مشکل در اپلود فایل با وی بی
kimiafars آفلاین
ارسال‌ها: 819
موضوع‌ها: 71
تاریخ عضویت: فروردین ۱۳۸۶
تشکرها : 663
( 1140 تشکر در 512 ارسال )
عزیزان سلام کسی میتونه بگه مشکل این کد چیه که به هاست کانکت نمیشه و اپلود نمیکنه...................................Dim bActiveSession As Boolean
Dim hOpen As Long, hConnection As Long
Dim dwType As Long
Dim EnumItemNameBag As New Collection
Dim EnumItemAttributeBag As New Collection
Private Sub Form_Load()
bActiveSession = False
hOpen = 0
hConnection = 0
chkPassive.Value = 1
optBin.Value = 1
dwType = FTP_TRANSFER_TYPE_BINARY
Dim imgI As ListImage
Set imgI = ImageList1.ListImages.Add(, "open", LoadPicture("open.bmp"))
Set imgI = ImageList1.ListImages.Add(, "closed", LoadPicture("closed.bmp"))
Set imgI = ImageList1.ListImages.Add(, "leaf", LoadPicture("leaf.bmp"))
Set imgI = ImageList1.ListImages.Add(, "root", LoadPicture("root.bmp"))
TreeView1.ImageList = ImageList1
TreeView1.Style = tvwTreelinesPictureText
EnableUI (False)
cmdClosehOpen_Click
Private Sub cmdInternetOpen_Click()
If Len(txtProxy.Text) <> 0 Then
hOpen = InternetOpen(scUserAgent, INTERNET_OPEN_TYPE_PROXY, txtProxy.Text, vbNullString, 0)
Else
hOpen = InternetOpen(scUserAgent, INTERNET_OPEN_TYPE_DIRECT, vbNullString, vbNullString, 0)
If hOpen = 0 Then ErrorOut Err.LastDllError, "InternetOpen"
EnableUI (True)
Private Sub cmdClosehOpen_Click()
If hConnection <> 0 Then InternetCloseHandle (hConnection)
If hOpen <> 0 Then InternetCloseHandle (hOpen)
hConnection = 0
hOpen = 0
If bActiveSession Then TreeView1.Nodes.Remove txtServer.Text
ClearTextBoxAndBag
EnableUI (False)
Private Sub cmdConnect_Click()
If Not bActiveSession And hOpen <> 0 Then
If txtServer.Text = "" Then
MsgBox "Please enter a server name!"
Exit Sub
Dim nFlag As Long
If chkPassive.Value Then
nFlag = INTERNET_FLAG_PASSIVE
Else
nFlag = 0
hConnection = InternetConnect(hOpen, txtServer.Text, INTERNET_INVALID_PORT_NUMBER, _
txtUser, txtPassword, INTERNET_SERVICE_FTP, nFlag, 0)
If hConnection = 0 Then
ErrorOut Err.LastDllError, "InternetConnect"
Else
bActiveSession = True
EnableUI (CBool(hOpen))
FillTreeViewControl (txtServer.Text)
FtpEnumDirectory ("")
If EnumItemNameBag.Count = 0 Then Exit Sub
Private Sub cmdDisconnect_Click()
bDirEmpty = True
If hConnection <> 0 Then InternetCloseHandle hConnection
hConnection = 0
ClearBag
EnableUI (True)
Private Sub ClearTextBoxAndBag()
txtServer.Text = ""
txtUser.Text = ""
txtPassword.Text = ""
txtProxy.Text = ""
ClearBag
Private Sub ClearBag()
Dim Num As Integer
For Num = 1 To EnumItemNameBag.Count
EnumItemNameBag.Remove 1
Next Num
For Num = 1 To EnumItemAttributeBag.Count
EnumItemAttributeBag.Remove 1
Next Num
Private Sub FillTreeViewControl(strParentKey As String)
Dim nodX As Node
Dim strImg As String
Dim nCount As Integer, i As Integer
Dim nAttr As Integer
Dim strItem As String
If EnumItemNameBag.Count = 0 And strParentKey = txtServer.Text Then
Set nodX = TreeView1.Nodes.Add(, tvwFirst, txtServer.Text, txtServer.Text, "root")
Exit Sub
nCount = EnumItemAttributeBag.Count
If nCount = 0 Then Exit Sub
For i = 1 To nCount
nAttr = EnumItemAttributeBag.Item(i)
strItem = EnumItemNameBag(i)
If nAttr = FILE_ATTRIBUTE_DIRECTORY Then
strImg = "closed"
Else
strImg = "leaf"
Set nodX = TreeView1.Nodes.Add(strParentKey, tvwChild, strParentKey & "/" & strItem, _
strParentKey & "/" & strItem, strImg)
Next
nodX.EnsureVisible
Private Sub cmdGet_Click()
Dim bRet As Boolean
Dim szFileRemote As String, szDirRemote As String, szFileLocal As String
Dim szTempString As String
Dim nPos As Long, nTemp As Long
Dim nodX As Node
Set nodX = TreeView1.SelectedItem
If nodX Is Nothing Then
MsgBox "Please select the item to GET!"
