![[تصویر: image_2_th.gif]](http://www.electronics-lab.com/projects/test/001/image_2_th.gif)
This is an easy to build, but nevertheless very accurate and useful digital voltmeter. It has been designed as a panel meter and can be used in DC power supplies or anywhere else it is necessary to have an accurate indication of the voltage present. The circuit employs the ADC (Analogue to Digital Converter) I.C. CL7107 made by INTERSIL. This IC incorporates in a 40 pin case all the circuitry necessary to convert an analogue signal to digital and can drive a series of four seven segment LED displays directly. The circuits built into the IC are an analogue to digital converter, a comparator, a clock, a decoder and a seven segment LED display driver. The circuit as it is described here can display any DC voltage in the range of 0-1999 Volts
http://www.electronics-lab.com/projects/...mage_3.jpg
![[تصویر: image_1_th.gif]](http://www.electronics-lab.com/projects/test/001/image_1_th.gif)
انواع مقاومت برای انواع ولتاژ
0 - 2 V ............ R3 = 0 ohm 1%
0 - 20 V ........... R3 = 1.2 Kohm 1%
0 - 200 V .......... R3 = 12 Kohm 1%
0 - 2000 V ......... R3 = 120 Kohm 1%
R1 = 180k
P1 = 20k trimmer multi turn
R2 = 22k
U1 = ICL 7107
R3 = 12k
LD1,2,3,4 = MAN 6960 common anode led displays
R4 = 1M
R5 = 470k
R6 = 560 Ohm
C1 = 100pF
C2, C6, C7 = 100nF
C3 = 47nF
C4 = 10nF
C5 = 220nF
