  • 2 رأی - میانگین امتیازات: 5
Raspberry Pi:Linux Install Guide
behzady آفلاین
ارسال‌ها: 1,169
تشکرها : 4094
( 6339 تشکر در 2085 ارسال )
خوب حالا می خوام نحوه نصب سیستم عامل روی رسبری رو آموزش بدم
و در مرحله بعد تنظیمات مخصوص برای سیستم هامل Arch رو بدم.
فقط توجه کنید که پکیج نوب (NOOBS) با روشی متفاوت عمل کنید که در آموزش بعدی میگم.
سیستم مورد نظر خودتون رو دانلود کنید:
رسبین (Raspbian)
نقل قول:
If you’re just starting out, this is the image we recommend you use. It’s a reference root filesystem from Alex and Dom, based on the Raspbian optimised version of Debian, and containing LXDE, Midori, development tools and example source code for multimedia functions.
SHA-1     f072b87a8a832004973db4f5e1edb863ed27507b
Default login     Username: pi Password: raspberry
دبین(Soft-float Debian)
نقل قول:
This image is identical to the Raspbian “wheezy” image, but uses the slower soft-float ABI. It is only intended for use with software such as the Oracle JVM which does not yet support the hard-float ABI used by Raspbian.
SHA-1     d42d913fb4f49b351ef865edcf318f47ae04edca
پیدورا(Pidora)
نقل قول:
Pidora is a Fedora Remix optimized for the Raspberry Pi computer. It uses the same hard-float calling convention as Raspbian, and incorporates many of the same optimizations, including ARMv6-optimized libarmmem. More details can be found here.
SHA-1     c6317c7f56ca68d8abe951a04bf494cf576a2792
Default login     Username: root Password: raspberrypi
آرچ لینوکس (Arch Linux ARM)
نقل قول:
Arch Linux ARM is based on Arch Linux, which aims for simplicity and full control to the end user. Note that this distribution may not be suitable for beginners. The latest version of this image uses the hard-float ABI, and boots to a command prompt in around ten seconds.
SHA-1     e273d680e89ca9f79c2252c0b00ccc3084cd9b14
Default login     Username: root Password: root
رایز (RISC OS)
نقل قول:
RISC OS is a computer operating system designed in Cambridge, England by Acorn. First released in 1987, its origins can be traced back to the original team that developed the ARM microprocessor. RISC OS is owned by Castle Technology, and maintained by RISC OS Open. This version is made available free of charge to Raspberry Pi users.
SHA-1     600ea45c26f5afd91cfc4c4cfa393cd4bb7549f7
خوب این مراحل رو من توی سیستم عامل فدورا دارم انجام میدم و بیشترش با لینوکس های مختلف سازگار هست با این حال اگر در ویندوز یا سیستم های دیگه مشکلی داشتید مطرح کنید
آماده سازی SD کارت
خوب ترمینال خودتون رو باز کنید و با دستور زیر وارد یوزر روت بشید
# su
ما باید اسم این SD کات رو پیدا کنیم برای این کار اول کارت اس دی رو از رایانه خارج کنید
بعد با این دستور لاگ کرنل رو پاک کنید
# dmesg --clear
و حالا SD کارت خودتون رو وارد دستگاه بکنید و با این دستور لاگ کرنل رو مشاهده کنید
# dmesg
و خروجی مثل این مشاهده می کنید
[ 4355.601098] usb 1-1.5: new high-speed USB device number 7 using ehci-pci
[ 4355.699677] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=0159
[ 4355.699684] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4355.699688] usb 1-1.5: Product: USB2.0-CRW
[ 4355.699691] usb 1-1.5: Manufacturer: Generic
[ 4355.699694] usb 1-1.5: SerialNumber: 20071114173400000
[ 4355.717735] scsi8 : usb-storage 1-1.5:1.0
[ 4356.720466] scsi 8:0:0:0: Direct-Access     Generic- Multi-Card       1.00 PQ: 0 ANSI: 0 CCS
[ 4356.723203] sd 8:0:0:0: Attached scsi generic sg2 type 0
[ 4357.538822] sd 8:0:0:0: [sdb] 32372736 512-byte logical blocks: (16.5 GB/15.4 GiB)
[ 4357.539968] sd 8:0:0:0: [sdb] Write Protect is off
[ 4357.539977] sd 8:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 4357.541051] sd 8:0:0:0: [sdb] No Caching mode page present
[ 4357.541060] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4357.545486] sd 8:0:0:0: [sdb] No Caching mode page present
[ 4357.545496] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4357.548603]  sdb: sdb1 sdb2 sdb3
[ 4357.552529] sd 8:0:0:0: [sdb] No Caching mode page present
[ 4357.552536] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 4357.552541] sd 8:0:0:0: [sdb] Attached SCSI removable disk
خوب اون خطی که با فاصله جدا کردم کردم اسم دستگاه و پارتیشن ها رو نشون میده (با لیبل پارتیشن ها فرق داره ها!)
