  • 2 رأی - میانگین امتیازات: 5
سورس کد فشرده سازی فایل در vb6
RAMA2009 آفلاین
Banned
ارسال‌ها: 131
موضوع‌ها: 38
تاریخ عضویت: اسفند ۱۳۸۹
تشکرها : 43
( 59 تشکر در 51 ارسال )
سلام بچه ها حقیقتش توی اینترنت که سرچ کردم، راجع به فشرده سازی فایل چیزی جز این کد پیدا نکردم :
Imports System.IO
Imports System.IO.Compression
Public Class ZipUtil
    Public Sub CompressFile(ByVal sourceFile As String, ByVal destinationFile As String)
        ' make sure the source file is there
        If File.Exists(sourceFile) = False Then
            Throw New FileNotFoundException
        ' Create the streams and byte arrays needed
        Dim buffer As Byte() = Nothing
        Dim sourceStream As FileStream = Nothing
        Dim destinationStream As FileStream = Nothing
        Dim compressedStream As GZipStream = Nothing
        Try
            ' Read the bytes from the source file into a byte array
            sourceStream = New FileStream(sourceFile, FileMode.Open, FileAccess.Read, FileShare.Read)
            ' Read the source stream values into the buffer
            buffer = New Byte(CInt(sourceStream.Length)) {}
            Dim checkCounter As Integer = sourceStream.Read(buffer, 0, buffer.Length)
            ' Open the FileStream to write to
            destinationStream = New FileStream(destinationFile, FileMode.OpenOrCreate, FileAccess.Write)
            ' Create a compression stream pointing to the destiantion stream
            compressedStream = New GZipStream(destinationStream, CompressionMode.Compress, True)
            'Now write the compressed data to the destination file
            compressedStream.Write(buffer, 0, buffer.Length)
        Catch ex As ApplicationException
            MessageBox.Show(ex.Message, "An Error occured during compression", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Finally
            ' Make sure we allways close all streams
            If Not (sourceStream Is Nothing) Then
                sourceStream.Close()
            If Not (compressedStream Is Nothing) Then
                compressedStream.Close()
            If Not (destinationStream Is Nothing) Then
                destinationStream.Close()
        End Try
    Public Sub DecompressFile(ByVal sourceFile As String, ByVal destinationFile As String)
        Dim decompressedStream As GZipStream = Nothing
        Dim quartetBuffer As Byte() = Nothing
        Try
            ' Read in the compressed source stream
            sourceStream = New FileStream(sourceFile, FileMode.Open)
            decompressedStream = New GZipStream(sourceStream, CompressionMode.Decompress, True)
            ' Read the footer to determine the length of the destiantion file
            quartetBuffer = New Byte(4) {}
            Dim position As Integer = CType(sourceStream.Length, Integer) - 4
            sourceStream.Position = position
            sourceStream.Read(quartetBuffer, 0, 4)
            sourceStream.Position = 0
            Dim checkLength As Integer = BitConverter.ToInt32(quartetBuffer, 0)
            Dim buffer(checkLength + 100) As Byte
            Dim offset As Integer = 0
            Dim total As Integer = 0
            ' Read the compressed data into the buffer
            While True
                Dim bytesRead As Integer = decompressedStream.Read(buffer, offset, 100)
                If bytesRead = 0 Then
                    Exit While
                offset += bytesRead
                total += bytesRead
            End While
            ' Now write everything to the destination file
            destinationStream = New FileStream(destinationFile, FileMode.Create)
            destinationStream.Write(buffer, 0, total)
            ' and flush everyhting to clean out the buffer
            destinationStream.Flush()
        Finally
            If Not (decompressedStream Is Nothing) Then
                decompressedStream.Close()
        End Try
End Class
ولی ازش سر در نمیارمAmaze، کسی میتونه کمکی بکنه، یا یه سورس بده لطفاShy؟
۱۶-اسفند-۱۳۹۰, ۲۳:۰۴:۴۴
rap0661 آفلاین
ارسال‌ها: 171
موضوع‌ها: 16
تاریخ عضویت: اردیبهشت ۱۳۸۸
( 84 تشکر در 71 ارسال )
RE: سورس کد فشرده سازی فایل در vb6
سلام و دورود
نگاه دوست عزیز من یه نمونه داشتم الان دسترسی ندارم بهش یعنی نمیدونم کجا اناختمش ولی کار زیاد میبره و یکم دردسر است کلا
ولی میشه
۲۱-اسفند-۱۳۹۰, ۲۲:۴۹:۲۳
(۲۱-اسفند-۱۳۹۰, ۲۲:۴۹:۲۳)rap0661 نوشته است: سلام و دورود
ولی میشه
میشه یه مقدار بیشتر توضیح بدید؟
rama از کامپوننتی که پیوست کردم استفاده کن.
.rar   Compressor.rar (اندازه: 114.49 KB / تعداد دفعات دریافت: 243)
۲۲-اسفند-۱۳۹۰, ۰۳:۵۶:۵۵
تشکر شده توسط : javaweb
آخرین ارسال: مجتبی میر
آخرین ارسال: payamkhatib
آخرین ارسال: ARASHSOFTV
  شبیه سازی کلیک موس Mr.pRoGraMmer 11 11,157 ۰۷-اردیبهشت-۱۳۹۴, ۱۷:۰۷:۳۹
آخرین ارسال: aligadimkhani
  جدا سازی 3 رقمی mabus 8 6,045 ۲۷-بهمن-۱۳۹۳, ۲۳:۰۲:۴۶
آخرین ارسال: ِdownfile
آخرین ارسال: aleas
  [فوری] درخواست سورس afi2000 13 9,613 ۰۲-خرداد-۱۳۹۳, ۱۳:۲۷:۵۵
آخرین ارسال: fatima71
