سایتی گرفتم.
ببینید چیز بدرد بخوریه؟همون کدهایی که میفرسته نیست؟
SONY TV
Sony TVs are quickly becoming more complicated. There are now 4 device codes being used in the U.S., and the foreign codes, which are sometimes completely different, complicate things even more. There are also a lot of old, obsolete codes and seemingly, many duplicates of certain functions. However, the codes for now seem to be pretty standardized for U.S. televisions. I just don’t know why they use so many device codes! Why do they use a few functions on 151 and 119 when those could be combined?
There’s also the weird 26.26 codes. I think these are for the DTV tuner portion of some early model HDTVs.
Hopefully someone out there could clear up some of the obsolete, foreign and teletext codes, or anything I don’t know what it does as listed in the chart. If you know any more codes, e-mail me!
New are the plasma TV codes.
Olive = obsolete
Orange = foreign
Magenta = Plasma TV
Sony:1
Command Code
Command(s)
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
0
10
11
11
Enter, 12
12
1-, 13
13
2-, 14
14
Guide, Channel Guide, P/C, 15
15
Clear
16
Channel Up
17
Channel Down
18
Volume Up
19
Volume Down
20
Mute
21
Power
22
Reset
23
MTS/SAP, Audio Monitor, Nicam
24
Picture/Contrast Up
25
Picture/Contrast Down
26
Color Up
27
Color Down
28
Channel Lock
29
30
Bright Up
31
Bright Down
32
Hue Down
33
Hue Up
34
Sharpness Up
35
Sharpness Down
36
TV tuner (discrete)
37
TV/Video
38
Balance Left
39
Balance Right
40
Bass, Tone, Loudness On/Off, OSE
41
SRS, Surround, 3D Sound On/Off
42
Antenna/Aux
43
Clock, Time
44
External Antenna
45
RGB
46
Power On (discrete)
47
Power Off (discrete), System Off
48
Timer, Time, Blk
49
Up
50
Down
51
Right, Clock AM/PM
52
Left, Clock Clear
54
Sleep, Off Timer
56
Teletext Off/Out, Power On (discrete), Select Tuner
58
Display, Info, Teletext Index
59
Jump, Last
60
Timer-Off, Repeat
62
Pic Off
63
Teletext On/Mode, Display
64
Video 1 (discrete), Line A, Line, Video
65
Video 2 (discrete), Line B, Option
66
Video 3 (discrete), VTR
67
RGB Input 1 (discrete), Computer (RGB) input (discrete)
68
RGB Input 2 (discrete)
71
Video 4 (discrete)
72
Video 5 (discrete), YUV
73
Video 6 (discrete), FM
74
Teletext Hold, Noise Reduction On/Off
75
Fasttext Red (obsolete?)
76
Fasttext Green (obsolete?)
77
S-Video, Y/C, Fasttext Yellow (obsolete?)
78
Cable toggle
79
Notch fliter On/Off, Fasttext Blue (obsolete?)
80
Internal Speakers On/Off
81
Sat (?)
88
PIP Channel Up
89
PIP Channel Down
90
PIP TV/Video
91
PIP On/Toggle
92
PIP Freeze, Digital Memo
94
PIP Position
95
PIP Swap
96
Menu, Guide, Wega Gate
97
Video
98
Audio
99
Exit
100
Picture Mode, ASC, Profile
101
Return, Select, Enter (menu select key)
102
Output Select
103
PIP source
104
TV System
106
Color System
107
Auto Program
108
Preset
110
Search +
111
Search –
112
Treble Up
113
Treble Down
114
Bass Up
115
Bass Down
116
Up, R, Level Up
117
Down, L, Level Down
120
Add
121
Erase
124
Select
125
Trinitron
127
test code