Exit Sub
szTempString = TreeView1.SelectedItem.Text
szFileRemote = szTempString
nPos = 0
nTemp = 0
nTemp = InStr(1, szTempString, "/", vbBinaryCompare)
If nTemp = 0 Then Exit Do
szTempString = Right(szTempString, Len(szTempString) - nTemp)
nPos = nTemp + nPos
szDirRemote = Left(szFileRemote, nPos)
szFileRemote = Right(szFileRemote, Len(szFileRemote) - nPos)
szFileLocal = File1.Path
rcd szDirRemote
bRet = FtpGetFile(hConnection, szFileRemote, szFileLocal & "/" & szFileRemote, False, _
INTERNET_FLAG_RELOAD, dwType, 0)
File1.Refresh
If bRet = False Then ErrorOut Err.LastDllError, "FtpGetFile"
Else
MsgBox "Not in session"
Private Sub cmdPut_Click()
Dim bRet As Boolean
Dim nodX As Node
MsgBox "Please select a remote directory to PUT to!"
Exit Sub
If nodX.Image = "leaf" Then
Exit Sub
If File1.FileName = "" Then
MsgBox "Please select a local file to put"
Exit Sub
szTempString = nodX.Text
szDirRemote = Right(szTempString, Len(szTempString) - Len(txtServer.Text))
szFileRemote = File1.FileName
szFileLocal = File1.Path & "\" & File1.FileName
If (szDirRemote = "") Then szDirRemote = "\"
rcd szDirRemote
bRet = FtpPutFile(hConnection, szFileLocal, szFileRemote, _
dwType, 0)
ErrorOut Err.LastDllError, "FtpPutFile"
Exit Sub
Dim nodChild As Node, nodNextChild As Node
Set nodChild = nodX.Child
If nodChild Is Nothing Then Exit Do
Set nodNextChild = nodChild.Next
TreeView1.Nodes.Remove nodChild.Index
If nodNextChild Is Nothing Then Exit Do
Set nodChild = nodNextChild
If nodX.Image = "closed" Then
nodX.Image = "open"
FtpEnumDirectory (nodX.Text)
FillTreeViewControl (nodX.Text)
Private Sub Dir1_Change()
File1.Path = Dir1.Path
Private Sub Drive1_Change()
On Error GoTo ErrProc
Dir1.Path = Drive1.Drive
Exit Sub
ErrProc:
Drive1.Drive = "c:"
Private Sub rcd(pszDir As String)
If pszDir = "" Then
MsgBox "Please enter the directory to CD"
Exit Sub
Else
Dim sPathFromRoot As String
Dim bRet As Boolean
If InStr(1, pszDir, txtServer.Text) Then
sPathFromRoot = Mid(pszDir, Len(txtServer.Text) + 1, Len(pszDir) - Len(txtServer.Text))
Else
sPathFromRoot = pszDir
If sPathFromRoot = "" Then sPathFromRoot = "/"
bRet = FtpSetCurrentDirectory(hConnection, sPathFromRoot)
If bRet = False Then ErrorOut Err.LastDllError, "rcd"
Function ErrorOut(dError As Long, szCallFunction As String)
Dim dwIntError As Long, dwLength As Long
Dim strBuffer As String
If dError = ERROR_INTERNET_EXTENDED_ERROR Then
InternetGetLastResponseInfo dwIntError, vbNullString, dwLength
strBuffer = String(dwLength + 1, 0)
InternetGetLastResponseInfo dwIntError, strBuffer, dwLength
MsgBox szCallFunction & " Extd Err: " & dwIntError & " " & strBuffer
If MsgBox(szCallFunction & " Err: " & dError & _
