اشکال در برنامه بسکام
870949623 آفلاین
ارسال‌ها: 9
تاریخ عضویت: اسفند ۱۳۸۹
تشکرها : 9
باسلام
من در مورد برنامه زیر مشکل داشتم
در پروتئوس مدام پرش می کند بطوری که اصلا صفحه نمایش خوانده نمی شود
لطفا کمکم کنید
باتشکر
$regfile = "M16def.dat"
$crystal = 1000000
Config Portd = Output
Config Pinb.2 = Input
Config Pinb.3 = Input
Config Pinb.4 = Input
Config Pinb.5 = Input
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 20 * 4
Config Adc = Single , Prescaler = Auto , Reference = Internal
Config Portb = Input
Config Debounce = 50
Start Adc
Seting Alias Pinb.2 : Up Alias Pinb.3 : Down Alias Pinb.4 : Menu Alias Pinb.5
Dim T0 As Word , T1 As Word , Temp As Word
Dim A As Byte , B As Word , C As Byte , D As Byte , E As Byte , F As Single
Dim O As Byte , Of As Byte , M As Byte , S As Byte , , Cx As Byte
Dim X As Word , Y As Word , Z As Word , Ch As Single , Tc As Single , Tr As Single
Dim W As Word , U As Single , J As Single , L As Single , H As Single , Q As Single,
Dim V As Single , R As Single , Pv As Single , Pc As Single , N As Single
Declare Sub Tempsens
Declare Sub Key
Declare Sub Llcd
Cursor Off
Call Key
Call Tempsens
Call Llcd
Sub Key
If M <> 0 Then
If Seting = 0 Then
Incr S
Waitms 200
If S > 3 Then S = 0
If S = 1 Then
Locate 2 , 4
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
If S = 2 Then
Locate 3 , 3
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
If S = 3 Then
Locate 4 , 4
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
Waitms 10
Cursor On Blink
Waitms 10
Cursor Off Noblink
If Menu = 0 Then
Incr M
Cls
Waitms 1000
If M > 1 Then M = 0
Cls
O = C
Of = D
Cx = E
S = 0
If Up = 0 Then
If S = 1 Then
Incr O
Waitms 50
If M = 1 Then C = O
If S = 2 Then
Incr Of
Waitms 50
If M = 1 Then D = Of
If S = 3 Then
Incr Cx
Waitms 50
If M = 1 Then E = Cx
If Down = 0 Then
If S = 1 Then
Decr O
Waitms 150
If M = 1 Then C = O
If S = 2 Then
Decr Of
Waitms 150
If S = 3 Then
Decr Cx
Waitms 150
Sub Tempsens
X = Getadc(0)
Y = Getadc(1)
Temp = X - Y
Temp = Temp / 4
Ch = Temp * 1.8
Ch = Ch + 502
Tc = T1 + 470
Tr = Ch / Tc
Z = Getadc(2)
Z = Z / 3
U = Tr ^ 6
U = 0.16934 * U
F = Log(tr)
F = 1.28862 * F
J = 1 / Tr
J = 6.09648 * J
H = 5.92714 - J
H = H - F
H = H + Y
L = Tr ^ 6
L = 0.4357 * L
Q = Log(tr)
Q = 13.4721 * Q
V = 1 / Tr
V = 15.6875 * V
N = 15.2518 - V
N = N - Q
N = N + L
R = W * N
R = R + H
R = Exp(r)
Pv = Pc * R
Pv = A
Waitms 1000
Sub Llcd
If M = 0 Then
Locate 2 , 1
Lcd "Temp=" ; Temp ; Chr(0) ; "c"
Locate 3 , 1
Lcd "pv=" ; A ; "psia"
Locate 4 , 1
Lcd "p=" ; Z ; "psia"
If M = 1 Then
Locate 2 , 1
Lcd "pc=" ; C ; " " ; "psia"
Locate 3 , 1
Lcd "w=" ; D ; " "
Locate 4 , 1
Lcd "T1=" ; E ; " "
(آخرین ویرایش در این ارسال: ۰۳-شهریور-۱۳۹۰, ۱۷:۵۶:۳۰، توسط h0x00i.)
۰۳-شهریور-۱۳۹۰, ۱۳:۴۹:۵۴
h0x00i آفلاین
ارسال‌ها: 959
موضوع‌ها: 109
تاریخ عضویت: دى ۱۳۸۹
تشکرها : 2866
( 2450 تشکر در 949 ارسال )
RE: اشکال در برنامه بسکام
سلام دوست عزیز ...
خوب این چیه ؟؟؟ مدار بزار ببینیم چیه
پروژه ، مقاله ،...
(آخرین ویرایش در این ارسال: ۱۳-شهریور-۱۳۹۰, ۲۰:۵۶:۴۹، توسط h0x00i.)
۰۳-شهریور-۱۳۹۰, ۱۷:۵۸:۱۳
tehrantat آفلاین
تشکرها : 2
dar Sub Llcd ghabl az end sub waitms 500
benevis!!!
۱۱-شهریور-۱۳۹۰, ۰۵:۳۶:۰۳
h0x00i آفلاین
ارسال‌ها: 959
موضوع‌ها: 109
تشکرها : 2866
سلام tehrantat عزیز
به ایران ویج خوش آمدید
لطفا جواب های خود را به صورت فارسی وارد کنید
پروژه ، مقاله ،...
۱۳-شهریور-۱۳۹۰, ۲۰:۵۹:۳۰
آخرین ارسال: lrn1380
آخرین ارسال: questnet
آخرین ارسال: hadikh73
آخرین ارسال: fedagh
آخرین ارسال: behzadsen
  [سوال] کتابخانه بسکام برای ks0108 mmolah 1 2,736 ۰۳-خرداد-۱۳۹۵, ۰۷:۵۵:۲۵
آخرین ارسال: mmolah
  [سوال] سوالی راجع به بسکام mohamadgmail 1 2,117 ۲۷-آذر-۱۳۹۴, ۰۲:۴۷:۰۴