ما با شماره پارتیشن ها کار نداریم با اسم دستگاه کار داریم که معمولا بدونه شماره هه هست که برای من میشه
sdb
این اسم رو میشه از روی بقیه پیغام ها هم فهمید همین طوری که می بینید همه ی پغام ها این رو دارن
[sdb]
که نشون دهنده یه دستگاه هست
نکته: حواستون باشه اشتباه نکنید وگرنه اطلاعات اون دستگاهی که اشتباهی انتخاب کردید کاملا پاک میشه و هیچ کاریش دیگه نمی تونید بکنید!
حتی هر بار که SD رو وارد می کنید این کار رو تکرار کنید چون گاهی اسم دستگاه عوض میشه!
این عوض شدن اسم یه بار کار دستم داد ولی شانسم گفت که فلشم رو اشتباهی انتخاب کردم ...
خوب حالا که اسم دستگاه رو می دونیم باید پارتیشن ها رو آن مونت(Unmount) کنیم
# umount /dev/sdb*
جای sdb باید اسم دستگاه خودتون رو بگید البته اگه اس دی نو باشه هیچ پارتیشنی نداره ولی برای محکم کار این کارو بکنید
(نکته اگه اشتباه اسم دستگاه رو انتخاب کرده باشید پارتیشن های دیگه ای خارج میشن که اگه پارتیشن های خودتون رو مشاهده کنید ممکن هست متوجه نبودشون بشید! ولی نگران نباشید با ریست شدن بر می گردند و برید و دوباره اسم SD رو پیدا کنید)
خوب حالا باید img رو روی اس دی بریزید
اول فایل زیپ خودتون رو باز کنید
و با دستور
sha1sum
یا
md5sum
چک کنید فایل با چک سامی که هست یکی باشه (با فایل زیپ فایل هست)
حالا باید ایمیج رو روی دستگاه بریزیم
با این دستور این کارو بکنید
# dd bs=1M if=/home/behzad/archlinux-hf-2013-06-06.img of=/dev/sdb
جای sdb اسم دستگاه خودتون رو قرار بدید و جای اون آدرس - آدرس ایمیج خودتون رو قرار بدید
فقط هیچ خروجی رو نمی بینید چند دقیقه منتظر بمونید و صبر پیشه کنید
یه همچین خروجی میده و خارج میشه
1870+0 records in
1870+0 records out
1960837120 bytes (2.0 GB) copied, 299.157 s, 6.6 MB/s
حالا با این دستور مطمن بشید که داده ها نوشته شدن
ممکن هست سریع خارج بشه یا مدتی طول بکشه ولی در دو حالت هیچ خروجی نمیده
# sync
حالا سیستم شما آماده هست ولی حالا فقط ۲ گیگ پارتیشن بندی شده اگه اس دی بزرگ تری دارید و میخواید پارتیشن ها رو بزرگ کنید تا کلش رو بگیره
یا پارتیشن های دیگه ای ایجاد کنید یا فضای swap و ... منتظر آموزش بعدی باشید ...