vbCrLf & "Close Connection and Session?", vbYesNo) = vbYes Then
If hConnection Then InternetCloseHandle hConnection
If hOpen Then InternetCloseHandle hOpen
hConnection = 0
hOpen = 0
ClearTextBoxAndBag
EnableUI (False)
End Function
Private Sub EnableUI(bEnabled As Boolean)
txtServer.Enabled = bEnabled
txtUser.Enabled = bEnabled
txtPassword.Enabled = bEnabled
cmdConnect.Enabled = bEnabled And Not bActiveSession
cmdDisconnect.Enabled = bEnabled And bActiveSession
chkPassive.Enabled = bEnabled
cmdClosehOpen.Enabled = bEnabled
cmdInternetOpen.Enabled = Not bEnabled
txtProxy.Enabled = Not bEnabled
optBin.Enabled = bEnabled
optAscii.Enabled = bEnabled
cmdGet.Enabled = bEnabled And bActiveSession
cmdPut.Enabled = bEnabled And bActiveSession
Private Sub FtpEnumDirectory(strDirectory As String)
ClearBag
Dim hFind As Long
Dim nLastError As Long
Dim dError As Long
Dim ptr As Long
Dim pData As WIN32_FIND_DATA
If Len(strDirectory) > 0 Then rcd (strDirectory)
pData.cFileName = String(MAX_PATH, 0)
hFind = FtpFindFirstFile(hConnection, "*.*", pData, 0, 0)
nLastError = Err.LastDllError
If hFind = 0 Then
If (nLastError = ERROR_NO_MORE_FILES) Then
MsgBox "This directory is empty!"
Else
ErrorOut nLastError, "FtpFindFirstFile"
Exit Sub
dError = NO_ERROR
Dim bRet As Boolean
Dim strItemName As String
EnumItemAttributeBag.Add pData.dwFileAttributes
strItemName = Left(pData.cFileName, InStr(1, pData.cFileName, String(1, 0), vbBinaryCompare) - 1)
EnumItemNameBag.Add strItemName
bRet = InternetFindNextFile(hFind, pData)
If Not bRet Then
dError = Err.LastDllError
If dError = ERROR_NO_MORE_FILES Then
Exit Do
Else
ErrorOut dError, "InternetFindNextFile"
InternetCloseHandle (hFind)
Exit Sub
Else
Private Sub optAscii_Click()
dwType = FTP_TRANSFER_TYPE_ASCII
Private Sub optBin_Click()
Private Sub TreeView1_DblClick()
Dim nodX As Node
If Not bActiveSession Then
MsgBox "No in session!"
Exit Sub
MsgBox "no Selection to enumerate"
nodX.Image = "open"
Else
If nodX.Image = "open" Then
۰۱-تير-۱۳۸۷, ۲۱:۲۸:۲۲
  [فوری] مشکل در ساخت فایل exe engzhina 8 6,092 ۰۱-مهر-۱۳۹۵, ۱۲:۳۴:۳۱
  مشکل حرف ی در نام فایل shinyboy 16 12,409 ۲۶-آبان-۱۳۹۱, ۱۹:۰۰:۴۷
آخرین ارسال: shinyboy
  [سوال] connectionString ها و مشکل در atach کردن فایل در VB one hacker alone 1 3,210 ۳۱-تير-۱۳۹۰, ۰۲:۰۵:۰۳
آخرین ارسال: Shayani
Question [سوال] مشکل فایل tlb bahar_azadi 6 4,038 ۰۹-تير-۱۳۹۰, ۱۰:۳۵:۲۹
آخرین ارسال: bahar_azadi
  مشکل در اکسترکت کردن فایل فشرده شده scream3196 0 4,436 ۲۷-دى-۱۳۸۹, ۰۱:۳۸:۴۵
آخرین ارسال: scream3196
آخرین ارسال: __Genius__
  مشکل با جست و جو فایل (مهم) saeedvir 2 2,893 ۲۹-بهمن-۱۳۸۸, ۱۶:۵۱:۵۳
آخرین ارسال: dreamvbfox
  مشکل با خواندن فایل متنی saeedvir 2 4,021 ۲۳-بهمن-۱۳۸۸, ۲۳:۳۸:۰۷
آخرین ارسال: krengaroo