برای خارج کردن اس دی این دستور رو بزنید
# eject /dev/sdb
و اس دی کارت رو توی رسبری بزنید و به تلویزیون وصلش کنید
اگه تصویری ندیدید نگران نشید! مشکل معمولی هست برای رفع این مشکل همراه با باشید
اگه کیبرد و تلویزیون و موس و ... هم ندارید باید منتظر بمونید! تا تنظیم سیستم عامل رو بدون اینا بگیم!
با ما بمونید ...Biggrin
ویلیام شکسپیر
مهاتما گاندی
(آخرین ویرایش در این ارسال: ۰۸-مرداد-۱۳۹۲, ۱۰:۴۰:۲۶، توسط behzady.)
۰۸-مرداد-۱۳۹۲, ۱۰:۳۶:۳۱
تشکر شده توسط : babyy, sharin, omid_phoenix, hadikh73, orange signal, salehjg
behzady آفلاین
ارسال‌ها: 1,169
تشکرها : 4094
RE:Raspberry Pi:Linux Install Guide
خوب برای نصب پکیچ نوب (NOOBS)
SHA-1     bdb61930b077dcefd22b36caaa9698bdf76b290d
برای نصبش کلا SD رو FAT32 فرمت کنید و محتویات نوب رو توش کپی پیست کنید و رسبری رو وصل کنید به تلویزیون و شیفت رو نگه دارید تا صفحه انتخاب OS بیاد اگه چیزی ندیدید با دکمه های ۱ ۲ ۳ ۴ کیبرد نوع تلویزیون رو انتخاب کنید در حالت پیش فرض فقط با HDMI ارتباط بر قرار می کنه .... کلا پکیج جالبی نیستBiggrin
نصب در ویندوز
برای نصب لینوکس های مختلفی که در پست قبلی روی لینوکس آموزش دادیم
این نرم افزار رو دانلود کنید و درایور اس دی رو انتخاب کنید و ایمیج رو بهش بدید و منتظر بشید کار به اتمام برسه ...
دانلود از وبسایت خود Win32DiskImager
.zip   win32diskimager-v0.8-binary.zip (اندازه: 2.5 MB / تعداد دفعات دریافت: 71)
کلا روش های دیگه ای هم هست استفاده از Fedora Remix Installer
خوب ایندفعه کمی تا قسمتی کوچول موچول بود پستمون:ي
ویلیام شکسپیر
مهاتما گاندی
(آخرین ویرایش در این ارسال: ۱۸-مرداد-۱۳۹۲, ۲۲:۳۸:۵۴، توسط behzady.)
۰۹-مرداد-۱۳۹۲, ۰۹:۲۴:۱۳
تشکر شده توسط : hadikh73, sharin, omid_phoenix, babyy, Ambassador, orange signal, salehjg
  Linux: Web Server behzady 2 2,931 ۱۴-مرداد-۱۳۹۳, ۱۸:۵۰:۲۱
  raspberry pi sara12 1 2,288 ۰۹-مرداد-۱۳۹۳, ۰۸:۱۴:۲۴
  [آموزشی] SnapPiCam ساخت دوربین با raspberry Pi salehjg 0 2,664 ۱۶-بهمن-۱۳۹۲, ۰۲:۱۶:۴۲
آخرین ارسال: salehjg
  Raspberry Pi: رسبری های خودتون رو بزارید! behzady 3 8,936 ۰۷-مهر-۱۳۹۲, ۱۶:۰۶:۵۸
آخرین ارسال: h0x00i
  Raspberry Pi: Boot Loader behzady 0 2,328 ۲۷-مرداد-۱۳۹۲, ۱۹:۰۴:۴۲
  Raspberry Pi: Remote Connecting behzady 4 5,173 ۲۲-مرداد-۱۳۹۲, ۱۸:۲۶:۱۶
  Raspberry Pi: Editing Partitions behzady 0 2,039 ۱۲-مرداد-۱۳۹۲, ۱۰:۲۳:۲۰
